Question about Olivetti wireless All-In-One InkJet Printer
Cannot install my ink cartridges
I'm trying to set up my any way for the first time (I've had it for ages, but never taken it out of the box). When I opened it up to install the ink cartridges, it looks like ther are some bits missing, as there is nothing to actually 'click' the cartridges into, just some white foam at the r-h end of the carriage - no 'securing clip'. Can anybody help - am I being stupid? Could anyone send a pic of what the inside should look like (it's difficult to tell from the diagrams).
Thanks
  • norbitonite Apr 27, 2009
    turns out that there's a problem with the carriage, but thanks, inka30, for wasting your time in posting a flippant, patronising reply and for wasting mine in reading it.
    Champion:
  • 214 Answers
Pull out the foam- then read the manual It's a small book that comes with the printer)
Posted on Apr 24, 2009
I've bought new cartridges and it keeps telling me cartridge problem or cartridge appear to be missing; What can I do about this problem ? or do I have to return the machine to you for a refund or
Please install one cartridge at a time and close the cartridge access door to check if the error pops up.
Also inspect the T shape vent on all of the cartridges, which should be clear and not clogged.
While installing the cartridges, make sure there is click sound when you install it.
If issue still persists, contact HP Tech Support as it could either be an issue with the Printhead or the Printer hardware itself.
If you are in USA, please call 1-800-474-6836
Jan 10, 2013 | HP 564 XL Series Ink Cartridge Set for...
Won't Print Color Ink
INK PROBLEM
Inkjet printers need to be used frequently to prevent inkdrying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
May 19, 2012 | HP PSC 1510 All-In-One InkJet Printer
E 22 error .. i've tried many times to fix the catridge or whatsoeva is that , but it didnt work . help me!!
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Thank you for using Fixya
Aug 25, 2011 | Office Equipment & Supplies
We just bought a new ink cartridge for our HP c5580 all in one printer. All the other colors print fine - EXCEPT BLUE. It comes out as a "tealish" looking green. We've tried cleaning the...
Jul 08, 2011 | HP Photosmart C5180 All-In-One InkJet...
I refilled the ink cartridges on my canon mp250 copier because it stoped printing. The little info box said that the ink was running low now it still won't print . I 've re inserted the ink cartridges...
originally, when u have ink cartridges in Canon product run low u need to buy new ones, because it was designed like that. even u have refilled the old cartridge full, it will detected low ink because the old cartridge already detected for the beginning. this designed to make Canon buyer to buy new ones ink cartridge. but, there some trick to make your old cartridge detected as new one, all u need just to reset the setting for cartridge recognition. try to visit this site:
http://resetcanon.com/reset-canon-mp250-pixma-inkjet-all-in-one-printer/
maybe this site can help your problem, regard riyan.
Mar 09, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
I forgot how to change the ink cartridge on my printer i dont rember where it is please help
If you go to the below link -
Canon MP530 manual
and look at pages 44 - 46 it shows you how to change the ink cartridges. Just bear in mind the page takes a while to load as its a 4mb pdf so it will just stay black for a while until it downloads.
Thx, if this solution helps please rate :)
Feb 03, 2011 | Canon PIXMA® MP530 All-In-One Printer
Ink cartridges cannot be recognized in canon printer
Hello!
Remove the cartridges and gently wipe the cartridge contacts with a dry cloth, then put them back in. Then, hold the "resume" button for 10 seconds for each cartridge, that should reset them.
If that doesn't work, one of your cartridges (sadly) needs to be replaced.
Apr 15, 2009 | Canon PIXMA iP1300 Printer
My ink lamp does not light red-pixma mx700
Have you installed the print head? It's a separate item in a foil colored sealed package. It must be installed and locked in before inserting the ink tanks. If you have done this and still get no lights on the ink tanks, there is something wrong with the unit itself.
Nov 05, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Ink cartridge (not) installed properly
For the Canon iP1800 printer are you sure you're using the 30 for black and 31 for color?
And make sure they "click" when installed. That should confirm that they're nice and tight in their ink compartments.
Besides that, maybe reinstalling the printer drivers could do something?
Sep 08, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Newly installed and getting error on printhead and ink cartridges
If that error happens every single time you turn on the printer, that pirnthead is faulty.
But if the error only happens some times, try a firmware update from www.kodak.com/go/downloads
Jul 04, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Olivetti wireless All-In-One InkJet Printer Logo
183 people viewed this question
Top Olivetti Office Equipment & Supplies Experts
James Cagle
James Cagle
Alun Cox
Are you an Olivetti Office Equipment and Supply Expert? Answer questions, earn points and help others
