At times my Panasonic High Def Digital Receiver does not work -
For Example...I can get no channels through the unit to work - it does not display or change channel through my plasma tv.When this hppens the LCD on the receiver has a small lower case ' n ' on it and does not change even after several power resets please explain this so it can be fixed. The model number of the high definition digital receiver is Panasonic TU-HDT104A....thankssame unit, exactly the same problem
  • 495 Answers
Try downloading firmware for the TU-HDT104A from Panasonic web page. It might be a software problem.
Posted on Apr 24, 2009
Picture problem on panasonic Vierra plasma tv
It looks like you are saying standard definition pictures do not cover the screen like HD pictures do. Standard def is formatted 4:3 and high def is 16:9. They are not the same so your high def screen is made to display the not as tall but wider high def picture. In order to fill the screen with the taller and not as wide 4:3 aspect ratio std def picture you must tell the TV to stretch the picture or otherwise fill the screen.The TV will have controls you can exercise for this purpose and you can set it up to always show std def in a particular manner. The alternative, if you want the standard Def picture to look true to form, is to view standard def in Letter Box form. It's appearance will then include black panels on the sides of the picture. So the problem is not with the TV but in accepting older format pictures playing on newer format displays (TVs.)
Mar 11, 2014 | Televison & Video
Picture problem on Panasonic Plasma tv
Mar 11, 2014 | Audio Players & Recorders
Is my apex tv AT2702 high def??
According to apex its not and does not have a digital tuner the only way this can be high def would be 720P meaning 720 lines progressive scan.
Your aspec Ratio is 4:3 this indeed is a standard TV without a digital tuner so you will need a digital setop box or a digital tuner.
High DEF is not considered digital its conidered how many lines are displayed on the TV. For example 720p, 1080p .
  • Silver, 27-inch monaural television; 29.6 x 23.2 x 18.7 inches (W x H x D)
  • Front-panel audio/video input accommodates a camcorder, VCR, or gaming console
  • 3 rear AV inputs (including 1 S-video input), 1 RF antenna input
  • Channel scan, channel recall, closed-caption display
  • Offers V-Chip parental control, sleep timer, auto-off, and a full-function remote control
Technical Details
  • Brand Name: Apex
  • Model: AT2702
  • Display Technology: CRT
  • Display Size: 27 inches
  • Image Aspect Ratio: 4:3
  • Speakers Included: 2 speakers
  • Height: 18.7 inches
  • Width: 29.5 inches
  • Depth: 23.2 inches
  • Weight: 88.2 pounds
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jan 27, 2011 | Apex Digital AT2702 27" TV
It wont work on lower cox channels.. High Def Channels work great
hi, there is an issue with your analog video board, this board converts the lower definition channels to digital, that is why your high def channels are ok
Sep 10, 2010 | Samsung HLP5674W 56" Rear Projection...
Recording HD channels
well you would need to hook up cable box to dvd recorder. the only draw back first off is one you cannot get hd onto a dvd. you can down scale and it will seem a little cleaner than standard def but of coarse it will never be high def. I'm not to familiar with the motorola boxes but if they offer dvr's in your area i would suggestgetting one you can record all channels then afterwards transfer them to a outside device. but as i said before high def cannot fit onto a dvd unless you plan to copy one movie to 6-7 disc. Just keep in mind a standard high def channelcan only fit 2 max on one freq due to the amount of data transfer as opposed to 10 to 12 standard def digital channels
May 08, 2009 | Televison & Video
Picture format
The HD reciever shouldn't be the problem.
If you recieve an image with a 4:3 aspect ratio, the image will be displayed at that ratio on your HDTV unless you specify otherwise. To do so go to your TV's Setup screen
setup
Choose picture formats
select smooth wide as your default
***Some digital (ATSC format) stations may transmit 4:3 images in a way that will not allow expansion. You will be unable to adjust the picture format.
Hope this helps!!!
J
Nov 17, 2008 | Hitachi 53SWX10B 53" Rear Projection...
Low def pictures on high def flat panel
do you have your video pluged in to the tv or any thing elc if so unplug the video any see if that work or it could be your ampifier let me know how you get on thanks
Jan 03, 2008 | Panasonic TH-50PHD8UK 50 in. Plasma...
Panasonic legacy connection
s-video is a legacy connection. legacy means obsolete and this will impare your image.
what you should do is connect the cable box and blue ray directly to tv with hdmi cable, then run audio cables back to the reciever from these devices. the vcr and regular dvd player would be routed through the reciever the conventional way. you would have to change the inputs on the tv between the cable box, and blue ray if u have one, and a seperate single tv imput for components running thru the stereo. you would have to use the reciever to select between audio sources, and the video sources between the vcr and dvd only.
Nov 04, 2007 | Panasonic TH-50PHD8UK 50 in. Plasma...
Onkyo TX-SR500 Dolby Digital problem
I just read over the problem you were having with your Onkyo TX-SR500 receiver. It sound like the unit needs to be setup for all five channels.Sence your symptom says the diplay shows Dolby D3/2.1. According to the owners manual with the remote control look for speaker setup whin the button is pressed the current speaker setup will be shown in the display. Press the preset/adjustment<> to change the current setting to five speakers. the listening mode will automatically change according to the number of channels you selected. Hope this helps. Radiotech
Aug 14, 2007 | Onkyo TX-SR500 Receiver
Televison & Video Logo
582 people viewed this question
Top Televison & Video Experts
