My grand daughter has a Dell Optiplex 620 that stopped working. Pushing the power-on button does nothing, no lights anywhere except for the yellow aux. power light. When I connect the power supply plug from the MoBo to my power supply tester all lights come on, on the tester except for the, -5V light & the CPU fan turns on. Would this indicate a bad power supply?
    New Friend:
    Problem Solver:
  • 8 Answers
When powering on the PC and you get no beeps, but you are getting power to the fans and hard drives, this may indicate either a bad power supply or bad memory. You can take the machine into a pc repair shop and have them test the memory and PSU for you.
Posted on Oct 14, 2013
SOURCE: Dell Inspiron 5160 wont turn on
I would suggest that first try running the psa test on ur system which could b done by press and hold FN key and power button together and leave it as soon as u see anything on the screen or any led in case u get any error code or beep sounds then it has to do with hardware and u ned to contact dell in case ur system is still under warranty.which lights do u see come up when u press the power button.I guess u r talking abt the led's for capslock , numlock and scroll lock.try reseating the memory module from the system and try running ur system on one memory chips and vise-versa because it seems that may b the prob is with the memory sticks.
in case u want manual for removing the memory sticks try using support.dell.com and u would get the manuals from there.
Posted on Feb 03, 2009
  • 90 Answers
SOURCE: Dell Precision M60 won't start up
Without battery connected it wont work. Better buy a new batterry connect it and plug it for charging for 8Hrs conitnuosly without switching on the laptop.
Posted on Apr 20, 2009
  • 130 Answers
SOURCE: Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
Posted on Jun 21, 2009
  • 479 Answers
SOURCE: 1150 dell inspiron. Laptop won't power up. If
This seems an issue with inverter board need to checked by an expert.
thanks
Posted on Jul 27, 2009
leecom72
  • 4806 Answers
SOURCE: Toshiba Satellite A75-S209 (PSA70U-09700E) PC
Take out the battery and try booting the machine on AC power only. If the machine boots up then let the operating system load up, the shut it down. Remove the AC jack and put the battery back in again, then power it up.
If it boots all is well if it doesn't then there could be a problem with the battery.
If the laptop won't start on AC power, what you could do is remove the system memory, clean the brass pins and the slots and then re-seat them/it.
Then try to turn the machine on.
Good luck.
Posted on Nov 13, 2009
Why does my desktop DELL Optiplex 1700L just flash YELLOW and refuse to come on, motherboard light is on
An Amber (Yellow) blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Apr 01, 2014 | Dell Optiplex 755 Desktop Desktop Computer...
Where is the fuse on a Dell Optiplex gx 620 PC
The computer is receiving electrical power, but an internal power problem may exist,Ensure that the processor power cable is securely connected to the system board,.It sounds like it may have had a power surge and may have burned something in your board.. You could try removing RAM unhooking everything hard drive cd drive un plug machine, hold power button till you see the amber light go out. reverse installing everything after it has sat for awhile and try to reboot
Jan 17, 2013 | Dell OptiPlex GX620 PC Desktop
My dell optiplex light is solid yellow
That usually means the switch on the power supply has been moved to 220v vs 110v. The switch is located just above where the power cord plugs in.
Aug 31, 2012 | Dell OptiPlex GX620 PC Desktop
Blinking amber power button light on Optiplex 990
It seems you have a problem with your Processor regulator that is why your computer sending an amber message.
This problem always happens to Dell Optiplex mostly and there is no solution for this except replacing your Motherboard.
To verify this problem unplug yellow (2 yellow and 2 black cables) cables near the processor and then try to turn it on when you see the fan processor can run smoothly and the power light getting green that is the sign that your processor regulator having some sort of problem.
Hope this will answer your problem
Apr 30, 2012 | Dell OptiPlex 990 SFF 1 x Core i7 2600 34...
Dell optiplex gx520 flashing yellow light on motherboard
According to the information you gave it seems it can still be the RAM. I've had a few PC's unable to startup due to bad memory.
Either that or the the front panel conectors are wrongly connected. Sometimes they do have a color code, but it's best to reference the manual. Can be the button . . .
If this is no help, I'd like to know more.
Apr 24, 2012 | Dell OptiPlex GX520 PC Desktop
My Dell Optiplex 620 started rebooting itself every time Windows started up and then it just went dead. I push the 'ON' button on the front of the computer and nothing happens. I have no lights, no fan,...
I would suspect that the power supply has gone bad and has to be replaced. A simple task, really. var fctb_tool=null; function FCTB_Init_b10486e133b24d6ca38e4d39d69b43a1(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_ee2e8b71ff554752b93d52dd01ec84ba(t) { fctb_tool=t; start(fctb_tool); }
Feb 03, 2011 | Dell OptiPlex GX620 PC Desktop
I have a Dell Precision 620 and the problem with running a PC. When I press the button, only yellow light is present and nothing happens. Control LEDs (4 pieces) on the rear side of motherboard does not...
Having worked with Dell computers before I have found that the amber light usually means bad power supply.
Get a replacement power supply from a know working Dell machine as their power supplies are different from standard ATX power supplies.
Regards.
Jan 13, 2011 | Dell Precision 620 PC Desktop
DELL OPTIPLEX GX 620 PC WONT SATRT ONLY ORANGE LIGHT KEEPS BLINKING
DELL OPTIPLEX GX 620 PC WILL NOT START.
ONLY ORANGE LIGHT.
Aug 31, 2010 | Dell OptiPlex GX620 PC Desktop
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
