Question about Samsung RF217ACRS Bottom Freezer French Door Refrigerator
Reset ice maker
How do i make sure ice maker is on
1 month old Samsung RF28HFEDTSR. No ice in upper ice compartment. All Ice drops to bucket in freezer section. I press reset button it dings and soon one group of ice falls in upper bucket.
I believe something's wrong with your new ice maker. Are you sure that the ice maker is not turned off on the display? And take a little bit of time and go through your user manual if you don't have the user manual let me know I will send you one
http://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/1509233L.pdf
Appliance 911 Sea Breeze
Sep 02, 2016 | Samsung Refrigerators
Power surge caused appliance to go out. refrigerator ice maker now not making ice. has water on but no ice help
Reset the ice maker:
Locate the switch next to the water filter status light.
Press the light switch five times in 10 seconds or less.
Wait for the status light to change from red to green.
Mar 02, 2015 | Whirlpool Refrigerators
Samusung RFG297HDRS Ice maker not cold enough to produce ice.
Suspect that the rubber boot that runs all around the edge of your freezer door is deformed, allowing warm air to seep into your freezer. You will see where your temp sensor is located by clicking into the site of a parts supplier like ShopJimmy.com and pulling up their photo of the guts of your unit.
Oct 29, 2014 | Samsung RFG297HDRS Stainless Steel
Youtube
Ice maker is not going to harvest mode.
a) Either Ice maker is faulty. Change Ice maker.
b) Before that make sure that freezer compartment has reached minimum temparature for the ice maker to function properly. Normally it is - 11 c or lower. You have a freezer temperature like -18c and not harvesting then problem is on icemaker. Sometime you can pull the power out from ice maker unit and plug back after couple of minutes to reset the ice maker unit control board. It might work again.
Sep 04, 2014 | Whirlpool Refrigerators
The swing arm gets stuck behing the ice bucket and the drawyer won't open
Swing arm alignment can be restored by resetting the ice maker. There is a reset on the bottom, near the front of the ice maker. HOLD it down through a complete cycle, about 8 seconds, then wait for the two-tone chime to indicate the reset is complete. Failing that, a new ice maker may be needed, the old one may need thawing or there is debris under the bin or arm stopping the cycle. I have actually tore this thing off by opening the freezer at the the exact moment it was cycling too, arrrrgh.
Jul 09, 2014 | Samsung RF265AA Bottom Freezer French Door...
How long does it take to make ice on a new fridge. i have a new samsung 29 cubic ft. and no water is being put into the ice maker after 16 hrs of operation. the water dispenser works.
You should have ice by now.there should be a reset button the ice maker try and hold it till you see the ice maker advance. also make sure that ice maker is turned on.If these steps do not correct it set it up for service since it is new.
Dec 04, 2010 | Samsung RS2534 Side by Side Refrigerator
Ice maker has ice motor doen't dump the ice
Your ice-maker may need to be "hard-reset". To do this, perform a manual-defrost by emptying out the freezer (and fridge) and shutting all power off to your unit for several hours (at least half a day unless you can be sure the temp in the freezer has fully reached ambient. Next, with freezer empty, restore power, make sure the "ice" setting is set to off, then set the forced power-freeze mode (you can refill the fridge, but leave the freezer empty for now. When the power-freeze completes (at least 2.5 hours) you can refill the freezer, set the "ice" mode to block/crushed (IE something other than off) and then hit the "black reset button" to restart the ice-maker. IF it still will not dump the cubes then the ice sensor/control board may have failed.
May 24, 2010 | Samsung RS2530BSH (25 cu ft) Side by Side...
My whirlpool ice maker makes ice just fine but it does not eject the ice you have to raise up on the arm then push it back down sometimes repeating this procedure a couple of times.it is the module type...
Good day,
Make sure the wire is inserted properly. If it is, then the module is failing. You can buy the module itself but there are many other parts to an ice maker and it is not considered to be long term cost effective. Most replace the ice maker complete.
To be sure. Remove the ice maker, unscrew the module and remove. Try resetting it 2 or three times, then re-install. If there is no improvement, replace the ice maker.
Mar 03, 2010 | Whirlpool ED2FHEXN Side by Side...
Amana Side-by-Side Fridge Model SBD21VPSE Problem started when water stopped flowing from in-door dispenser and ice maker stopped making ice. I emptied fridge and freezer, left unit off for several...
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
Nov 29, 2008 | Refrigerators
Samsung Ice Maker on Mdl RB215LASH
It is quite possible the water line near the ice-maker is frozen. I would try a warm hair drier to thaw it out.
Apr 21, 2008 | Samsung RB215LASH
Samsung RF217ACRS Bottom Freezer French Door Refrigerator Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
