Question about RoadPro RPAT715 12-Volt Rechargeable Air Compressor / Jumpstart / Emergency System w / Power Inverter
Unit will not take a charge. Roger
  • 438 Answers
Do you have a multiy meter ? can you check to verify your adapter unit is providing power ? are you capable of taking your unit apart and locating the devices internal that make your unit function ?
If so contact me further for more info
best regards Falco
Posted on Nov 05, 2013
Generac XP8000E how do you replace the battery charger fuse 1.5 all I can find out is you have to remove the control panel. No manual and can't find any info
Roger,
1st check the voltage going into the Battery Charging Rectifier from the alternator. You should get between 12 Volts DC to 16 Volt DC with the engine running.
If you get these results next check the battery. You should get max 13v dc going to the battery. If your battery is not charging on this unit or gets under 12x dc, you need to replace the battery charging rectifier.
http://www.generatorguru.com/battery-charging-rectifier-99302775/
If you need other parts you can find them on this page.
http://www.generatorguru.com/xp8000e/
Hope this is of assistance to you!
Dec 19, 2016 | Generac Electrical Supplies
I need to cancel a transaction I just made with Society for Research into Hydrocephalus and Spina Bifida
Contact Us Please use the contact details on these pages to get in touch with us. We look forward to hearing from you.
Email Address info@srhsb.org
Postal Address Hon Secretary
Mrs Rosemary R Batchelor
ASBAH House
42 Park Road
Peterborough
PE1 2UQ
United Kingdom
srhsb@asbah.org/
Hon Treasurer
Mr Roger Strachan
Dept. of Neurosurgery
The James Cook University Hospital
Marton Road
Middlesbrough, Cleveland
TS4 3BW, UK
FAX +44 (0)1642 282770
rogerstrachan@hotmail.com
Contact Name President`
Roger Bayston - roger.bayston@nottingham.ac.uk
May 21, 2011 | Computers & Internet
Where is the location of the fuel sending unit in an astro 1999?
Hello sidmary: My name is Roger and I will answer your question. The location of the fuel sending unit is in the fuel tank. It attaches to the fuel pump assembly. THis unit is serviceable separate from the fuel pump. It is a factory part you can buy at a dealer. The parts store show it bat as not available. Should you need further help please just ask. Please rate the answer. Thank You for using Fix Ya. Roger
Jan 17, 2011 | Chevrolet Astro Cars & Trucks
It shuts down it acts like it is not charging bttery is 12.75. When i put the head lights on it goes down to 12.17
Hello paulschwalm: My name is Roger and I will help you. If your jeep is only charging 12.75 volts? You should be charging more. 12.5 is bear minimum voltage. Will not sustain lights and heater operations.Anything less than 12.5 volts the computer will start shutting down components to protect the battery and the memory of the computer. I would have the alternator tested as it should produce 13.0 to 14.5 volts Should you need further help please just ask. Please rate the answer. Thank You for using and trusting Fix Ya.Roger
Dec 21, 2010 | 2005 Jeep Grand Cherokee
Location of oil pressure sending unit 1998 buick lesabre
Hello l rowan: My name is Roger and I will help. You should find the oil pressure sending unit directly above the oil filter. Should be on the filter housing to the left of the exhaust manifold. Should you need further help please just ask. Please rate the answer. This way I know the answer was helpful. Thank You for using Fix Ya. Roger
Aug 11, 2010 | 1998 Buick LeSabre
Freon for the back
Hello tbirch6: My name is Roger and I will try to help you. Your question is not real clear. If you want to know what kind of freon to use? The freon is the same as the front system. Both the front and rear a/c systems are the same. There is not a separate system for each. If you fill one you filled both. The total amount of freon for both units is 54 ounces or 3lb.4 oz. The best way to recharge the system is to start from scratch with a vacuum on the system and a complete recharge of the system. There is noway of knowing how much of a charge is in the system otherwise. Most shops can preform this task at a reasonable charge. Please do not just vent the freon into the atmosphere as it depletes the Ozone layer. Should you need further help please just ask. Thank You for using Fix Ya. Roger
Jun 19, 2010 | 2003 Ford Expedition
What kind of refridgerant does it take for the air cond
Hello boardchairma: My name is Roger and I will help. The correct freon for your car is R134A. If you have the system partial charged. Make sure it is not over charged. his will cause damage to the components of your air conditioner system. Should you need further help[ please just ask. Please rate the answer. This way I know it was helpful. Thank You for using Fix YA. Roger
Jun 19, 2010 | 1998 Chrysler Sebring
2005 Monte Carlo 2800. Belt Broken. No diagram need diagram
Hello carsongore: y name is Roger and I will help you.I attached a picture of the 3.8 non super charged engine. You did not state if yours was super charged or not. The belt routing is the same on both engines. The difference would be the separate belt for the charger. Should you need further help please just ask. Please rate the answer. Thank You for using Fix Ya. Rogerb137de7.jpg
May 22, 2010 | 2005 Chevrolet Monte Carlo
Car died, starts when jump it and dies again soon as charge drain
Hello dpkommineni: My name is Roger and I will answer your question. The problem you described is that of a car not charging the battery. You need to have the charging system tested. The alternator should charge between 13.5 to 14.5 volts. Anything less then 12.5 the battery will go dead. Since the weather is hot any use of the head lamp and A/C the battery would die fairly fast. I would also have the battery tested. Should the battery have a open cell then it would not take a charge from the alternator.
Should you need further help please just ask. Please rate the answer as this way we can tell you received helpful information. Thank You for using Fix Ya. Roger
Jul 06, 2009 | 1995 Nissan Maxima
Roger black treadmill.
i can repair or supply any roger black parts that you would need. contact me on 01706 371711
Jan 27, 2008 | Baby Gear
RoadPro RPAT715 12-Volt Rechargeable Air Compressor / Jumpstart / Emergency System w / Power Inverter Logo
Top RoadPro Electronics - Others Experts
jdthefixer
deton8 von Splosion
Are you a RoadPro Electronics - Other Expert? Answer questions, earn points and help others
