Question about Brother MFC-7220 All-In-One Laser Printer
Having constant paper jams - the paper does feed and the document prints about 3/4 of the page, but crinkles up before exiting the printer, like the slit where the paper is supposed to come out after printing is closed...thanks for your assistance
  • 39 Answers
If the paper is jamming at the exit rollers, you will be need to clean the rubber on the rollers. It gets shiny and does not grip the paper to take it away.
I clean the rollers with Isopropyl Alcohol and the green kitchenhaving constant paper jams - the paper does feed - lb_icon1.png scouring pads. When the rollers are shiny they often have white/grey markings on them. Keep scrubbing until rubber is roughened up.
Posted on Oct 14, 2013
SOURCE: brother HL-2040 laser printer
brother laserjet HL2040 printer
tonner error / paper error / continued rolling
what is the problem
Posted on Jan 02, 2009
  • 39 Answers
SOURCE: Continual paper jams in rear of printer
Posted on Mar 03, 2009
  • 103 Answers
SOURCE: Printer only printing a blank page
Try to reset the printer and print the demo page
Posted on May 05, 2009
  • 13433 Answers
SOURCE: paper jam while printing on BROTHER MFC-290C all-in-one
hey
try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 03, 2009
  • 1684 Answers
SOURCE: Ghost printing
You have a worn image drum. The drum is the part of the printer that the print image is created on before it transfers the toner to the paper. This part is coated with a very thin layer of Teflon so the toner does not stick. When it gets worn the toner starts to stick and that produces the shadow or ghost image approximately 3 inches down the page because the diameter of the drum roller is 3 inches. You will need to get the part DR-350, Office Depot has them as well as many places on the internet.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
Posted on May 14, 2010
Testimonial: "I really appreciate the answer! I will go buy a new drum. Thanks again for your help! I appreciate it very much! "
I have a Samsung scx 4623fw printner. When I print one page, the machine will send 2nd page following first page causing page 1 jam at exit 2 and p2 jam on exit 1. It happens every time. Can someone h
On the document that you are trying to print, go to the very last word, of the last page.. hold the shift key down & use your down arrow to highlight anything below, no matter how long it may be highlighting white space. Hit your back arrow once. Check the last word for punctuation & spelling, resale your document & try to print again.
A lot of times in the course of 'composing', extra carriage returns or tabs or spaces, are added to the bottom of the document. I have just explained how to clear the second page printing. It may also remove the erroneous codes that may have formed.
Rebooting a printer has the same good effect as rebooting your computing device. It clears up a lot of confusion that has stacked up since the last time you did it.
If you have printed labels with this same printer, you may have part of a label throwing off the paper path. Also make sure that the paper guides in your paper bin or manual feed area are close, but not touching or pinching the paper. This can cause paper to go off of its normal print path.
Good luck.
Toby.
Aug 31, 2015 | Office Equipment & Supplies
Prints one page and jams, displays paper jam
so it does print and exit one page before it jams? if so you have something wrong with the exit sensor. if it does not feed it all the way thru it might not be feeding paper in to the machine fast enough. the feed tires might be dirty.
Sep 23, 2014 | Samsung Ml3312nd Black White Laser Printer
I have two HP2025's with the same problem, if I try to print a multi page document the 2nd page always jams... I have had both printers checked for paper pieces stuck somewhere but there is none. Total...
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Sep 05, 2011 | Office Equipment & Supplies
I have printed all odd # pages from a document, but my HP Laserjet 4 won't feed these pages back through to print on the blank side with even # pages. I've tried to keep the front (feeding edge) of papers...
You need to try a thicker paper, Heavier stock to double print the page. Slightly more expensive. Recycled paper typically will not work for this type of function. I had this same problem and found this was the only solution.
Oct 31, 2009 | HP LaserJet 4 plus Printer
HP Laserjet 4M makes accordion folds in the paper before jamming
I have found that with laser printers that have an occasional "crinkle" problem that "fanning" the paper does alleviate the problem ... but it will not if there is an actual feed/hardware problem with the rollers
Mar 13, 2009 | HP LaserJet 4M Printer
Samsung 6210 paper jam
open access(load area) check feed roller take a q tip and use rubbing alcohol and clean photo eye that detects paper be sure all jammed paper is removed
most jams are at the exit and there may be some paper obstructing that area
insert card stock through the paper path
insert ine
Dec 30, 2008 | Nikon COOLPRINT Thermal Printer
Epson R300 Constant Paper Jam
Take it apart,as fas as you can.clean out all of the paper and chips. The print 5 pages only, twice as the Epson manual says to do , in order to clean itself out.
Dec 23, 2008 | Epson Stylus Photo R300 InkJet Printer
Everytime I try to print to my PIXMA 9000 I get an error from the print spooler that the printer is not responding. THe print job starts to print, stalls after a few lines.
1. First, clean your printer. Get some spray-n-wipe cleaner and a clean cloth and clean the entire inside of the printer. Also ensure your paper isn't dirty. Now print a test page. Does the symptom persist?
2. Remove all jammed paper. Check the paper tray first. Look closely at the paper rollers nearest where the paper exits the printer; this is a common source of jams. If you’re trying to print labels, they will often jam just before exiting the printer.
3. Try to print a test page. Does the printer still jam? If you can find no source of the jamming, check the printer's message display window and refer to your user’s manual to look up the printer error code.
OR=
1. Check the printer and/or the software to see if "manual feed" is selected. If manual feed is selected, the printer may be looking for paper in another tray.
2. Reseat paper. Ensure printer is on-line. Check for paper jams or obstructions.
3. Likely suspect: paper-out sensor is damaged or broken. Consult a computer repair shop.
Sep 16, 2008 | Office Equipment & Supplies
Paper will not feed correctly, keeps jamming up.
There IS something stuck in the feed path. If the paper starts to feed and then crinkles on the feed side, there is an object stopping the paper moving forward.
Lay the machine on it's back and take a sheet of very stiff card (A5 size approx) and push it through the paper path in reverse. So start where the paper would normally exit and push the card in. You may need to lift the pinch rollers just behind the print head by hand to aid the card through. Keep the card to the side that would normally crinkle but beware of the paper sensor flag. If you force it you could break it off.
Once you get past the pinch rollers behind the print head, push a little further then start to move the card in and out but along the length of the rollers. You should find that sufficient to push out whatever is in the path and having the machine on it's back will help it fall clear of the feed mechanism.
If it does not fall out using this method you will have to remove the covers and try to remove the ASF to get at the object.
Oct 14, 2007 | Canon PIXMA MP170 All-In-One InkJet...
Brother HL-5250DN printer paper light won't go off
I had the same problem on 4 Brother HL-5250's, I checked the whole printer, and couldn't find a paper jam, yet the red printer light wouldn't shut off. I finally followed the instructions on Brother's website for removing a paper jam, and the solution for all 4 printers was paper stuck in the fuser cover. See below on how to open the fuser cover.
Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
  2. Hint
  3. There are 2 kinds of covers at the rear of the printer. Please make sure to open both the back cover (step 7) and the fuser cover (step8).
Here's the link from HP, on how to open the Fuser Cover.
http://welcome.solutions.brother.com/BSC/public/eu/eu_ot/en/faq/faq/000000/000000/000026/faq000026_007.html?reg=eu&c=eu_ot&lang=en&prod=hl5250dn_all
Oct 05, 2007 | Brother HL 5250DN Laser Printer
Brother MFC-7220 All-In-One Laser Printer Logo
136 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
