Question about Samsung DV218AG Gas Dryer
Samsung as dryer will power up but wont tumble
  • 2,113 Answers
If it powers up but the motor doesn't work then one of the 2 power wires works. Find the 30 amp double breaker and shut it off and back on to reset it
Posted on Oct 15, 2013
I have misplaced my manual. I have a Samsung Moisture Sensor dryer. the power works but the it wont tumble. Model #DV400EWHDWR/AA SERIAL # Y6915AEFB00979F. PLEASE HELP.
Samsung has the manual and a trouble-shooting guide on the product support page: http://www.samsung.com/us/support/owners/product/electric-dryers-dv400ewhd . The direct link to the manual is currently http://downloadcenter.samsung.com/content/UM/201501/20150120165209818/HUDSON_DRY_DV456_DC68-03170A-09_AA.pdf .
Usually if the drum won't tumble, the problem is with the belt, the drum rollers, bearings or shaft that the connect the drum to the motor or the motor.
Can you turn the drum by hand easily? Then look closely at the belt. Replace it if it is damaged. If the drum won't turn, disconnect the belt and check if the drum turns. If it doesn't, check the drum support rollers for wear. Replace all of the support bearings at once if any are faulty. Check the support rollers and shaft at the back of the drum for damage. If you hear a lot of noise as you turn the drum, then the bearings are possibly bad. Check that the plastic slides that stabilize the front of the drum are fine.
Finally check the motor. Replace this if it is faulty. To see a parts diagram and price lists for any parts, see http://www.appliancepartspros.com/parts-for-samsung-dv400ewhdwr-aa-0001.html . Other sites also have the parts for the dryer.
I hope this helps.
Aug 12, 2017 | Samsung Dryers
Drum not going round,burning smell when it started, when started it again it clanged really loud then stopped
belt and possible drum rollers:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Mar 16, 2011 | Samsung DV218AEW Electric Dryer
Power is on and seem to be normal, but dryer not turn
belt maybe even the door switch:
Oct 30, 2010 | Samsung 7.3 Cu. Ft. Electric Dryer
HI, MY ADMIRAL TUMBLE DRYER WILL NOT START. THERE
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Aug 28, 2010 | Dryers
Electrolux tumble dryer
Power it down and then restart. Turn breaker off
Aug 27, 2009 | Dryers
TUMBLE DRYER WONT WORK
It will most probably be the door switch which is either sticking, give the door casing latch a gentle knock with the back of a screw driver, or is just broken. Try and get to the two wires at the switch and shorting them out i.e. linking out the switch. Make sure the dryer is UNPLUGGED when you do this.
Nov 28, 2008 | Dryers
Drum wont turn on my creda t622cw tumble dryer
my tumble dryer drum wont go round
Nov 15, 2007 | Dryers
Samsung DV218AG Gas Dryer Logo
599 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
