Question about Datamax M-Class M-4206 Thermal Label Printer
Out of stock error on datamax m4206 - Datamax M-Class M-4206 Thermal Label Printer
How to solve out stock error message, ?
Slide the green plastic sensor outward by 4mm at the time then press feed. See if that fix it, if not check your sensor setting against the labels used.
May 23, 2014 | Datamax M-4208 Thermal Label Printer
Out of stock
Slide out the Media Sensor (green plastic bar that sticks out over the labels) about 1 inch from all the way in ("in" = left if looking from front). Then press Feed to clear errors. If still get same error, then look for piece of label or ribbon stuck in that error - ok to blow out with canned air.
Oct 19, 2011 | Datamax I-4208 Thermal Label Printer
I have a few Datamax-I-4206 printers and some of them have the Thermal Transfer ribbons and some do not....Do I need to have Thermal Transfers or cant I just print to them without it?
If the unit is set up for either(with the thermal trasnfer option- ribbon unwind and rewind assembly) you can use either ribbon- with thermal transfer stock, or direct thermal- with direct stock.
You can tell the stock by rubbing something across the stock to see if it will turn black, that is direct thermal stock.
If using direct, go into the setup and select media type- direct thermal.
If using ribbon- use thermal trasnfer option. But remember to install ribbon before calibration as ithe printer will error on out-of -ribbon.
Dec 31, 2010 | Datamax DMX I-4206 Printer
The printer is datamax I 4208 give me an error top of form fault
Try moving the sliding green media guide out from the wall about 1/4 to 1/2 inch, until the white line is under the label path. This green piece holds the label sensor, which needs to be under the labels so it can sense the gap between labels (or the black mark on the bottom side of the backing, if there is no gap). Also, on the printer menu you must choose whether your stock has a gap (aka web) or black mark (aka reflective).
Oct 12, 2010 | Datamax I-4208 Thermal Label Printer
Hi we are using the Datamax Mclass printerwhen we switch on the printer it comes with error on the display screen as out of stock and position fault. could any one please help?
Check to see if you are using the right settings for your paper stock - could be a mark or a gap - this is in your printer settings.
Always check your paper sensor to make sure it is in the right position to see your paper stock.
Calibrate the printer - hold down the FEED button (should have printable stock loaded) and wait till the printer cycles 8-10 times. Will say "Calibration Complete".
If it says "Can not calibrate" then you probably need to check your paper sensor position again.
Hope this helps.
Jul 17, 2010 | Datamax M-4208 Thermal Label Printer
We use the Datamax Printer to print labels with labelview. The printer itself however keeps saying :position fault" how do I fix that?
Position fault or Out of stock when the printer is loaded with paper stock can usually be solved by calibrating the printer.
Press & hold the FEED button. Let the printer cycle 8-10 times. Should feed to the right position and say Calibration Complete in the window.
Hope this solves your problem.
Jul 12, 2010 | Datamax DMX-I-4208 Label Printer
We can not use our print DATAMAX DMX M CLASS
What type of stock are you using? Gapped, continuous, or reflective mark?
If you are using a standard gapped stock, and the stock is loaded in the printer and ready, press the feed button until 3-6 labels are passed beneath the media sensor.
If you are using reflective (eyemarked stock) go in the the media settings. Change the sensor type to reflective.
Make sure that the eyemark is presented to the sensot at the small white strip on the sensor. Do not move the sensor to a place where the sensor will see anything but the mark.
Dec 31, 2009 | Datamax I-4308 Thermal Label Printer
Looking for printing specifications for the Model M4206 and M4210
http://www.datamaxcorp.com/software/
Manuals for both units are listed at Datamax-O'Neil.
Both pirnters have been discontinued, but service and parts are still available.
Dec 29, 2009 | DPI Datamax M-Class M-4306 Printer
Printhead won't balance... I have tried everything. I'm printing horticultural products (tags, labels, potstakes...) and I can't get a "happy medium" on print quality when changing stocks. I am highly...
Buy a Zebra or a TEC printer, they haveno problems with ballancing. I have had similar problems with a customer Datamax printer and could not sort it.
Jun 23, 2009 | Datamax H-Class H-8308X Printer
Out of stock
out of stock warning on display?
check to see if the label sensor is over the gap on the die cut stock.
if not die cut?
If reflective, make suree you have the correct sensot set in the printer configuration.
You can go to test, and print a conf label to see how it is set.
You may also have to do a calibration depending on the error
Feb 12, 2009 | Datamax M-4208 Thermal Label Printer
Datamax M-Class  M-4206 Thermal Label Printer Logo
755 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Greg Cann
Greg Cann
Kevin Brown
Level 1 Expert
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
