Question about Bitumastic Coatings 50-5 50 Protective Coating Compound
My 60s wooden floorboards are fixed with bitumen, can I replace a board using bitumen?
Fixing plasterboard to bricks ?
Google GORILLA CONSTRUCTION ADHESIVE
Nov 10, 2016 | Cars & Trucks
Tip
How Do You Clean a Wooden Cutting Board? Wooden cutting boards are visually so...
Wooden cutting boards are visually so much nicer than plastic and glass ones, even though some people think that they are more practical.
Wooden boards can be cleaned, you just have to put more time and effort into it.
1. First wash your boards with soap and hot water and let them drip dry upright.
2. Every few weeks or so, sprinkle coasrse (kosher) salt on the board and then rub it well with lemon that's been cut in half (ie rub the cut side on the wood).
3. Rinse well with hot water.
4. Some people use oils such as walnut or almond oil or beeswax to rub on their butcher's blocks but do'nt use olive oil as it becomes rancid.
5. If you rub oil in wipe off the excess and leave it to dry overnight.
on Dec 17, 2013 | Home
Where can I get Original Victorian Pine Floorboards? I am looking for it since 2 months.
You will get Original Victorian Pine Floorboards online at The Reclaimed Flooring Co, here you will find Original Victorian Pine Floorboards and Edwardian pine floorboards which have become increasingly difficult to source in recently years. Get them to your living room floorboard today! Original Victorian Pine Floorboards The Reclaimed Flooring Company
Dec 01, 2014 | Cars & Trucks
Why won't my millstead engineered wood floor lay flat
if it does not lay flat after 48 hours of acclimatization, return the material to the seller. Must be a bad batch.
Jun 28, 2014 | Millstead Hardwood Floor Sample: Hand...
Intermittent backlash in drive train appears to be between transfer case to front diff in 4th gear on bitumen when centre diff lock engaged no more backlash. mainly occurs when at a constant speed ie 70 to...
you shouldnt be in 4 wheel drive on bitumen you will get "bind up" of drive train which can cause damage or excessive freeplay in other components in drive train, inspect freeplay in universal joints on tailshafts, centre bearing and diff backlash specs, some backlash is quite normal, inspect trans/transfer case mounts also.
Jan 22, 2011 | 2001 Toyota Land Cruiser
How do i go about getting a replacement screen for my DGS200
This is an "oldie"...not sure, but may be same LCD as used in the D40/50s;M40/60s;I40/50/60s...if so,www.moultriefeeders.com...get my parts from other defective cams...
Jan 18, 2011 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Hi My Benq FP91G flickers with the auto syncing message around once every 60s. sometimes the power button does not work, i have to keep pressing it before it will eventually switch on. Is this worth...
Its worth fixing...
Its just an issue with the board.
If it happens to be the LCD panel, rather not fix it since its gonna cost u a fortune.
Oct 11, 2010 | BenQ FP91G+ Monitor
I just bought a 2004 pontiac grand am and it makes a lot of noise inside of the car while driving. How can I fix this problem?
add another layer of fire blanket under your floor carpet , this does mean removing all seats and any consoles that are in the way , but this does work !, you can also remove door panels and paint on bitumen sealer inside door skins this is the metal part of the inside of each door , also it has been known that some people have painted a layer of bitumen behind engine bay on the fire wall as it is called , this also cuts engin noise down , but i suggest layers of fire blanket first under floor covering then carpet over the top , softer on the feet and much quieter..
Oct 09, 2010 | 2004 Pontiac Grand Am
Dont know were is the computer of my nissan 300zx
I have a nissan truck 96 and it is under the seat. but I have worked on maximas and they are below the radio under console. so I would check under seat but more than likely you are going to have to take out console too.
Dec 22, 2008 | 1992 Nissan 300ZX
Bitumastic Coatings 50-5 50 Protective Coating Compound Logo
35 people viewed this question
Top Bitumastic Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Bitumastic Air Tool and Compressor Expert? Answer questions, earn points and help others
