Question about Epson Perfection 4180 Photo Flatbed Scanner
When a white paper document is scanned the background comes out bluish.
    Problem Solver:
  • 7 Answers
Adjust your Gamma settings in the scanner software.
Posted on Oct 14, 2013
How to have white background on small documents
All areas outside of the document will be black only. I don't know how you were getting white background.
If you want white background around your scanned image, a) stick the check (in this example) onto a white paper and scan the whole sheet. Ensure double detection is off. b) You can also do this in software, by cropping a larger area outside the scanned image.
There are many options to view the scanned image like Actual size or Fit or Fit vertically or Fit width. The same image will appear different in each case.
S. Mohan, India
Jun 27, 2013 | Canon DR-5010C Scanner
Making the background of my document a color
You can't really change a setting to do that. You can change the document to have colored background, or the easiest way, buy colored paper. Why waste all that ink.
Jan 15, 2013 | Canon PIXMA iP1600 Printer
My sahara Flatbed Scanner works fine except that I cannot find how to print without a "grey:" background. What should I do to print with a clear white background? Eric Schafer. Cape Town RSA.
you will find if you reduce the dpi the scanner is scanning the pictures or documents in, that you will not get a grey background , as you describe, what it is printing is actually the paper itself, if you have it set for say 1200 dpi then reduce it to 600 dpi or even 300 dpi and you will see the difference when you print it
or only select the exact area you want to scan in the document, click preview then move the scan area selection box to exactly fit the picture you want to scan
Mar 27, 2011 | Office Equipment & Supplies
All of my copies and scans have a yellow background. This does not happen when I print a document directly.
You might be scanning and copying in full color even for regular documents. When you do this, it treats the document as a photograph or color document and therefore, the background, even if white, is scanned in as a bit yellow
Feb 28, 2011 | HP OfficeJet 7310 All-In-One InkJet...
Ricoh MP 5500 changes 8.5 x 11 documents to legal size on scan.
verify that the paper size shown on the display matches the size and direction of the paper in the respective trays, make sure paper side guides and rear backstop are tight against paper
Jan 07, 2010 | Ricoh Office Equipment & Supplies
Fi4990C
When the scanner scans the first image it will bring in via a set of solenoids a background white Reference metal flap for both rear and front cameras.
The above error comes about when the solenoids are sticking or they have magnetised themselves.
1.Clean the Solenoids.
if scanner still errors .
2. Replace solenoids.
Dec 30, 2008 | Fujitsu M4099D/FI-4990C Scanners
Background has a bluish tint instead of white
the lens , glass inside your scanner is dirty with dust you need to clean this up and calibrate once again cheers
Nov 26, 2008 | Canon CanoScan 9950F Flatbed Scanner
When scanning color document, blue tone is present as background shade
Have long experince with PixEdit program using Kodaks. PixEdit usually comes around it after a firmware upgrade on the scanner. Not sure about this specific model but at least OK on other models of Kodak.
Sep 25, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Grayblue Background on scans
A color scan will give real output as it is. If the background is grey, the output will also be grey. If you select 256 Color output, there may be small change in color, as compared to the original. If you select grey output, all colors will be converted to Grey. If these files are converted to PDF, it will be same, except in ODF format.
If you select B&W you can save the file in TIFF format. Unlike grey or color, each pixel can be either black or white only. To scan in black and white you must select right brightness. By doing os you can eliminate background (technically noise) and capture foreground(data)
S. Mohan
Oct 19, 2007 | Canon DR-1210C Scanner
When printing a scanned object, paper is all gray
Whatever scanning utility you are using, set it to Black and white, not grayscale nor colour! regards, babb
May 05, 2007 | Umax Astra 610P Flatbed Scanner
Epson Perfection 4180 Photo Flatbed Scanner Logo
79 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
