Question about Coleman Powermate Powermate 5000W Generator
UST 5500 GENERARATOR. WHICH WAY IS THE CHOKE POSITION?
    Master:
  • 452 Answers
Im not sure but easy to check remove tube from filter to carb and check visualy, wilst oppertating it
Posted on Oct 15, 2013
Why does troybilt generator engine keeps shutting off when throttle is moved from choke to run position?
Give it a shot of starting fluid. If it runs initially, then most likely the jets on the carbureator are clogged. You should remove the carb and clean/rebuild it.
Sep 05, 2014 | Briggs Stratton Portable Generator 305cc...
When I start my generator it just lugs and shakes and will not get going. I have a UST 2300w generator modle GG2300. thanks jeffery
OK, you have a hard to find info on model. My first thought is that your choke is still on.
Does it have a manually activated choke? If so you know what to do, after she kicks, turn it off.
If it is one of the new Auto-choke units you may need to find the choke linkage and disengage
it that way. I have asked for a manual for your from UTS. We will see what they send, or dont!
As with all engines, if left in storage for long periods of time, use fuel stabilizer and try and start
the engine every 30 days and let it run for 10-15 minutes just to warm up and keep everything moving.
Mar 29, 2011 | UST GG2300 Portable Gas Powered Generator
ONAN GENERATOR STARTS THEN ONLY RUNS WITH CHOKE ON
This sounds like a problem with fuel settings or dirt in the jet.
If you can find the carb adjustment screws, with it runing on full choke - screw it in fully untill it stalls, then back out to original position, then restart.
Take off choke and adjust setting untill it runs well when warm with choke fully out.
You can then try and make it run leaner without stalling.
Feb 07, 2010 | Watts Onan Portable Generator - 4000 ,...
Coleman Powermate 5500 runs rough
vent in gas cap.
fuel filter.
dirt or gum in the carb.???
Dec 26, 2008 | Coleman Powermate Powermate 5000W...
Runs rough when choke pushed all the way to run position
Where can i obtain a manual for the 5500 gas generator
5500 gas generator
Recently purchased UST 5500 from Pep Boys. Had same problem during engine break in period. Found that the carb will not draw gas when generator is on level surface. Mine has the wheel kit and it causes the fuel inlet to be at highest point in tank. If you block up the wheels and change the angle of the tank it will improve fuel line pickup. Also check gap on plug, mine was way off from factory. Also check the routing of the spark plug wire and make sure it is not getting forced off the plug by tension from breather hose. Once the engine starts make sure to push choke back in, it will run for a good while choked but it will eventually shut off if you don't push choke back in. Hope this helps. Took me awhile to discover the fuel feed issue.
Sep 22, 2008 | Welding Tools
Coleman Powermate Powermate 5000W Generator Logo
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
