Question about Coffee Makers & Espresso Machines
When I brewed coffee from my Keurig mini k10 brewer, the coffee came out of the center and the side (spilling coffee into the drip pan) but the resevior was not overfilled and the coffee was not finished brewing when the machine was finished.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 32 Answers
Sometimes things can build up on the inside of the machine, even though you may have only had it for a short period of time. You should try cleaning it to make sure nothing is clogged in the filters.
Posted on Oct 14, 2013
4 Suggested Answers
SOURCE: Keurig B50 Ultra brewer
This is a known problem with the B50 which Keurig will acknowledge if you press them hard. Some users have suggested trying to clean the check valve just inside the water outlet but the best solution is probably to call customer support, complain like crazy, and take the discount on a new machine that they will offer you. Apparently, this problem occurs much more often with the B50 than with more recent models, which may explain why it isn't on the market anymore.
Posted on Jan 23, 2008
  • 25 Answers
SOURCE: Keurig starts & stops without brewing coffee, just descaled
The pic is clogged with coffee or the air bladder is bad. Use the tool on the underside of the tray to clean out pic. If that doesn't work, the bladder will be bad.
Posted on May 14, 2009
  • 464 Answers
SOURCE: My Cuisinart 10 cup Grind & Brew does not
you need to run a few pots of straight white vinegar through the machine to clean out the lime build up in the tubes. the first time you do it, after it starts to pump the water, shut it off for a few hours and let the vinegar sit in the tubes. after doing this run a few pots of cold water through before making coffee.
Posted on Nov 08, 2009
Keurig K10 water spills out top and sides while brewing
Check to make sure the rubber gasket is still on the water output in the brew head. It goes around the water output needle in the top of the brew head. Without that gasket, there is no seal on the top of the k-cup and water can leak. Run it with no K-cup in it and see of water does not leak this way. If it doesn't leak then it points to a missing seal. Hope this works for you.
Mar 22, 2014 | Keurig Coffee Makers & Espresso Machines
My K10 mini keeps shutting itself off
It is normal for a Keurig mini to shut itself off after 90 seconds of inactivity. Reference page 17 of the manual.
https://www.greenmountaincoffee.com/~/media/B2C/Files/Keurig%20Brewer%20Manuals/B31MiniPlus_manual.ashx
Feb 19, 2014 | Keurig K10 Mini Plus Single-Cup Coffee...
How do I get a manual for a Keurig K10 mini?
You go to the Keurig website:
http://www.keurigtroubleshooting.com/keurig_user_manuals.html
Jan 03, 2014 | Keurig K10 Mini Plus Single-Cup Coffee...
The water heats up fine, but then the coffee does not brew. This will be my 3rd mini Keurig in the last year.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Sep 13, 2011 | Keurig B30 Mini Coffee Maker
My Keurig b30 doesn't brew and squirts hot water instead
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Nov 15, 2010 | Keurig B30 Mini Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
