Question about Sewing Machines
Bobbin wont feed
Bobbin thread wont catch upper thread at all. Wont sew anything. Bobbin wont feed.
  • j29j61 May 05, 2009
    Tried all that and even gave it a good clean. Thanks for the solution though.
  • Anonymous Mar 18, 2014
    my bobbin thread wont feed through . the sewing needle is not catching the bobbin thread
  • 111 Answers
A. needle in backwards
or
b. needle threaded wrong
Posted on May 04, 2009
My bottom thread wont pull out once the cover is closed and the thread is pulled through and ready to sew.
If the top thread is not pulling up the bobbin thread, is it actually catching the bobbin thread? If not, then the machine may be out of time. Search for sewing machine timing or take it for service.
If it catches the bobbin thread but then the bobbin thread is difficult to pull, then possibly there is a snag somewhere that is catching the bobbin thread, the bobbin tension needs adjustment, or the bobbin case is incorrectly threaded.
Nov 01, 2017 | Sewing Machines
Wont sew thread keeps coming out of needle
you have to hold the loose end for a couple stitches when starting off
Dec 16, 2015 | Sewing Machines
Brand new sewing machine wont stitch. Any ideas?!?!
I'm sure you've done this, but I'll just throw this out there. Did you pull the bobbin thread through the groove that slants on the left side of the needle plate starting from the upper left corner of the bobbin cover?
Feb 24, 2015 | Singer 8763 Curvy
Big loops under the needle plate. The bobbin case is pulled towards the needle and lifted up in the front.
OK, Nylon thread and vinyl fabric are difficult. Try this:
1. Be sure your machine is *very* clean - no leftovers from previous projects.
2. Take the bobbin receiver out (need a screwdriver to hold the release), clean it and all around it and re-insert. When you re-insert in this machine, hold the release lever with the screwdriver, push the receiver away from you (under the feed dogs) then bring it back toward you so it catches before you release the catch.
3. Use a stitch length just a bit longer than you 'normally' would - 3+ for vinyl.
4. Wind your nylon thread onto a bobbin *very* carefully. It's easy to get it caught so that it won't feed evenly.
5. Be sure your upper thread is in properly, and that it doesn't catch on anything.
6. Adjust your upper tension tighter than 'normal' to accomodate the slippery thread your're using - do this a little at a time, it's easy to miss the 'sweet spot' if you adjust too much.
7. Be sure to bring up your bobbin thread and hold both threads as you start to sew - hold them for 3-4 stitches.
8. Sew slow - this machine can go *really* fast, but don't let it on this project. It will catch better if you take it slow and easy.
Hope all this helps. If not, you'd probably better take it in for service.
Aug 29, 2012 | Singer CG590 Mechanical Sewing Machine
Upper thread will not catch the bobbin thread
make sure to use every thread guide
try a new needle
make sure the bobbin is inserted correctly
if these suggestions don't help & if the machine is still under warrenty take it back & let them check it
Mar 20, 2012 | Singer Sewing Machines
My bobbin wont engage with the stich. it just keeps getting jammed up. i lost the manuel i have no idea what to set the tension.
Try these solutions
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin. There could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
* When you start to sew a seam, Hold the upper and bobbin thread tails back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
I hope this helps.
Dec 24, 2009 | Sewing Machines
Bobbin holder keeps catchin thread
Try re-threading, make sure the presser lifer is up so the tension discs are open and the thread will go into them. It sounds like you may have missed either the upper tension discs or the take up lever.
A drop of oil on the hook wouldn't hurt if you haven't oiled in awhile.
good luck!
Jan 28, 2009 | Brother LS-2125 Mechanical Sewing Machine
Not picking up the Bobbin thread
Sounds like you have to take off the throat plate and clean out threads under it.  Sometime they ball up and prevent the needle from going down and catching the bobbin thread. You can't see themuntil you take off the plate.  Follow the directions.  It is easy.
Dec 28, 2008 | Baby Lock Ellure
Brother 3022 Mechanical Problem
Make sure your needle is in correctly. Check your threading again. If that does not work, remove throat plate, install new needle, turn hand wheel until needle is at its lowest position and observe if the hook is exactly behind the eye of the needle. If that is correct then you do not have threaded correctly. If it is not then the machine needs to be re-timed.
Oct 09, 2007 | White Sewing 2037 Mechanical Sewing...
Bobbin thread won't catch
I've just had this exact problem with my model 2037. The problem, according to 3 shops I've taken mine to, is that the shuttle hook (the metal piece that the bobbin sits in) is broken and needs replaced. Problem is, the piece is next to impossible to find.
Jan 14, 2007 | White Sewing 2037 Mechanical Sewing...
Sewing Machines Logo
411 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
