Pinnacle 27 laminator shows error 1 code. Machine runs for about 20 minutes then shuts off.
2 Suggested Answers
alicantecoli
  • 22326 Answers
SOURCE: I have a Pinnacle 27
have no idea what the code means but i would hazard a guess and say the heater circuit isnt working ,take it apart and try a volt meter across the heater element
Posted on Dec 19, 2010
Our machine is starting to squeal when working what do we do
There isn't anything you can do, those machines are screamers. sometimes they start screaching right away, sometimes it takes a few rolls of film run through before they start, but they ALWAYS start to scream, sooner or later. it becomes loud enough that some people refuse to use it because they think its coming apart. not my favorite.
Sep 18, 2014 | Gbc Pinnacle 27 Ezload Roll Laminator, 27...
Pinnacle er-1
left hand side cover is probably off and excess light is getting onto the motor speed sensor. put the side cover back on and try it, most likely that will fix it. could also be the set screw on the right side is loose, error 1 means you have a speed problem. check gears and chain. only other part that has caused this in the past is the keypanel.
Sep 15, 2014 | Gbc 1701720: Pinnacle 27 EZload Laminator
Why won't someone answer the ??s about the GBC Pinnacle 27 power light in the back works, but no power
Each heat shoe has a small thermal fuse, if either fuse is blown, the laminator keypanel will not operate. 99% fix everytime, just follow the wires from each heat shoe (right side of laminator) cover off. Ohm each set of wires and look for an open circuit. replace fuse (TCO) and it will work everytime......
Westco Laminating Service 405-324-6092
Aug 09, 2014 | Gbc 1701720: Pinnacle 27 EZload Laminator
Dryer blows circuit breaker after running 10-20 minutes.
indicates problem motor , overheating in the wiring or excessive loads in the drier
Jun 07, 2017 | Kenmore Dryers
The heat button won't turn on
either the top or lower heater shoe TCO is blown out. take the right side cover off, trace the wires back to the heat shoe and check for continuity, (unplug machine first) find out which TCO is blown order another one, replace it and your off to the races. I've fixed many of them.
Mar 11, 2013 | Gbc 1701720: Pinnacle 27 EZload Laminator
GBC Pinnacle 27 won't come on
each heat shoe has a small thermal fuse, if either fuse is blown, the laminator keypanel will not operate. 99% fix everytime, just follow the wires from each heat shoe (right side of laminator) cover off. Ohm each set of wires and look for an open circuit. replace fuse (TCO) and it will work everytime.
Feb 20, 2013 | Gbc ® Pinnacle 27 Two-Heat Roll Laminator,...
I have a Pinnacle 27 EZ load Laminator that keeps showing an ERROR CODE 02, nothing in my service manual showes me what this problem is, the unit will not run, HELP!
Dec 16, 2010 | Office Equipment & Supplies
I work for the city of red deer, and we just purchased the GBC Pinnacle 27" laminator. We keep getting an error code ( Er.1 ) it dosent list this code in the manuel. We have tried calling the 7 different...
That error is the speed sensor and it could be a bad sensor or light is getting into the machine and causing a hard time with the opticals in the sensor or it could be bad set screw, The transport system that moves the lamination holder is having issues. Check the chain and gears and make sure they are tight.
Dec 27, 2017 | Office Equipment & Supplies
Make movie keeps timing out, render error
I have also been running into an MPEGENCODER.DLL error about 1/2 way through my 20 minute movie. I am able to Make Movie with a 6 minute version, but hitting this error time and time again. I have removed Virus protection and all unessential system tray loads; defragged drive; downloaded newest Windows drivers; downloaded newest NVIDIA drivers; running Win XP Pro SP3, Intel 3GHZ, 1GB RAM, 76GB/10K spin drive.
Jul 01, 2009 | Pinnacle Studio Plus 12 for PC
k24674
jasbo
jasbo
