How adapt audio from 43 inch hd tv with no headphone jack to vivanco fms 2000 speakers
    Top Expert:
  • 12,223 Answers
Follow the chart troubleshooting and fix it. God bless you
No sound
  1. Check if the TV and Amplifier (if connected) is turned on and set correctly.
  2. Check if the TV, DVD player and Amplifier are connected properly.
  3. Make sure the TV, DVD player and Amplifier volume are not set to Mute.
  4. There will be no sound output during Reverse Play / Pause / Step / Slow / Search.
  5. If the DTS soundtrack is enabled in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
Posted on Oct 15, 2013
No sound on my technika 42" 3dtv
If the headphone jack socket works the audio output for the set is good, I suspect a dvd etc will also work if connected to the rear input audio and video jacks.
This does not leave too much, headphone jack dirty or defective, speakers for whatever reason are switched to off in the main menu.
the sound for the headphone socket if it is built into the set is the same audio going to the speakers.
Dec 05, 2012 | Televison & Video
Problems with headphone jack
Replace the headphone socket of the TV. It has contact fault.
Jul 12, 2012 | Vizio M260VA 26 in. HD-Ready LCD TV
Ok so 1 of my kidos has the RCA 20F420T tv, and i guess there is no headphone jack hole, so i went and bought adapter that plugs into the av jacks, still doesnt work can you please help!!!
Without knowing the specifics on this adapter - I can provide only provide some clues as to how this works.
Basically, the A/V jacks on a TV has a "fixed" audio output level - this means that the sound levels on the A/V jacks is NOT controlled by the volume control of the TV itself. You should be able to set the TV volume to minimum and then use the adapter's volume control to make the earphone / headphone sound louder and softer. Your TV however, may have a setting in the menu that can change the audio from "fixed" to "variable". If set to "variable", when turning the volume down for the TV's built in speakers will also turn the volume down on the A/V jacks as well. You do not want this to work like that as the sound in the headphones and the TV speakers will be same - instead of the TV speakers being off and the headphones on.
I hope this helps and good luck! Please rate my reply. Thanks!
May 26, 2011 | RCA 20F420T 20" TV
I have a Dynex Flat Pannel TV with a DVD player in the TV. I have it hooked up to my HD line coming into the house. My question is: Is there a way to hook speparate speakers from the TV and by-pas the...
Yes you can provided your tv-has a headphone jack. Just plug in any regular computer speakers or the like into the headphones jack and the audio output would be switched to external speakers automatically. On the contrary if your tv does not have a headphone jack then you will need to obtain a home-theatre system and connect the stereo audio out ports to the audio in of the home theatre system. They have become very affordable these days and I have seen a Philips home theatre system(2.1) starting at around 120$.
Apr 04, 2011 | Dynex Televison & Video
Can the audio be heard normally from the TV while these headphones are also being used? One person in the family is deaf and will use the headphones while the rest of the family will watch also with the...
Randy - I don't know what TV you have but in general media devices turn the internal speakers off when you plug anything into the headphone jacks. If your TV does you can probably do the following for probably around $20 (USD)
If you have a relatively new TV you could get a pair of inexpensive self powered computer speakers and a simple 3.5 mm to RCA stereo adapter. Then plug a standard red-white RCA stereo cable into the red-white stereo output jacks on the TV and the other end into the 3.5mm adapter and a 3.5" stereo cable from the adapter into the computer speakers.
Or, if the TV headphone jack is 3.5" instead of the larger 1/4" headphone type you could simply get a 3.5" stereo Y adapter and then plug the headphones into one end of the Y and the computer speakers into the other.
Either way sound for everyone.
Thanks for using Fix Ya
Mikeywaf .
Mar 17, 2011 | Audio Players & Recorders
My 26 inch Panasonic Viera TV has what looks like a headphone jack on the side of it but when I plug headphones in the sound still comes through the TV speakers. How do I get the headphones to work?
