Question about Ativa AT-P3000 Printing Calculator
How do I install the printer ribbon on an ATIVA AT-P3000 calculator?
How do you change ink on a canon p20-dh calculator
For accounting offices and stores, calculators that produce a printed paper are indispensable. Canon's desktop or commercial printing calculators use ribbon tape, and you'll need to change the ribbon when it is used up. All Canon desktop and commercial printing calculators use the same method for changing the ribbon.
  • Turn off the calculator.
  • Pull up on the tab on the far side of the printer cover to remove the cover.
  • Pinch together the ribbon lock (the arrow shows you the direction to pinch). Lift the ribbon spools off the shafts and discard them.
  • Separate the new ribbon spools. Guide the ribbon tape around the four guiding pegs and set the spools on the shafts. The spools should be peg side down.
  • Rotate the spools so the peg at the bottom of the spool goes into the hole of the spool holder. Release the ribbon locks.
  • Rotate the spools to make the ribbon taut, keeping the ribbon positioned around the guide pegs.
  • Replace the printer cover and turn the calculator on.
How to Change the Ribbon in Canon Calculator eHow
Feb 06, 2016 | Canon Office Equipment & Supplies
I was given an XL-1267 calculator, with no user manual. The ink is very faint, How do I fix this?
Unisonic Calculator Ribbon XL 1267 We supply Calculator Ribbon supplies for various calculators, as well as supplies for typewriters, cash registers, printers and dictation equipment. Can't find the calculator supplies you are looking for here? Then call us at 1-800-816-6855 or email us at pos@execuline.com We carry many of the hard to find calculator ribbons for various model printers.
Aug 16, 2010 | Unisonic Office Equipment & Supplies
How do i install the ribbon on Texas Instruments Calculator TI 5045 SVC
I could tell you, but you'll probably find it easier to follow the somewhat illustrated instructions in http://education.ti.com/downloads/guidebooks/printer/5045svc/5045svc.pdf
Jun 15, 2010 | Texas Instruments TI-5660 Calculator
Need to replace ribbon on canon mp25dv calculator
remove the printer cover, insert one spool on the left side pin, guide the ribbon though printer and inset other spool on right pin. make sure the ribbon looks like a C with the ribbon coming around the outside of each spool.
Apr 27, 2010 | Canon MP-25DV Calculator
HOW DO YOU SET DATE AND TIME ON ATIVA AT-P4000 CALCULATOR
instructions are here
http://www.ativaproducts.com/downloads/577-813_faqs.pdf
Aug 12, 2009 | Office Depot Ativa D5772 Phone
I have a Saitek P3000 gamepad, cant turn on?
i can not charge my batteries and i dont know how to turn it on
Mar 16, 2009 | Saitek (p3000) Game Pad
Ativa at-p3000 adding machine....no user manual or way to set ate and time
To set the time: Press the date/time button (next to the feed button) to make the time appear on the display. Then press and hold the "Time Set" button (the "=" button) until the first digit of the time setting begins to flash. Then just enter the current time with the keypad (3:30 is 0-3-3-0) and use the "AM-PM" key (the "x" button) to toggle am/pm. After you have the time entered, press and release the "Time Set" (=) again to set the new time.
To set the correct date: Press the date/time button (next to the feed button) to make the date appear on the display rather than the time. Then press and hold the "Time Set" button (the "=" button) until the first digit of the date begins to flash. Do the same as before to set the new date. Don't forget to press the Time Set button after you set the date or it will not record the change.
If for some reason you need to reset your calculator, turn it over and stick a pencil into the reset hole next to the battery compartment. That will reset everything.
Dec 14, 2008 | Computers & Internet
Monroe Calculator 7130 - won't print red for negative
turn it off & back on & that should fix it. the ribbon lift needs to reset.
dennis
Nov 18, 2008 | Monroe 7130 Calculator
Ativa AT-P3000 Printing Calculator Logo
159 people viewed this question
Top Ativa Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you an Ativa Office Equipment and Supply Expert? Answer questions, earn points and help others
