Question about GE Profile Prodigy WPSE4200A
I have an Amana washer LW8203W that was making a random screeching sound during the agitation cycle (probably 5 or 6 screeches per cycle). I changed the belt and now the sound is still random, but much more frequent. I've tried to get the agitator off to check out the drive hub, but I've been unable to get it off. I put a strap under the agitator and rock it and pull, but luck. Any suggestions as to the screeching sound or how to get the agitator off if the problem could be under there?
3 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: GE Profile WPRE6100G Top Load Washer. The hub nut loosens
You do not have a "high torque" motor (which would have required motor replacement along with these other parts).
Install a new hub washer WH2X1199, split ring WH2X1195, and hub nut WH2X1193. Inspect the hub on the inner basket for wear. If it is worn, the entire SS inner basket (WH45X10060) will also have to be replaced to prevent continued problems. If possible, tighten hub nut with torque wrench to 110 ft-lbs. I hope you did not purchase from Sears. (Sears sold machines are sold with NO FACTORY WARRANTY of any kind. For those, GE will tell you to call Sears.) If not from Sears, you may be able to get some assistance from GE customer relations if you need the inner basket. Your machine was manufactured in Nov. 06, so most likely was purchased over one year ago.
Note: If you look at the board on the top portion of the motor, you should see a LED light flashing on the right front side. It should flash about 1 second on, 1 second off (unless motor running, then .5 on, .5 off) Other flashes indicate various problems. To reset code if necessary, unplug motor for at least 15 seconds, then plug in, wait 3-5 seconds, then open and close lid 5 times within next 10 seconds.
If this does not rate a Fix-Ya for you, please don't bother rating, as I don't like to see my score drop after giving this much free advise.
Thanks.
Posted on Jan 17, 2009
SOURCE: GE topload washer occasional screeching noise during wash cycle
It sounds like it could be a brake pad that has broken and is partially rubbing against the brake frame.
Posted on Mar 07, 2009
My dishwasher is making these horrible screeching sounds during the wash cycle !! It's a stainless steel fridgdaire dishwasher about 5 yrs old
Open up the door, try spinning the cross fan to see if you can replicate the sounds if it does, check the fastener to see if it's either too loose or too tight, either of which can create such sounds.
Mar 17, 2013 | Dishwashers
My washer makes a terrible screeching sound when it starts agitating for the wash cycle. what could this be? it is a Hotpoint, model wlw2500b
Hi this sounds like the clutch assembly, this model is fairly old, you would probably be better off getting a new washer.
Sean
Mar 27, 2011 | Washing Machines
Washer makes a loud, pulsing, screeching noise with no spinning
With a manufacturing date of 7/15/97, your washing machine is clearly worn out.
Nov 07, 2017 | Whirlpool Washing Machines
Fisher Paykel Gw11, leaking, loud noise, not going through cycle
pump is a common fault and easy to change for about $25. all sound related. new machines are pretty inexpensive. your call
Aug 23, 2009 | Fisher and Paykel GWL11 Top Load Washer
A screeching sound during agitation cycle only.
sounds like a bad clutch. check the transmission out for ware and inspect the clutch as well. make sure the brake is not dragging as well.
May 22, 2009 | Maytag Washing Machines
Loud screeching noise on spin cycle
I have the same problem...during SPIN it make a LOUD SCREECHING sound.
Apr 20, 2009 | Maytag PAV2300 Top Load Washer
Mar 07, 2009 | GE WJRR4170E Top Load Washer
Whirlpool Ultimate Care II
sounds like a broken coupling.
it probably don't agitate either.
Oct 28, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
GE Model WHDSR209D2WW makes unbearable loud metal Screeching noise
ppr78, couple of things you want to check. The bottom panel on these GE's are pretty flimsy. I have run into a couple where during agitation the bottom of the motor housing would rub against the bottom panel making a terrible noise. You need to remove the front panel by pusing on the clips on the left and right side just under the top. The front panel will pull out. During agitation, take your foot and push down on the bottom panel and see if the screech goes away. I have also found the suspension rod support sockets at the top dry out and make a screeching noise. You also want to check your belt and pully and see if the noise is from there. Check these things first...Catriver..post back.
Jan 12, 2007 | GE Profile Prodigy WPSE4200A
Washing Machines Logo
52 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
