Spinmaster Air Hogs RC Reflex Micro Helicopter Logo
A
Anonymous Posted on Oct 14, 2013
My helicopter kyanite keeps keeps spinning and wont fly
4 Related Answers
Anonymous
  • 7 Answers
  • Posted on Feb 15, 2010
SOURCE: how do i fly my spin master air hog rc helicopter
If its a Reflex twin rotor Heli use the trim wheel on top to counteract the spin and at least stabilize the craft at hover. Then use the right/left froward backward fans to control flight, (right joystick on the controller). These fans are not very powerful so don't expect alot from them other than turning the craft right left and reverse. Seems there is too much down draft from the rotors to effectively move the Heli forward. Not a real good design. The Sharpshooter is easier to fly but uses the batteries in the controller as a charger so they don't last real long.
Anonymous
  • 4 Answers
  • Posted on Sep 08, 2010
If you trimmed your heli but it still can't work, try using the direction knob to trim it instead. When it goes clockwise push th knob leftwards and hold, and vise versa for anti-clockwise. Or, push and release repeatedly in the direction mentioned till it flies straight. Tested on around 6 air hogs helis and works each time. If you still can't trim you might try it after turning it off or contact the service centre.
robfig0214
  • 7 Answers
  • Posted on Dec 17, 2010
SOURCE: my AH-64D LONGBOW helicopter spins out of control
make sure the tail motor does not have any hair stuck in it take of the little propeller and clean it.
next adjust the trim so when your taking off so helicopter will not spin any more and your good to go
Anonymous
  • 7 Answers
  • Posted on Sep 10, 2011
SOURCE: help! my helicopter keeps wabbling
To fix: Look at the flybar and check for even flybar paddles (if looking down the flybar make sure one is not angled differently than the other) you can twist them a little to manipulate them. #2 the small extensions connecting the flybar to the links may be bent up or down. Again, looking down the flybar make sure they are pretty level with one another (you can slightly bend them back but be gentle. #3 There is a pin connecting the flybar to the head that goes through. What happens is, after a few bang into things this can start to move out just a fraction of a mm. You will notice that the flybar can move back and forth like it should very easily but there is also a little play rocking it the other way that it is not supposed to go. this amount will be very small but plenty to adversely affect the heli. take a pair of needle nose pliers and carefulle push that pin in just a touch until the flybar tightens enough to stop the movement. Be sure its not too tight so it takes away from the easy movement the flybar is supposed to have. I 100% promise its not the tail motor.
Tail rotor blade is bent and helicopter wont fly forward or backwards
Fixing Your RC Helicopter - The Basics + Tips / Tricks ...
? 3:26
https://www.youtube.com/watch?v=Gxst73zE0VY
Jan 16, 2011 - Uploaded by Live2Fly94
i have a heli and the tail rotor will spin right but not left .... im having problems with my silverlit nano copter the tail ...
Frequently Asked Questions - RC Helicopter Wiki
www.rcheliwiki.com/Frequently_Asked_Questions
Probably the best way to learn to fly is to find a group of like minded people locally and ask their advice. ... The tail rotor should rotate so that the blades come 'up' towards the front of the heli. ... My helicopter won't stop spinning! ... still flying awesome but now tail vibrate and it issues backward forward. what should i do ?
Dec 28, 2015 • Toys
Spins to left, will not take off/lift?
GYRO Nano Hercules Unbreakable 3.5CH Electric RTF RC ...
www.amazon.com/Hercules-Unbreakable.../B00AAOJ...
Amazon.com, Inc.GYRO Nano Hercules Unbreakable 3.5CH Electric RTF RC Helicopter (Color ... you can remove the 8 or so screws that allow you to pull the fairing off, remove .... Also we purchased our helicopter from HobbyTron.com through Amazon and .... won't spin, so the entire helicopter spins, and doesn't generate enough lift to fly.
GYRO Nano Hercules Unbreakable 3.5 CH Electric RTF RC
Amazon.com, Inc.Nano Hercules Unbreakable Glow in the Dark 3.5CH RC Helicopter ... It can go forward, backward, up, down, left, right and hover. .... It worked for a few flights and now the copter will not fly off the ground. ... and ive had it for a year now and everytime I start it up and it takes lift off it starts to fly backwards but otherwise ok toy.
Hercules Unbreakable 3.5CH RC Helicopter - HobbyTron.com
1helpful
I have an air hogs sharpshooter helicopter and it wont stop spinning when i try to fly it and it only gets about a foot off the ground
it could be that you just need to use the adjustment nob it is next to the right joy stick u can turn it to make the heli fly straight. or one of your blades is not working like it should.
5helpful
2answers
I crashed my Apache onto a table and when I try to fly it, It keeps spinning out of control. To my knowledge I don't see anything broken. It spins to the right. Please help! thanks!!!
It sounds like your tail rotor is acting up or missing. It keeps your Helicopter from flying in circles.
http://www.start-flying.com/new%20site/heli1.htm
3helpful
2answers
My rc helicopter wont fly high?
flew at first hit sealing won,t fly now hit the trim button,s but still wont fly
2helpful
8helpful
Helicopter keeps spinning in circles and won't lift.
There is a "trim button" on the controller. Ex: if the helicopter is spinning left, press the "R" trim button repeatedly. Takes a little practice to get it down to flying with out hitting anything. Good luck.
9helpful
3answers
Heli max hicro helicopter just keeps spinning in circles
Spinning is caused by one of the main propellers rotating faster than the other. If both propellers are secured tightly to their drive shafts, the spin control knob on the remote control can be used to stop the spin. However, if one prop is slipping with respect to the other, the spin control knob will not fix the problem.
I've found that the set screws holding the propellers to the drive shafts tend to loosen after a while. If one prop is a bit loose and the other is tight, the relative slippage will cause the helicopter to spin.
To check, turn off helicopter power and manually rotate each propeller separately, watching the nylon gears in the body. If the propeller is moving and its drive shaft gear isn't, the propeller is slipping because its set screws are not applying enough pressure on the propeller's drive shaft.
Carefully tighten the set screw and the problem should be fixed. DON'T OVERTIGHTEN, or the plastic threads for the set screw will be stripped and the propeller assembly will be ruined.
Top Spinmaster Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Spinmaster Toy Expert? Answer questions, earn points and help others
