Standard sd350 close the plotter cover is displaying on the screen. I need help please
5 Suggested Answers
SOURCE: display screen says: door/covers open close covers of relay unit??
I believe the "relay Unit" on that machine is the section that transports copies to either the finisher (if installed) or the exit tray on the LEFT side of that machine. Sometimes neither of these units are present, but the relay unit may still be installed.
There are 2 flip up covers on that section (left and right), and you will probably see that one of them (usually the left one) has come unclipped, or perhaps the plastic clip that holds it closed is broken. If you flip up this unit. You will see a black button at the back end that is engaged when ther unit is closed. If you simply pree this button with your finger, hopefully the message will go away - this may at least help you troubleshoot what is causing the "cover open" message). Even if the clip is broken, it is often just a matter of seating the unit correctly so that the switch is engaged when the unit is closed. There is also the same switch on the right cover that could be causing the problem, but this cover doesn't sem to get damged as often.
I hope this helps. Please let me know.
Posted on May 26, 2009
SOURCE: Where is the plotter cover on the gestetner
The plotter cover is the piece that you press down when installing a new roll of masters. it is located on the top right of the machine.
Posted on May 27, 2009
nonontech
  • 4737 Answers
SOURCE: Brother MFC 7220 fax is
This error massage shows up when there's paper jam in the back of the machine. If the door is securely closed and the error persists, I would recommend you to check for jammed paper in the back of the machine. To do this, please follow this LINK and follow the step by step instructions. You'll find the detailed instructions with illustrations.
I would also suggest you to use a blower (or you can also use a vacuum cleaner). Remove the cartridge/s and drum, open both the front and the back door, and then blow through the passage from front to back or from back to front. Repeat the process several times and do this while the printer is Off or while it's turning On or after it's turned On.
You can also do some manual cleaner if the problem persists. Clean all the rollers. You'll find the instructions HERE.
Note: Both the links will open up as pdf file in your browser, if you wish to download, on the page, click the "File" just below the "Google Docs" logo and select "Download Original".
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Posted on Mar 01, 2011
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: screen displays message saying "cover
    It could be that the cover sensor is stuck or could also be due to the cartridges in the printer. Please follow the steps below on how to identify and fix the problem:
    1. Remove the sheets of paper from the feeder.
    2. Open the printer cover and remove the cartridges.
    3. Close the printer cover.
    4. Re-brick your printer by pulling out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
    5. When the printer turns on, reinsert one cartridge first.
    6. Close the printer cover and check for any errors.
    7. Reinsert the other cartridge.
    8. Replace whichever cartridge is causing the error to appear.
    9. If no error appears, reload some sheets of paper and try to print a document again to verify that problem is fixed.
    If the problem continues, please contact the Lexmark Technical Support Center for additional assistance.
    Posted on Sep 13, 2011
    System error in designjet 500 plotter error code 20:10
    The error code 20:10 does not appear to be a valid error code. The plotter may be misinterpreting the code. Try disconnecting the service station (power off). It is the bundle of green wires plugged into the small interconnect board behind the display. You will need to remove the right end cover to see it. That should generate a 21:10 error when you power up. You will need to hold down the top cover interlock. If you get the 21:10, reconnect the service station cables and disconnect the cables going to the ink supply station. When you power up you should get a 22:10 error. If either of these causes the 20:10 error, that module has a problem.
    Oct 03, 2013 | Office Equipment & Supplies
    Close carriage cover ipf8300
    I have tried to find this elusive black flap you are refering to ... are you sure we are talking about the Canon 1pf8300 44" printer?
    Aug 13, 2012 | Canon imagePROGRAF iPF8000 Printer
    I hahve hp 1020+ print not proper margine if top margin 1" print 1.2"
    SOLUTION: Follow the steps below to change the plotter's current setting.
    1. From the STATUS screen on the plotter's display, press Enter.
    2. Scroll using the up or down arrow key until Page format is shown, and press Enter.
    3. Scroll to Margins and press Enter, the current setting will display either Normal or Expand.
    4. Press Enter, then using the scrolling keys change the selection to the choice needed and press Enter.
    5. Press the Previous key until the STATUS screen appears.
    6. The plotter is now ready to plot using the selected margin setting.
    Feb 15, 2011 | HP LaserJet 1020 Printer
    Can't trun off closed caption
    Here is a link to the operating instruction manual:
    http://www.docs.sony.com/release/KV27S42.pdf
    Look at page 23 for help with the closed captioning.
    If this has helped, please give me the appropriate thumbs up! Thanks, and good luck!
    Aug 16, 2010 | Sony KV-27S42 27" TV
    My C-70 boots up with lines in it, can not see display at all. I bump the display and reboot and it works, I have checked and cleaned all cables. Don't want to get off shore and get let down.
    I recognize the problem. It mostly occurs when the plotter is exposed to moist during some days. The contactstrip which connects the computer to the screen gets moist and does not conduct in an optimal way. The result is a non readable screen with stripes,
    The solution is simple: press on the edges of the screen and the contact is re-established.And next time when you moor the ship, don't put the cover over the plotter till it is dry :-)
    Aug 01, 2010 | Raymarine C70 GPS Receiver
    A black rectangular black screen shows up but..... sony trinitron
    Check the set up. You may have closed captioning turned on which will show up as a black box if there is no closed captioning information for the selected channel. If that fails to resolve the problem, update this.
    Thanks,
    Dan
    Aug 07, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
    Black screen on EVERY input/channel
    Turn off the closed capition
    Jun 19, 2009 | JVC AV-27530 27" TV
    How do i print the usage page
    You should be able to communicate with the plotter and get a control screen, through your browser, by typing in it's ip address. (i.e. 192.168.1.xxx)
    Also, from the plotter, under utilites, you can view/print a usage report.
    Nov 23, 2008 | Office Equipment & Supplies
    Riso ks800
    e4-ink over flow. solution-clean ink sensor.
    e3-clamp motor locked. solution-use code 64
    Sep 21, 2008 | Office Equipment & Supplies
    Sep 04, 2008 | Gestetner - 5309L CopyPrinter Copier
    Computers & Internet Logo
    15 people viewed this question
    David Payne
    David Payne
