Question about Sony HD Radio and Dock Docking Station, Remote Control for iPod XDR-S10HDiP
Updated iPhone with new software and now it won't play when docked to my iHome.
IHome won't play Ipad it charges but says the accessory is not supported by ipad
the best iPad accessories Best iPad Accessories July 2017 The Gadget Flow you can get are on Gadget Flow especially for home kit compatible that you are looking for.
Feb 09, 2013 | iHome Clock Clock Radio for iPhone iPod...
Iphone4 will not playing music through docking station Sony XDR-DS12IP... Iphone was working with system perfectly until sunday? still manages to charge iphone ? Iphone message iphone not configured...
first return sony and get ihome because sony is bad at docky station(not affending ps) or you can do is take it where you got it and bring the ios deviece and get it checked if it works congrauts if it doesn`t BUY IHOME.
Aug 23, 2011 | Sony HD Radio and Dock Docking Station,...
My iphone 3GS is not been charging when I dock in JBL On Time 200P and it used to charge just fine. This happened after I used in a travel a hotel iHome as my charging dock, and then a wall charger for...
It seems an issue of the dock connector of your Iphone, please check if there's no contact blocked or bended, if there's one or more contacts with these conditions, you may need to replace the dock connector of Iphone.
Feb 24, 2011 | JBL On Time Docking Station for Apple iPod...
My iPhone 3G will not respond to iHome play/pause
Just solved exactly the same problem by powering off and on the iPhone
Jan 24, 2010 | Brookstone iHome Alarm Clock Radio Remote...
The altec lansing inmotion does not charge my new ipod nano.What I can do
Maybe this could be the solution...
Source: http://www.speakerstation.co.uk/ipod-speaker-docks-ct-87.html
Important Note: iPods released since Sept 2008 (e.g. Touch 2nd Gen, 4th Gen iPod Nano and iPod Classic 120 Gigabyte, iPhone 3g and onwards) have an updated dock connector that means older revisions of speaker dock may not be able to charge these newer models of iPod/iPhone. Older docks should play music from these newer models with no problem.
The problem with charging is due to Apple removing support for 12v (firewire) charging on these new models of iPod/iPhone. Only 5v (USB) charging is supported on these new models. ..."
Oct 30, 2009 | Altec Lansing inMotion® iM500 Docking...
Doesn't play on ihome says "not compatable"
It's a new ipod, right? And your docking station must of been made before the new nano toke the stores. You need to get a new docking station.
May 26, 2009 | SDI iHome iH5 Docking Station, FM...
Ihome won't play ipod, even after resetting ipod I have de same problem. I got an itouch 2nd generation and docked it on a speaker that supports it. It worked fine for two or three hours, but suddenly it...
Welcome to the wonderful world of the iHome frying the Ipod.
Your iHome, has most likely fried the mainboard on your ipod.
to check plug a usb into the ipod and connect to the computer.
if it comes up disconnect the usb and try a headphones in the jack.
if it doesn;t play sound its fried and you will need a new mainboard.
if it does play through the headphone jack, your lucky and keep it off the dock.
I have fixed at least 30 ipods taken out by ihome docks and other docks.
they are terrible for the ipod. Even Apple sells the docks on their website
that shows how much they care about the product.
If this helps leave a vote on fixya
May 11, 2009 | Apple iPod touch
When I first got my ipod touch and my ihome I had no problems and then all of a sudden everything worked except for the ihome wouldn't play music. It charged properly and the alarm and clock worked fine just the music wouldn't play. So I assumed it was the ihome and took it back and exchanged it only to get home and have the exact same problem. So I reset my Ipod and it worked. To do it you have to hold the sleep button until the red slider appears. Slide your finger across it to turn off. Press and hold the sleep button until the apple comes on. Next I sync'ed and looke dfor an update. After all this I docked it and it worked.
Jun 30, 2008 | Audio Players & Recorders
Sony HD Radio and Dock Docking Station, Remote Control for iPod XDR-S10HDiP Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
