Question about Hoover Elite & Legacy Vacuum Cleaner Belt -
I have a Hoover Legacy model S3592 and the cord will not retract, it is fully extended. How can I fix this problem? Patty Lester
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 47 Answers
You may have to dis-assemble the machine to the point where you can gain access to the mechanism that retracts the cord. Then see if it can be fixed or needs replacement. Just don't lose any parts when dis-assembly, and make sure everything is put back together correctly.
Posted on Oct 19, 2013
4 Suggested Answers
SOURCE: Hoover S3630 WindTunnel
Solved. I downloaded the exposed view of the Hoover and located the screws.
Posted on Jul 14, 2008
SOURCE: S3765
The hardest part of fixing this is locating and removing the 5 Phillips-head screws without stripping the heads. There are 2 of them at the bottom front, 2 at the top back (above the wheels), and 1 at the back under the dust canister. After they are loosened/removed, you can remove the entire top cover of the vacuum (be careful with the wiring harness), and then the black plastic piece above the cord rewind reel. You can then easily remove the rewind reel, free the snagged cord, and reassemble.
Posted on May 23, 2010
  • 1503 Answers
SOURCE: Hoover UH70120 WindTunnel TSeries problems with
You will probably have to replace the cord winding mechanism. I have never had any luck trying to repair one. Cord retracters are great when they work but it seems like they always go bad before too long. On many units you can't even replace the cord if you get a bad spot in it, you have to buy a new cord reel which can get expensive.
Posted on Jul 21, 2010
How to fix retractable cord that won't go back
Gonna need a repair man if you are not handy. there a lot of parts to remove and put back (all of them). Check online for a parts manual that shows exploded views of the vacum.
Aug 30, 2014 | Hoover Vacuums
Retractable cord stuck
I wonder if there is a tangle in the cord. It could have also come off the wheel inside. Open the vacuum to see if you can untangle the wire and put it back on the wheel.
Nov 29, 2013 | Hoover Vacuums
The power cord is fully extended and will not retract in Miele LUNA vacuum cleaner model s4580
Keep playing with it, it will go if you are careful. The alternative is to disassemble the device and get involved with the retractor system. This is not always a simple task with springs under tansion, reassembly required about 8 hands ... which MAY be a small exageration.
Thanks for your question @ FixYa.com
Mar 23, 2011 | Vacuums
Hoover UH70120 WindTunnel TSeries problems with the cord. im a tech savy guy and have been trying to fix a cord after it was pulled to far out and now wont auto retract, but just cant find a way to pull...
Jul 21, 2010 | Hoover UH70120 WindTunnel TSeries Rewind...
Need Hoover cannister vacuum floor brush & filter bags
Hello, if you GOOgle Hoover you will be able to find your nearest Hoover center, they will then be able to help you with parts and bags. We did this last year and it was emensely helpful. Hope this helps.
Nov 04, 2009 | Vacuums
Hoover s3639 vacuum...cord does not rewind
I had the same problem with my Hoover s3639. The cord rewinder started squeaking, and retracted less and less of the cord each time, until it finally stopped retracting the cord at all. Here is what I did. I hope it will work for you as well. Open the covered tool storage and remove the tools. You should see three screws. Unscrew the screws. Remove the cover. You should see the motor for the vacuum and the cord rewinder. Between the vacuum motor and the white wheel where the cord is, you should see two brass wheels that turn into each other in order to operate the cord rewinder. Spray a small amount WD-40 between the two brass wheels. This should solve your problem.
Dec 29, 2008 | Hoover S3639 WindTunnel Bagged Canister...
S3765
Returned the sweeper to Costco for a full refund and bought another.
Sep 08, 2008 | Hoover S3765-040 WindTunnel Bagless...
Broken wire reconnected and power was restored.
Jul 13, 2008 | Hoover S3630 WindTunnel Bagged Canister...
Power cord will not retract
Your cordwinder is broken take it to your local Aerus Electrolux dealer. If you have any additional problems call Liz at 570-326-1731
Dec 01, 2007 | Electrolux Guardian Bagged Canister Vacuum
Hoover Elite & Legacy Vacuum Cleaner Belt - Logo
104 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
