Question about Dryers
I have a similar problem. I replaced the drum belt and when putting everything back together I shorted out the door switch. It sparked but nothing seemed to have been damaged. The dryer runs fine BUT it will not automatically shut off. The dial simply continues on past the "off" position and keeps on going... forever. The cycles work the way they should.The air is just air, the heat cycle works too. The dryer keeps on running through all the cycles. The only way it stops is to open the door.
  • 50 Answers
Pretty rare but the contacts on the timer unit could have fused together.
An electrician would be useful for you
Posted on Oct 19, 2013
4 Suggested Answers
watugot
  • 290 Answers
SOURCE: Dryer won't stop running - Second try
The push-to-start switch is the easiest and cheapest to replace. You can check it by starting the machine then, unplug it, remove one of the wires from the switch, then plug dryer back up. Dryer should not start. If your model has an even heat board and two relays under the console, your problem could be with them if switch is not bad. Reply back if you need to know how to check them.
Posted on Sep 25, 2007
  • 686 Answers
SOURCE: Dryer keeps running and timer continues to move around dial.
Change your timer. It has a malfunction in it. it's about a 100 dollar fix. Also your start switch may be bad.
Posted on Mar 02, 2009
the dryer wont stop running only when open door will it start a fire?
Posted on Jun 02, 2013
How to replace belt on modle #rel4434awd dryer
Unplug machine. Remove lint filter. Remove the 2 phillips head screws under filter. Raise top by pressing in on clips with putty knife or flat screwdriver. Clips are just underneath top in front about 3-4 inches from each corner. Lean top back against wall. Unplug wires from door switch. Remove the two 5/16 inch screws holding front to cabinet. These are located in front about 3-4 inches down from top. One on each side. Lean front forward and lift up. Set front aside. Now look underneath drum and you will see belt. It goes around idler pulley and motor pulley. Study how it is on closely as you will want to install new one the same way. Flex idler pulley towards motor. This will loosen belt so it can be removed. Put everything back together in reverse order. It is easier to take apart than to put back together, so study steps you take appropriately. Hope this helps.
Oct 12, 2017 | Dryers
Replace blower belt
unplug it,open the door,remove the two phillips screws that hold the door on and remove the other two on the other side,remove the door and pull the front panel off,just tilt the top of panel out,remove the four 5/16 inch screws that hold the front bulkhead on,then remove the top screws and the L bracket on top,remove the front bulkhead,pop off the metal wire holder on the right side and stick the bulkhead on the right side of the machine so you can remove the drum,lift the top panel up a few inches and slide out the drum,you'll see the mark on the drum from the old belt,put the belt on the drum ribs down against the drum,slide the drum back in,grab the belt,put it under the belt pulley,pull the pulley over to the motor and connect the belt on the motor shaft,put the dryer back together the same way you took it apart,you'll notice two short screws,they go into the holes that have a space around the hole,one goes in the bottom and then the other opposite side up top.hope this helps.
http://www.youtube.com/watch?v=1eeJvqhHEYY
May 16, 2013 | Maytag Atlantis MDE6400AY Electric Dryer
I replaced the Drive belt and two front drum wheels put everything back together and not it goes to start but doesn't click on. Also is the drive belt supposed to sit on the drum very loosely?
the belt is not installed correctly,, some dryers have a switch that shuts the motor and heat off if the belt breaks,, if it is not on the right way it will act like the belt is broke,, double check the belt routing, it should be tight
May 05, 2011 | Dryers
Do not know hoe to get into the dryer to replace the drum belt
unplug the dryer,open the door and take out the two phillips screws holding the door on and remove the other two screws opposite the door screws.remove the door and pull the front of dryer off.now remove the two top 5/16 inch screws and metal Lbrackets,down below them you'll see i think on the right side a screw that's in a hole or in a cutout,those screws are short and the one below it is a long screw on the bottom,don't take out anymore screws than that,on the other side the long screw is on top and the short screw is on the bottom and don't take out anymore screws than that or the bulkhead will separate on you,now pull the bulkhead off and you can replace the belt,when putting it back together just remember the short screws go into the cutout holes and the long screws go in the holes without the cutout.one more thing when you put the bulkhead back on make sure the felt isn't sticking out into the drum opening,if it is use a screw driver and push the felt in with it and push up at the same time and the felt will get pushed back up and behind the drum,run your finger around the drum and you'll be able to feel if the felt is sticking out
