Question about Kenmore Ovens
Kenmore 66572173301 oven wont light. replaced ignighter still wont work
5 Suggested Answers
Sea Breeze
  • 4654 Answers
SOURCE: kenmore oven
This oven may fall under the touch pad complaint that many customer are having, click link to see if your's is one. http://www.lieffcabraser.com/profileovencomplaints.htm
Posted on Oct 23, 2007
  • 3 Answers
SOURCE: Oven won't light
I am assuming this is a gas stove. You probably need a new flint in the igniter. Simple problem. Check your local hardware store for flint, and refer to your manufacturer's manual for how to install it. If it's not there, a quick call to a service technician should answer the problem. hope this has been helpful.
Posted on Oct 24, 2008
  • 5 Answers
SOURCE: electric ignighter does not come on in the oven at all
In most cases it is the ignitor itself. Eledtricity goes thru the ignitor and as it gets hot it allows more electricity thru to the gas coils, allowing them to open and let the gas go thru. The ignitors do get weak and will glow but that is all. Not enough electricity can get to the gas valve solenoids and let gas thru. Find a local parts dealer and give them your make and model # to order the part.
Posted on Jan 28, 2009
  • 193 Answers
SOURCE: oven wont light, pilot is lite but the burners
Bakers Pride used several different safety valves over the years. If your oven has a pilot valve that has a beige know that you hold in and turn to light the pilot, then after it lights you need to turn the beige know another half round to the "on" setting. If you push in a red button to light the pilot, it may not be getting enough heat on the thermocouple where the pilot flame should be heating it up. Be sure the main gas valve on the front of the oven is turned to the on position also. On some models the pilot will light with the main gas valve in the off position. If you look at the pilot flame while it is burning, make sure that it is hitting the pencil sized thermopile enough to make it glow red. If not bend it slightly to improve the heating.
Posted on Sep 07, 2010
Oven kicks on gas lights runs for 10 sec then beeps showing preheat is done then kicks off
I had to replace my igniter to get mine to work. I did it myself for $65.00 Mine the gas just would not stay on to heat up.
Mar 13, 2015 | Maytag Ovens
Frigidaire oven won't stay lit
sounds like you have to much propane coming out at one to ignight and flooding it can u adjust the level,of propane that will help unlell u ignighter is a slack one getting old
Sep 14, 2008 | Ovens
Kenmore gas oven model 36275578690 oven wont light
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Apr 20, 2011 | Kenmore Ovens
Viking gas stove operators manual....I was working on my stove ...it was not lighting up....the stove......and I noticed that there was 2 burners...and when I replaced one of the ignighters and tryed the...
The way it works is the igniter gets voltage signal from the control and will start to glow. The gas valve for the burner and the igniter are wired on the same circuit. When the igniter starts to glow it takes all the voltage from the circuit. As the igniter increases in temp the resistence changes and the voltage starts to travel to the gas valve. Once the gas valve registers 3 to 4 volts it will open allowing gas to the burner for ignition. The igniter needs to reach approx 2200 degrees for this to happen. So it could be the igniter or the gas valve. The igniter should test approx 500 to 700 ohms with a ohm meter. The gas valve could also be sticking. If the igniter is glowing bright and you tap the gas valve with a wrench and it comes on then the gas valve is sticking and needs replacement(as long as the igniter tests good)...Hope that helps.
Oct 11, 2009 | Viking Ovens
The lower oven ignighter does not glow
I had the same problem and swapped the oven igniter with the broiler igniter and the oven now works. This proved the oven igniter itself was the fault, now I have to replace the broiler igniter with a new one(which is much easier to get to).
FYI: An igniter may glow red and still not allow the oven to work. The igniter has to draw a certain amount of electrical current for the main gas valve to open.
Jul 20, 2009 | GE JGRP17 Gas Single Oven
Electric ignighter does not come on in the oven at all
Jan 28, 2009 | Magic Chef 9122 Gas Single Oven
The top burners do not light?
your ignighters are not working,,,you need to have it serviced for them to work again..the ignighters are what start the heat process.
Jan 08, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Pilot Light Wont Light
Take off the top cover plate inside the oven. Now with the door open turn the oven on does the hot surface glow? If it doesn't glow then you have a bad igniter and needs to be replaced. What ever you do don't touch the surface of the new igniter human oil will shorten the life of the igniter. now if the hot surface glows then the gas valve is bad and need to be replaced. I'm betting it's the hot surface.
Nov 25, 2008 | Amana Ovens
Oven won't light
Oct 24, 2008 | Ovens
Kenmore oven
Is this an electronic control oven...touch pads to set temp? May have a bad ERC. Electronic Range Control. Also check oven sensor. This is steel rod in oven in back wall near top on left or right. Check ohms from the rear where it connects to harness. Disconnect at harness and measure resistance of sensor. Most are around 1.1k.
Oct 07, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
13 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
