I am trying to copying onto a CD-R disc that already has a small file on it. Using CD burning software I can not copy any more files onto disc. Why is this and how can I overcome the problem for this disc and others in the future.
Thanks
Tony
While you write on cd first time, there is a option, whether you mant to make it a multisession ( add files later ) or not.
you have to make it multisession on the first time of write.
If you did not do it, then, you can not add files after the first burning.
Hope it is clear to you. if not please comment with your question here or make a Rating if your problem is solved :D
Before you can copy files to a CD or DVD, the disc must first be prepared using a process called formatting. There are several ways to format a CD or DVD disc. Your choice of format determines which computers and other devices will be able to read the disc.
Insert a disc into your computer's CD or DVD drive.
In the dialog box that appears, click Burn files to disc.
In the Burn a disc dialog box, type a name for your new disc.
Click Show formatting options, and then click one of the following formatting options:
Live File System
Mastered
Click Next to prepare the disc.
Now you can copy files to your disc using whichever method you selected.
Many thanks for answering the question. You have answered the problem exactly which will makes it clear for when I burn CD's and DVDs in the future.
Many thanks
Tony Munroe