Aug 06, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Change drier belt on model number 41794702300 Kenmore stackable
1. UNPLUG UNIT. 2. On the front of the unit, remove two screws from the bottom panel. Remove it and you will see two screws holding the top panel and door in place. 3. Remove the screws and gently pull up and out on the door panel, INSURE NOT TO PULL ON THE WIRES LEADING TO THE DOOR SWITCH. 4. Remove wires from door switch. MAKE SURE TO NOTE WHICH WIRES CONNECT TO WHICH TAB. 5. Set door aside and you will have complete access to drum. Remove old belt, if necessary, noting now it is around the drum and weaved through or around the tension bar below the drum. 6. Once removed, or if there is no belt, or a broken belt, put the new belt around the drum so that the slack hangs below the drum. NOTE: You will probably see a black mark around the drum where the belt has laid, about in the middle of the drum. Lay the belt on that path. 6A. Lay on your back with both hands available, raise drum slightly to get access to the belt. Take slack in belt, raise tension bar slightly out of the way, bring belt UNDER the pulley on tension bar and put it around the pulley/spindle on the motor. (This may take another hand) Slowly lower tension bar back down to make contact with belt, applying tension to belt. 7. Get the door panel and reconnect the door switch. 8. Start to put door panel in place, while slightly raising drum to fit into position, careful to the raise to high or **** drum out of position off the back rollers or cause belt to slip off. Push door panel into place and put screws in. 9. Once you've got the door secure, test the belt by reaching inside and manually turning the drum clockwise until it seems to turn easily with not bumps. This is allowing the belt to settle into place and insuring it is not going to pop off; if it does, repeat the operation. If it turns easily, move on to... 10. Replace lower panel. 11. Plug in unit and test to insure drum moves freely. If not, you may need to readjust the way the door panel fits in place with the drum, or the belt on the tension bar. 12. If you need further help, please let me know.
Good luck. It's simpler than it sounds. G
Aug 02, 2010 | Kenmore 77062 Gas Dryer
I replaced belt in my gas dryer, put back together, and now blows breaker when I plug it back in. I only disconnected switch on front door. It is a Maytag model #LDG8304AAE.
WHEN YOU REPLACED THE BELT CHECK TO SEE IF YOU MAY HAVED KNOCKED A WIRE OFF UNDERNEITH THE DRUM THEY DON'T LEAVE A LOT OF ROOM FOR BELT REPLACEMENT AND THIS HAPPENS ALOT
Aug 08, 2009 | Dryers
Need help with installing belt in Maytag Electric dryer
if not able to remove rear panel,you will need to start,like most models,take top cover off and hinge back to wall then remove frt cover including door as a whole assy. lift up drum put new belt on drum ( and position in same area as old belt,it will have marks on drum from where original belt was on drum) then put rest of belt over mtr pulley and then idler pulley, turn drum by hand to align belts and put it back together in reverse order
Jul 28, 2009 | Maytag PYE2300AY Electric Dryer
Belt broken on LEC8858Eq0 need instructions on how to replace belt and pulley.
To open the dryer, remove screws under the lint filter door/ handle. Pull top towards you and lift on front, top should pop up and rotate back. There will be two sheet metal screws one on either side of the front door panel, remove them and pull front out and clear of the drum, an extra hand can really help with this. Lift on t he door panel and either disconnect the door switch connector or just turn it out of the way. Look under the drum, if the idler pulley does not have a roller on it, you should replace it. If it does have a roller, check for signs of wear and seizing, only then should that one be replaced. While you're in there it is always a good idea to clean out the lint and check the drum rollers. When putting back together, the drum may cause a problem seating on the front door seal. you may need to rotate the drum back and forth to work it into position.
Jun 19, 2009 | Whirlpool Dryers
The belt on my kenmore series 70 dryer is broken how do I repair it?
remove the 2 lint screen screws,pull the top toward you and up,disconnect the door switch,remove the 2 front top screws on the front panel,pull off front,remove old belt,put new belt with the ribbed side on drum,loop it around the pulley and motor under the drum,put back together,your done,good job-mike
Jun 17, 2009 | Kenmore 63942 Dryer
Drum does not turn
THE BELT HAS BROKEN,TO REPLACE REMOVE THE 2 LINT SCREEN SCREWS,PULL THE TOP TOWARD YOU AND UP,REMOVE THE 2 SCREWS FROM THE TOP FRONT PANEL ONE ON EACH SIDE,REMOVE THE DOOR SWITCH WIRES,PULL THE FRONT UP AND OFF,PUT THE NEW BELT AROUND THE DRUM AND UNDER THE DRUM PULLEY AND ONTO THE MOTOR PULLEY,PUT ALL BACK TOGETHER,YOU CAN GET THE MODEL NUMBER FROM INSIDE THE DRYER DOOR,GO TO YOUR LOCAL APPLIANCE PARTS STORE TO GET A BELT,OR GET IT FROM SEARS .COM
Mar 08, 2009 | Kenmore 63942 Dryer
Dryers Logo
69 people viewed this question
Top Dryers Experts
