Model no.5437RU vertical line is not appearing, horizontal line is comming
  • 2,113 Answers
That means you need to replace the vertical output transistor.
Posted on Oct 16, 2013
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
What cause Vertical lines on my Toshiba TV Model 46G310U that affect the way the image is seen. Also some white bands Horizontally are appearing?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 07, 2015 | Toshiba Televison & Video
There is a line down the center of the screen
whether the line-shaped vertical or horizontal? if it appears a horizontal line on your side, it signifies the vertical rays do not exit the screen or your TV vertical part is not working. damage can be caused by IC Vertical, or in the vertical deflection coil yoke.dan if a line that appears is from top to bottom that indicates the horizontal section is not working, usually there is a problem of the deflection yoke is not connected or defective.
Jul 11, 2010 | Televison & Video
How do you set convergence
What is your Make and Model number?
Mar 18, 2010 | Televison & Video
How do you fix a white horizontal line across top of Orion TV?
Hello eatkinson,
This denotes a problem with the vertical deflection circuit. This is more then likely the result of the vertical coupling capacitor failing. You will need the schematic diagram of the TV to find the capacitor in question. it is located between the vertical output stage and the vertical deflection winding of the yoke transformer. In addition check the continuity of the vertical winding of the yoke transformer this can cause the same problem. In any event the problem is that the vertical deflection signal is not getting to the yoke transformer or the yoke transformer is malfunctioning.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Apr 08, 2009 | Orion1934 19" TV
Monitor disply movable horizontal lines.
yes you first check the supply at vertical ic 12v if present then replace that vertical ic if supply is not present then check the regulator ic in smps if faulty then replace it
Nov 20, 2008 | SAMTRON 55V 15" CRT Monitor
Verticlel lines appear when colorprinting photos
There may be multiple reasons why your pictures and printed pages have unexpected vertical or horizontal lines. To resolve this problem,
http://www.kodak.com/global/en/service/repair/troubleshooting/aio-troubleshooting.jhtml?pq-path=10355
Within the Link, select Print quality, then Unexpected vertical or horizontal lines (banding).
Nov 11, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Sony tv model no. KV - 19 APR 2
This is for a different model, but I had thin horizontal lines in red and had to adjust the tube for red. You may have a similar adjustment on your set.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Aug 01, 2008 | Sony KP-48V80 48" Rear Projection...
A horizontal or vertical red line appears on picture.
Red lines are caused by glare. Avoid photographing shiny surfaces that reflect excessive amounts of light into your lens.
Sep 13, 2005 | Epson PhotoPC 800 Digital Camera
Televison & Video Logo
Top Televison & Video Experts