Check you USER MANUAL to make sure it is actually a headphone OUTPUT jack and not a digital INPUT jack.
If your tv does not have a headphone output jack you can always get an adapter that plugs into the red and white AUDIO OUT jacks in the back.
If you want to turn off your tv's speakers, go to the MENU.
Then go to AUDIO then select SPEAKERS OFF.
Good luck and please post back with how you make out.
Jan 24, 2011 | Panasonic Televison & Video
How to find JVC AV27320 headphone jack? I've plugged into the avs(red & white) in the front panel as well as the extra ones in the back. Altho - I CAN hear the sound thru the headphones, The external...
This model doesn't have a headphone jack. The only JVC TV in the series that does is the model AV-20D202. For the JVC AV-2732, use the RCA audio out jacks with an RCA to 3.5 mm adapter to connect to the headphones. The front audio jacks are audio in (for the audio from a video camera for example).
When you use any external speakers or headphones through the audio out jacks, make sure to turn off the TV speakers. Press Menu and navigate down to TV Speakers (up/down arrows). Then use the right/left arrows to select Off and then Exit the menu. Make sure you scroll the TV volume before doing this. Note: if your headphones do not have a volume control they are a bad choice for this type of audio output.
You can find the manual for the TV here: http://books.jvc.com/booklist.asp?Model=AV-27230 .
I wish that I had better news for you.
Jan 06, 2011 | JVC AV-27320 27" TV
If I hook up a set of headphones to the slot on the side of the TV the sound goes off and you can only hear sound through the headphones, no one else in the room can hear the TV. Is there a way to hook...
The headphone jack on the TV has switch built-in to kill the TV speakers when headphne jack is used, you need to use powered PC speakers with headphone jack and connect this PC speakers to the Audio line out of the TV set (RED and WHITE RCA audio line out). Basically the powered PC speakers are being used a headphone driver. Or you can get one of those wirless headphone system instead.
Jun 27, 2010 | Televison & Video
How do I connect external speakers
    Connecting Full-Size Speakers
  1. Step 1 Insert the red and white plugs on a set of RCA audio cables into the right and left audio "OUT" jacks on the back of the TV.
  2. Step 2 Connect the other ends of the cables to a free pair of audio "IN" jacks on the amplifier.
  3. Step 3 Strip 1/2 inch of insulation from the speaker wires, and connect a pair of wires to the left and right terminals on the back of each speaker using the red wire for the right audio connection and the other wire for the left.
  4. Step 4 Connect the other ends of the speaker wires to a pair of stereo speaker terminals on the back of the amplifier. The wires attach by raising spring-loaded clips on the back of the amp to reveal a hole for inserting each wire.
  5. Step 5 Set the amplifier selector to the set of audio jacks connected to the TV to enjoy stereo sound from the television.
  6. Connecting Self-Powered Speakers
  7. Step 1 Insert the RCA plugs on the Y adapter into the TV's Audio "OUT" jacks.
  8. Step 2 Connect the mini-plug on the wire attached to the right-hand self-powered speaker to the mini-plug jack on the Y adapter.
  9. Step 3 Plug in the audio cable and mini-plug from the left-hand speaker into the Audio "OUT" jack on the back of the right-hand speaker.
  10. Step 4 Connect the AC adapter to the power jack on the back of the right-hand speaker, then plug the adapter into an electrical outlet.
  11. Step 5 Switch on the external speakers and adjust the volume.
Jun 01, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
I was watching tv, turned the channel and the sound quit. I turned off the tv for awhile and still no sound, on any channel. Is there anything I can do to fix it or do I need to take it for repair? It is a...
the speaker may have quit working. or possibly if the t.v has a headphone jack something may be in the hole causing te=he t.v to send audio to the jack instead of the speakers. if that is not it if you do have a jack for headphones you can plug in an adapter to hook up your media to an external speaker device, the first place to look is this jack, if no sound will come through your headphones either thanyou have an internal problem
Apr 07, 2009 | Sony Televison & Video
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
