Question about Nintaus Televison & Video
The Nintaus DVD player says there is "no disc" when a disc is definitely in place, correct side up.
3 Suggested Answers
  • 86 Answers
SOURCE: Hi Definition
I believe the craig CVD329 is a progressive DVD player, not a HD DVD player. It can not read HD DVD discs, it can only read regular DVD discs.
Posted on Feb 15, 2008
jdvillanueva
  • 2098 Answers
SOURCE: I have a Onkyo DV-SP
Hi hannesswart,
Yes, Region 2 is for Japan, Europe, South Africa, and Middle East. Since you're unit is in correct region and same with the disc you are trying to play and still it came up with the "no disc" error, it means that the fault is in the optical lens assembly.
If you have necessary tools and test instruments, know safety precaution in basic troubleshooting try the steps below to solve your problem.
Assuming that the disc is good.
1.Clean the lens. - Sometimes because of dust and any fine foreign objects the lens can't read any disc. If you have a DVD Lens cleaner, play it to the unit. If this is not available you may manually clean the optical lens. Open the cover and gently clean the eye of the lens by smooth,clean,soft cotton buds. Be careful while doing this, just a gentle stroke only.
2.Check the ribbon - Check the ribbon connected to the lens from the main board for scratch, damage. Once it has an open line then of course the lens can't read the disc. Also try to erase the contact by pencil eraser. If you've done the steps above and the symptoms still there then the next step requires you a little knowledge in soldering technique and reading the ohmmeter.
3.Check the motor - Check the motor that spin the disc with an ohmmeter. You can test it using the ohmmeter (x1) even it is connected on the lens assembly.Good motor - reading should be fairly high and it will spin. Bad motor- reading will drop to low resistance and will not spin.
Click this link for more info.
LINK1
LINK2
Hint : Most of my repaired unit the above parts are commonly caused of the problem.
If you confirmed that you have a defective motor then replace it with a new one. Before replacing the new motor you have to check the clearance of the disc holder with the old one. The clearance should be the same as the old because if not the lens will not read the disc if it is too far or too close.
If the above steps didn't cure the problem, high chance that your optical lens was faulty.
If you can't do the job yourself, I would advice you to look for a professional to troubleshoot the symptom.
Also, check if your unit is under warranty period, avail it because the manufacturer will fix it for free. Don't attempt to open the cover(it will void the warranty).
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Jun 29, 2011
Protable phillips pet824 DVD player will play cd but not dvd's
follow this steps, and fix it. Merry Christmas.
However you must sure if you device can play any CD/DVD.
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Dec 17, 2013 | Philips Televison & Video
DVD video wont play
follow this steps and fix it. God bless you
Jul 08, 2013 | DMCOM Blu-ray Player Laptop External Usb...
Player stays in loading mode never finishing and playing the dvd
see the causes and fix it: God bless you
Clean with disk cleaner the Lens +OPU
Jul 21, 2012 | Audiovox D1812 Portable DVD Player
E disc it doesn't rI have a gpx DVD player D200B and when I insert thecordnize it. Says
see the next remedies:God bless you
Jul 21, 2012 | GPX Televison & Video
My JVC HR-XVC27U plays some DVDs but not others. They have the correct codes, but it seems to not play the newer DVDs like Toy Story 3
see the causes and remedies and fix it: God bless you
Jul 20, 2012 | JVC HR-XVC27U DVD Player/VCR
Panasonic dvd player in car
see the cause and remedies:
  7. rollers in PLAYER car, is worn or defective.
