Question about Coffee Makers & Espresso Machines
I need an instruction manual for the conair cuisine grind and brew coffee maker CCP-10FR
ThaMp3Doctor
  • 8596 Answers
SOURCE: cuisinart Grind and Brew 10
Replacement time. a certain percentage of thse have this problem. There is a small, non-replaceable tube in the inside toward the bottom that has become melted/damaged.
Posted on Dec 17, 2008
SOURCE: Leaking cuisinart grind and brew
Our Cuisinart grind and brew was leaving a puddle under it after making a pot of coffee. I called Cuisinart this week and it turns out the handle of the carafe has to be lined up in the middle of the opening for the carafe. It will be under the word Cuisinart, in the middle.
We have now made several pots with NO residual puddle of water or coffee. It also seems to be making the pots quicker.
Before trying this I had run 2 pots of water with 1/2 cup white vinegar in it also. But it still puddled until we lined up the carafe as noted above.
Posted on Jan 16, 2009
SOURCE: our coffee maker is only brewing half of the
Run a 1/2 pot of vinegar through it 2-3 times (I reuse it) and then run water 1-2 times to get the vinegar smell out. This cleans the mineral deposits from your water that are clogging it.
Posted on Dec 16, 2009
  • 9 Answers
SOURCE: Coffee maker won't start brewing process
brew light is off
Posted on Feb 08, 2010
  • 81 Answers
SOURCE: Coffee not brewing after grinding
After grinding did you hear the brew group goes up and pump start? If you hear the pump start and stopped, itis blockage in the brewunit metal screen. Just needs cleaning.
If you don't hear the pump starting, the problem is with the faulty micro switch inside the gearbox , that is behind the plate of brewunit.(service center job)
Posted on Apr 15, 2010
Need instruction manual for 10 cup Cuisinart coffee maker
You did not specify your model number but you may be able to find a manuaj for your coffee maker online here:
http://www.cuisinart.ca/cuisinart_manuals.php?cat_id=2
Jun 02, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
I need an instruction manual for the cuisinart coffee maker DGB550BCU can any one help or tell me where to get one. Thanks
There is a free downloadable manual for the DGB550xxx series of Grind and Brew coffee makers.
Here's the link with the free downloadable manual
http://www.cuisinart.com/manuals/coffee_bar.html
Hppe you find this info helpful.Best regards!
Jul 02, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
I need an instruction maual
I have a manual for the DGB550 unit if that will help. The look line maybe the same general unit. Email me if you need a copy.
Correllbil
Jun 16, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
My grind and brew turns itself off in the middle of brew cycle
Coffee overflowing onto the counter is a common complaint found in response to many automatic drip coffee makers. The following are potential solutions that can be used to rule out "operator error" vs. a defect or malfunction:
1. Do not "pack" or otherwise overfill the cone/basket with grinds.
2. If self-grinding your coffee beans, ensure you are using the correct grind setting for an automatic drip coffee maker. (See instruction manual for coffee maker and/or grinder.)
3. Do not overfill tank with water. Use the marks on the side of the reservoir as a guide rather than those defined by another measuring method. This is because a "cup" in a coffee carafe is defined as 6 oz, not 8 oz, and in some cases as little as 5 oz as a cup. As such, a 12-cup machine actually produces closer to 9 standard 8 oz cups. (See your owner's manual.)
4. Make certain the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
5. Try a permanent filter rather than a paper filter or vice versa.
6. Only use the correct permanent or paper filter (see manual).
7. Verify that the Pause 'n Serve button isn't sticking. If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.
8. It is extremely important to clean your machine with vinegar or as instructed by your owner's manual at least three times per year, more if your water supply is hard (prone to leaving water rings). A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew a pot of coffee, to produce "off" tasting coffee, or to clog and overrun the filter basket.
9. Ensure that the coffee machine is sitting level on the counter.
May 10, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
NEED oWNERS mANUAL FOR gRIND & bREW SO i CAN SET IT
if you go to this address you can download a manual...
http://safemanuals.com/user-guide-instructions-owner-manual/CUISINART/DGB-300BK-_E
if the address doesn't go just go to safemanuals.com and in drop boxes choose cuisinart/dgb-300bk. will take you to thie page.
enjoy your coffee.
Dec 02, 2008 | Cuisinart Grind and Brew DGB-300BK 10-Cup...
Don't know how to work the steamer.
I have the same Conair Cuisine Ultra expresso maker as you; its an old one. Make sure the coffee grind is in the spoon/filter cup and as the water heats it will brew the expresso. Simply twist the the knob at the top of the silver steam valve stem will let out hot steam for you to frosh the milk.
Nov 24, 2008 | Coffee Makers & Espresso Machines
Cuisinart 10 cup auto grind and brew
Here is a link for the PDF version of the Instruction Booklet for the DGB-600BCC (from the name you provided I’m assuming this is the correct product).
If it’s not the right product, check out the Cuisinart.ca website, you can select the product you are looking for and download the instruction booklet from the product page.
http://www.cuisinart.ca/en/pdf/ibs/DGB-600BCC_en.pdf
Hope that helps!
Oct 15, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart Automotic Grind & Brew Coffee Maker
http://www.cuisinart.com/manuals/index.php?item_id=34
Jun 02, 2008 | Cuisinart DGB-600 Coffee Maker
Coffee Makers & Espresso Machines Logo
527 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
