Question about LG LRSC-26922 Side by Side Refrigerator
LG LRSC 26920tt won't make ice - LG LRSC-26922 Side by Side Refrigerator
    New Friend:
In order to determine the problem you must check a few things:
1) Is there water in the ice tray? If not. verify the saddle valve is turned on, check the connection on the water valve, verify that there are no kinks in the inlet hose, and check he water filter to see if it is clogged.
2) Is the temperature correct? Make sure the fans are working properly and air is flowing. Verify the the frig and freezer are at the correct temperature and make sure the ice maker compartment door is sealing shut.
If these things check out ok, run an ice maker test. Make sure the ejector arm and feeler arm are in their original positions before beginning. If they are not:
1. Turn off icemaker and wait 5sec.
2. Turn on icemaker.
3. Wait until feeler arm and ejector are back to original positions.
To begin the icemaker test: Press and hold the test button on the icemaker for 5 seconds. If the LED, feeler arm and or ejector does not return to to their original positions the problem is with the ice maker.
The ice maker part number for your model is 5989JA0002G
Posted on Oct 14, 2013
5 Suggested Answers
SOURCE: LG LRSC 26923TT Side by Side Refrigerator Problem with ice maker
We have the same problem with the ice cube tray. Repairman said the tray must be replaced every year as continual bending warps it out of shape. Replace every year and your problem is solved.
Posted on Mar 08, 2009
  • 531 Answers
SOURCE: icemaker LG LRSC 26930SW
check water valve
Posted on Apr 03, 2009
SOURCE: icemaker will not dump the ice into tray
Make sure that an ice cude is not stuck somewhere in the maker. I had a simular problem and that was it.
Posted on May 01, 2009
  • 1891 Answers
SOURCE: I have a LG refrigerator LRSC 26925TT and I need
most ref have ice makers. but if yours does not the the ice tray can be pruchased from l g / they are there own dist and most part supply houses do not have there parts . however sear's is a good source / try there web sight and i think you can order it there . i works for me ... mm
Posted on Oct 10, 2010
I dont get ice water
check the water supply to the fridge has it begin shut off or has the water line begin pinched behind the fridge
Feb 19, 2015 | LG LRSC-26922 Side by Side Refrigerator
Where do i fill with water for ice on LG
do you have direct water feed?if so check feed
May 01, 2013 | LG LRSC-26922 Side by Side Refrigerator
How to fix LG icecube tray 3390JA115A
Hello there,
Fixing the ice cubes tray is quite simple, all you need to do is to hold the ice tray by the edge and gently slide it into the ice tray position. Pull out the drawer and place the ice tray into the freezer.
To make ice cubes, fill the ice tray to the water level and place it in the freezer.
Hope this helped. All the best Elect_Comp
Sep 22, 2011 | LG LRSC-26922 Side by Side Refrigerator
Ice maker won't work
my mum use the same kind of freezer, when it had the problem on the ice maker, we both took it to a lg service center to renew the ice maker engine
May 31, 2010 | LG LRSC-26922 Side by Side Refrigerator
LG 26930tt side by side refrigerator water leaking
Make sure the unit is not all iced up, try to defrost it and then retry, turn off the ice maker and water supply before defrosting. Put a thermoter in the freezer to check temp.
Aug 30, 2009 | LG LRSC-26930 Side by Side Refrigerator
We have a LG LRSC 26923 frig. It will make and dispense ice fine. We cannot get water to come through the dispenser. We had this problem a couple weeks ago and it looked like water had frozen up in the...
i believe there is a water filter in the fridge side as well as a storage tank. if the fridge is set too cold the tank or filter will freeze. causing blockage. Try setting fridge to 38 deg or higher for a couple of days. should melt blockage
Aug 26, 2009 | LG LRSC-26922 Side by Side Refrigerator
Icemaker will not dump the ice into tray
Apr 30, 2009 | LG LRSC-26922 Side by Side Refrigerator
LG Ice maker
You may have a broken ice maker and it needs to be replaced. You will need to have a qualified LG technician assist you.
Apr 20, 2008 | LG LRSC-26930 Side by Side Refrigerator
LG LRSC-26922 Side by Side Refrigerator Logo
353 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