  8. use clean disk cleaner for to clean the OPU optical pick up or lens. see the block similar to dvd player conventional
Jul 20, 2012 | Panasonic Televison & Video
DVD side will not open, for the longest I could only get the DVD side to open if there was a disk in the slide yesterday the DVD side was closed with NO disk in it and now I can not open it
The DVD player in model DRC8295 uses a magnet to pull the Disc tray up into position. You can open up the front disc cover and push down slightly on the Disc tray and then push the open/close button to eject the tray. If this doesn't open the unit, you will have to unplug the unit and remove the cover. The cover is held in place by two silver screws on each side and five silver screws on the back of the unit. Once the cover screws have been removed, you can slide the cover towards the back halfway and then take the silver cover (held in place with two screws) off of the DVD player. Once the DVD cover is removed, insert a disc in the player and re-install the dvd cover and case cover. Plug the unit back in and eject and close the cover like normal. I have never tried to remove the magnet from the cover and checked to see if the DVD player still worked correctly. I have found it easier to just leave a Disc in it at all times. I leave a "Bad Disc" in mine and it opens/closes with no problems.
Apr 09, 2010 | RCA DRC8295 DVD Recorder/VCR Combo
Did not burn dvd
The DW-100 burns files in the same format as they were originally recorded by your camcorder. The Canon Vixia HG-21 records in AVCHD--a high-definition format--which is completely different from standard-definition DVD and which is not compatible with regular DVD players (even though the disc itself is a standard DVD-R). As it states in the manual for the camcorder, "High-definition (AVCHD) discs created using the optional DW-100 DVD Burner can be played back only with AVCHD-compatible DVD players."
The DW-100 is really more for archiving your files in their native format than for creating standard DVDs that can be played on regular DVD players. Regular (standard-definition) DVD players can't play AVCHD, although many Blu-Ray players can. Unless you use a Blu-Ray player that supports AVCHD playback, there are two solutions to your problem:
1. If you want to keep your recordings high-def, you can view them by playing them back with the DW-100, which must be connected to your camcorder via the USB cable, then from your camcorder to your TV via an HDMI cable.
2. If you want to have standard DVDs that you can play on any DVD player, either import the files to your computer and convert them to standard-definition using video-editing software, then burn them to DVD with your computer's DVD burner, or connect the analog output (component=better, composite=good) to a stand-alone DVD recorder (i.e. not the DW-100).
I've used the route of Vixia HF-10 camcorder > composite output > Panasonic DMR-ES25S DVD recorder (about $65 used on eBay) with pretty good results when I've wanted to give videos to relatives who don't have Blu-Ray players. You just have to make sure to set the camcorder 's analog (composite) output to 480i so that it formats the picture in the right aspect ratio, or else the 16:9 image will be squeezed to 4:3 instead of letterboxed.
Hope this helps. Good luck.
Mar 19, 2009 | Canon DW 100 DVD-RW Burner
Phillips pet 706/05 dvd player wont dvd-r-rw
  • Disc not loaded. Load a disc into the player, close the door and press PLAY.
  • The disc used may be defective. The disc used may be defective, try another disc.
  • The disc is placed improperly in the tray. Make sure the disc is properly placed and centered in the tray and if the disc has a label on one side, make sure the label is facing up.
  • The disc is dirty. Use a soft cloth to clean the disc by wiping in a straight line from the center of the disc to the outside edge.
  • Use of DualDisc or Flip Disc which does not meet the Compact Disc Digital Audio Standard. Some music labels have recently introduced the DualDisc for pre-recorded audio and video content. The DualDisc bonds DVD content on one side 'back-to-back' with digital audio content on the other side. However, the digital audio side does not meet the technical specifications specified in the Compact Disc Digital Audio Standard. For this Reason, DualDisc is not permitted to carry the CD logo. Philips DVD and CD players and disc drives fully comply with the CD specifications and therefore may not recognize the DualDisc. Attempting to use DualDisc may lead to playback problems or jamming in the slot loader or drive.
    The DVD video content on the DVD side of the DualDisc should play on Philips DVD players and DVD drives. However, Philips DVD players and drives do not support DVD Audio, and will not play any DVD Audio content present on the DVD side of a DualDisc. Philips will further investigate DualDisc and update this notice accordingly.
Jul 18, 2008 | Philips Televison & Video
Hi Definition
Feb 15, 2008 | Craig 731398403288
Televison & Video Logo
Top Nintaus Televison & Video Experts
Are you a Nintaus Televison and Video Expert? Answer questions, earn points and help others
