Question about Dryers
The lint trap isnt collecting it is plugging up ducts why???
  • 64 Answers
Check the 'outlet vent hose', it should be 'level or sloping downhill' If it is 'looped' there could be a 'water trap' preventing the air from escaping.
Posted on Oct 16, 2013
ronpar
  • 27 Answers
SOURCE: Whirlpool Duet Dryer - Working but no heat
it sounds like your heating element is gone bad. there is no heat if they burn out or get corroded
Posted on Jun 29, 2008
abhishek33
  • 1239 Answers
SOURCE: I want to know how
Besides drying clothes, dryers also remove lint. This fine, fuzzy material can cause trouble because it blocks dryer lint traps, clogs vents, and fills blowers. Lint can also gather around and in the tracks of the drum rollers, or in and under the pulleys and the drive belt. The result is poor clothes drying or -- sometimes -- no drying. To avoid lint problems, clean out the dryer's lint trap system every time you use the dryer.
To clean the lint screen, remove it from the unit. The screen may be located near or under the door sill, or in the top of the dryer near the control panel. It can usually be removed by pulling it up and out of its housing. Remove the accumulated lint to clear the screen; then replace the screen.
The exhaust vent also collects lint. Vent maintenance involves cleaning the lint from a screen in the dryer's vent exhaust collar and/or at the end of the exhaust vent where it sticks out through a basement window or through an exterior wall. To clean the screen, remove the clamp that holds the vent to the collar, or back out the screws that hold the vent to the collar, or pull the vent straight off an extended collar. Clean the screen thoroughly and replace it in the vent assembly.
To clean the vent itself, use a vent-cleaning brush (available at hardware stores) to pull out any lint deposits. Also check the vent run to make sure that the vent piping or tubing isn't loose at the joints, or -- in the case of flexible plastic venting -- isn't sagging between hanging brackets. Breaks or sags cause undue strain on the dryer's blower system, and can cause drying problems. If the vent pipe or tubing has become clogged with lint, remove the lint by pushing a garden hose or a drain-and-trap auger through the vent to a convenient joint. Disassemble the joint to remove the debris. With this procedure, it isn't necessary to disassemble the entire vent to find the blockage.You can head off problems before they become too serious by providing routine maintenance for your dryer's door gasket, thermostat, timer, and other frequently used parts. Let's discuss how to service these important components in the next section.
how-to-repair-a-dryer-1.jpgTHANK U.. RATE IT...
Posted on Sep 11, 2008
  • 10 Answers
SOURCE: Lint is not going into pull out lint trap. The lint screen is torn and lint is collecting behind trap.
Poor air flow would be my guess. How long is the vent hose? Does it have more than one angle/turn before venting outside? Is the lint gathering around the outer edges of the door? Keeping the length of air travel shorter will improve the operation.
Posted on May 12, 2009
dawson57
  • 25 Answers
SOURCE: Lint fell down the lint trap. How do I get it
Luckily, dryers are light. Best thing to do is pull it out until you can remove the back cover. (unplug it first) Then vacuum and clean all the dust and lint you can. This should be a yearly thing at least anyway. Replace the back plug it in and slid it back. I do mine every 6 months or so.
Posted on Jul 13, 2009
milten1
  • 1304 Answers
SOURCE: Lint is massing toward the bottom of the lint trap
please check your exhaust vent, where the dryer air comes out of the house, this particular pattern is very indicitive of a slow moving exhaust, you may need to clean the duct between the machine and exhaust as well
Posted on Oct 22, 2009
Testimonial: "Thanks, I'll do that!"
Burning smell when dryer is turned on for a few minutes.
Hi Paul
At the very least, it could be that lint has collected in the vent hose.
There have been cases where lint has bypassed the lint trap and gone places that it shouldn't be.
Worst case scenario is that your dryer motor is checking out.
I'd have a pro look at this if there is no lint in the vent hose.
-Steve
Apr 02, 2015 | Dryers
Lint trap not collecting lint
the lint trap is a thin gauze material and should trap plenty of lint---are you sure its there or in place properly?
Sep 23, 2012 | Estate TEDS840JQ Electric Dryer
Clogged lint inside dryer exhaust
there is a vent cleaning kit that can be baught at lowes or home depot and comes with attachments to get down inside the lint trap to be vaccumed out.
you can also lift the lid and remove the front panel and get to the trap area
Mar 28, 2010 | Whirlpool LER4634J Electric Dryer
F @ P DEGX2 lint trap problem
If you are collecting more on the outside of the house means the lint filter has a tear in it and the lint in being pulled through the tear and pushed out the exhaust. It sounds like you need a new filter but this isn't cheap. If you do it your self it will run about $70 if you get a repair man it will cost about $150.
Feb 25, 2010 | Fisher and Paykel DEGX1 Electric Dryer
I have constant lint buildup in the exhaust pipe. Why isn't the lint trap catching it?
