Question about Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
My blower motor pulley and spindle keeps coming of of my whirpool WED7600XWO. How do i keep the spindle from coming off? thanks, Jon
  • 64 Answers
There should be a 'locking screw or clamp' of some sort holding it in place, suspect this device has 'come loose or dropped off'.
Check and refit if this is the case.
Posted on Oct 16, 2013
  • 119 Answers
Use locktite for the motor pulley. what you mean by the spindle?
Whirlpool dryer model LER562KQ1 continues to make groaning/lo-pitched whining noise as drum turns even after installing preventive maintenance kit(rear seal not included).
follow this steps and fix it. God bless you
Rollers
Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. You will need to disassembly dryer to check these. Some dryers use rollers in both the front and rear.
Belt
The Belt should be replaced if you hear any noise coming from it or if there is any cracking, glazing, or grooves worn out. Replace it along with the idler pulley.
Idler pulley
Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides
Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace it if necessary. Put hand inside drum near front and push up there should be no play.
Rear drum bearing
Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace it when they're worn. Put hand inside drum near rear and push up there should be no play.
Blower wheel
Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermosta ts, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it Many times the blower wheel is making the noise and it is commonly mistaken for the motor.
Motor
The motor may be making noise. The easy way to check is to remove the belt and turn the dryer on if it is noisy replace it
Oct 01, 2013 | Whirlpool Dryers
Dryer shutd off.
see the next steps and fix it. God bless you
Not all will apply to every dryer. Check our video page for more style dryers.
Rollers
Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. You will need to disassemble the dryer to check these. Some dryers use rollers in both the front and rear.
Belt
The Belt should be replaced if you hear any noise coming from it or if there is any cracking, glazing, or grooves worn out.replace the belt along with the idler pulley.
Idler pulley
Dryers have a tension or ideler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides
Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace the glides and bearing houses if necessary. Put hand inside drum near front and push up there should be no play.
Rear drum bearing
Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace the rear bearing when they're worn. Put hand inside drum near rear and push up there should be no play.
Blower wheel
Your dryer's blower whells pulls air over the heat source, through the clothes drum, and past the thermosta ts, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace the blower whell Many times the blower wheel is making the noise and it is commonly mistaken for the motor.
Motor
The motor may be making noise. The easy way to check is to remove the belt and turn the dryer on if it is noisy replace the motor
Jul 09, 2013 | Dryers
Belt keeps coming off
Something is not lined up. Maybe you installed new spindle in opposite direction?
Mar 03, 2018 | John Deere Garden
Why dose my washer keep throwing belt
It can be due to problems faced by poor alignment of the motor, pulley and shaft. Also it can be due to worn belt or tight spindle that makes the belt slip over. check the free movement of the spindle and pulley , if not the assembly must be reset.
Jan 17, 2013 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
We have a air flow problem but exaust tube is not clogged no air coming out of bottom of dryer
On this weird dryer the blower is not mounted to the motor. Instead a fancy blower is mounted away from the dryer and requires a second smaller belt to drive it. What goes wrong? The drive pulley for the blower often falls off the motor. Locktite is recommended to keep the blower pulley secure to the motor shaft or this will be the result:
MAYTAG 2 BELT dryer innards
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 10, 2012 | Whirlpool Dryers
My dryer is making a loud humming noise
your pump belt in motor to spindle were tilted or loose. or your motor need to replace coz i think your washing maybe is to old
Mar 02, 2010 | Frigidaire Dryers
Replacing the drum belt
Hi.
Ensure power is disconnevcted first!
  1. Locate the lid. On both left and right front of the lid you will find a cover. Remove covers and this will gain access to screws (probably will be star shaped heads so a normal philips screw driver wont work.) B&Q will sell them.
  2. slide top backwards. It might need a slight tap as its often tight. Push lid backwards and it should lift off.
  3. Now the drum spindle will be located at the back of the appliance. If the belt is still intact then you have a fault somewhere else. If belt has come off then you will need replacement belt, part number, 1603287
  4. Remove bottom plate, located at back of appliance. here you will see the motor spindle.
  5. This is now the tricky part. The belt is a stretch type so it will appear to be too short but the best way to do this is to put the belt around the motor spindle first. then place around one side of the drum spindle (normally black). If you have a extra pair of hands then as you stretch the belt over the spindle someone else can SLOWLY rotate the drum (by placing their hands inside the drum and holding on to the paddles) and you can then "thread" the belt round. You may need to do this a few times as sometimes the belt slips off.
Good luck.
AARDVARK REPAIRS
Nov 18, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
I have a 20 year old table saw of unknown manufacturer (but all machne parts are metric). The spindle pulley (mounted on motor spindle - it accepts v-belt from motor pulley) keeps coming loose. i think the...
Simple, there are two options:
1) buy a new pulley from any hardware or home improvement store.
2) If threads are stripped from pulley, either retap with next larger size tap, or redrill new hole and tap with same size as the current size. Note the best way to keep pulley on is to have a set screw over the key and another at 90 degrees from keyway. Note 2 - Are you sure current pulley does have two set screws?
Jun 26, 2009 | CMT Saws
Whirpool gas dryer
HI thanks for the question. the drum must be out. with a right size wrench. hold the blower wheel . from turning . with a 3/4 inch socket. put socket on the motor pulley. turn the socket clock wise . it should loosen. thanks the appliance doc
Apr 13, 2008 | Whirlpool LGV4634JQ Gas Dryer
Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
69 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