No lint trap catches ALL the dryer lint. Some small particles of lint are always exhausted through the dryer exhaust along with warm moist air as your clothes dry. In a perfect world, this lint makes it all the way to the end of the dryer exhaust and exits your home. However, if you have any kinks, excessive bends, sags, or excessively long ducting runs, the can create choke points for lint to accumulate. This creates resistance and makes and condensation forms inside the dryer vent. With condensation, comes areas where lint can accumulate. Once the lint accumulates, it begins to collect moisture. As it collects enough moisture, it will act as a sponge and collect more lint until the dryer becomes completely clogged. Left in a clogged state, the dryer begins to overheat and dries less efficiently. You may notice longer dry times or an excessively hot dryer. Eventually the dryer heating circuits will fail. This can also become a fire hazard if the lint becomes so backed up that it begins to collect on, or near, the heating element.
If you have not checked the dryer ventilation any time recently, now may be a good time to do so. I recommend checking it about once per season to ensure it is not obstructed. Make sure you are also using the semi-rigid metal type ducting. It resists crushing, kinking, resists heat better, and resists rodent infestation.
NOTE: Mice are notorious for building nests inside dryers. Give them a warm place with bedding material and they will make it a home.
Make sure the exhaust vent is at least 12 inches off the ground. This will deter mice and others pests (like snakes or birds) from entering the dryer exhaust from the outside. If you place a cover on the vent, make sure it is of the louvered variety. Do not use screens. They will collect lint and clog easily.
An easy test to determine if you have an exhaust problem is to remove the dryer vent hose from the back of the dryer. Turn the dryer on and allow it to run. The air leaving the back of the dryer should be forceful and warm. If the air flow is weak, you need to check the dryer interior. If the air flow is normal, reattach hose and run the dryer again. This time, check the exhaust vent where it exits your home. Again, the air flow should be forceful and warm. If not, you have a clog somewhere in the ventilation ducting which will require cleaning.
NOTE: If you are using plactic ducting, get rid of it. It collapses easy, rips and mice will chew right through it.
In addtion, many home owners unknowingly will push the dryer against the wall and crush the hose behind it. This will also clog the vent and make the dryer inefficient. Leave about a 1 foot space behind the dryer for proper ventilation and ensure the vent hose does not get crushed. Semi-rigid hose will prevent this from happening.
If you have any questions, please let me know. I have seen this problem many times. Let me know what you find and if I can be of further assistance. I hope this helps you.
Nov 30, 2009 | Dishwashers
My dryer is blowing lint out through the vent outside, I clean my lint trap every load, but it still sends lint outside
this is normal for lint to blown out the ducting because not all the lint will be collected on the lint filter when you remove the filter some lint may fall of down into the duct housing.there is nothing ot worry about
Sep 19, 2009 | Samsung Dryers
Dropped bleach pen into lint trap. How do I get it out?
its not too hard to get out.
you will need a #2 phillips screwdriver and or a 1/4" socket driver
remove lint trap
remove 2 screws at lint trap
unplug unilt
open the top (2 clips between lid and front panel in the crack, push them with a butter knife or putty knife to release top) opens like a hood
pull out dryer and pull off rear panel
on the left hand side there is a metal duct like thing lol
that leads to the lint trap at the top.
there should be 4 screws at the bottom where it gets round.
remove them, and wiggle the duct open. your pen should be there..
May 25, 2009 | Kenmore 62602 Electric Dryer
The drum is spinning, the heats working, not drying
Try washing both lint screens with soap and water and letting them dry.
Apr 04, 2009 | Asko T700 Electric Commercial Dryer
Is it possible that the automatic sensor can fail on a dryer.
hi, Sounds like everything mechanical and electrical is working. The sensors are located on the outbound air ducts. You may be able to improve things significantly by removing the dryer vent where it attaches to the rear (or side) of the machine, and cleaning the tube going into the machine. While you have it removed from the vent, remove the lint trap, use your vacuum crevice tool and clean the trap area. If you have the ability to blow air through the trap area, blow it through the crevice tool so that you are as far beyond the screen area as possible. Be warned that it may blow dust and lint from the vent, covering it with a piece of nylon stocking will catch most of it. The object of this whole exercise is, the exhaust air ducts collect dust and lint which collect moisture from the damp items, the sensor reacts to this so cleaning out as much of it as you can will help. Good Luck to You!
Feb 17, 2009 | Kenmore 63942 Dryer
Dryer Problem
SHUT OFF THE BREAKER to the unit then open the panel (3 Screws) that is in between the washer and Dryer you will see your venting hose ther remove the flex vent pipe from the exh duct closes Turn back on the pwr and run a load in the dryer see if it drys ok if you wil need your vent to the outside cleaned out
Jan 23, 2008 | Kenmore 88752 Top Load Stacked Washer /...
Dryers Logo
44 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
