Question about Amana PTH123B25AJ Heat Pump Air Conditioner
I have a ptac that's just over a year old. Just recently started having a problem with the cold air. Cold air shuts off after a short time, with the fan continuing to run (doesn't matter how low I set the temperature). I can get it to cycle back on by disconnecting the thermostat wire from the front of the control board, and reconnecting it. The first time I tried this the unit seemed to work fine for a few days. Now, when using this method, it will work for only a short period.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 101 Answers
SENSORS
Posted on Nov 11, 2013
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
  • 53 Answers
This means there is a fault in relay section in PCB or might be loose connection in connector. Pls reconnect the connector again and tight that connector with cable tie and any tape then see , if it works then fine if not means problem in contractor. Just clean that
Posted on Oct 16, 2013
5 Suggested Answers
oscarn
  • 109 Answers
SOURCE: ptac fan keeps blowing
Try setting the fan control to "AUTO" this will cause it to cut out with the compressor.
Posted on Sep 07, 2007
SOURCE: I am renting a house which has a Trane heat pump
If it is a heat pump it may not have enough oomph.
Posted on Oct 20, 2009
espressonist
  • 1711 Answers
SOURCE: Air conditioning unit Amana Asx130361AA comes on,
You have probably a compressor start capacitor or relay damage and you have to replace first capacitor and if problem insist then go to the relay. If the problem insist then you have a complete compressor failure. Often when this happens the compressor will "lock up" or not be able to turn when power is supplied to it. Overheating or lack of lubrication are usually the main causes of compressor failure. Overheating can be caused by the outdoor coil around the compressor getting clogged with dirt, leaves, or grass. Loss of the refrigerant charge will also cause the compressor to overheat. It is the cool return gas coming back to the compressor that helps to keep it from overheating.
As you can see there are many things that can go wrong with an air conditioner and I have not come close to exhausting the possibilities here. I have just touched on the most common problems in a very basic way.
There are some basic trouble shooting things that can be done very easily. Most problems are above out of the range of comfort for many homeowners and professional help should be consulted before any attempt is made at repairs. Remember also, that the release of refrigerant gases into the atmosphere is a federal offense in the
US. Proper care must always be taken to minimize the release of any gases. A license is also required to handle refrigerants. Make sure that the professional you call has the proper certifications to handle refrigerants properly
Posted on Aug 31, 2010
  • 3 Answers
SOURCE: Amana PTAC
I know this is late but I had to add a solution to this problem since I had the exact same problem and was able to solve it. The probelm is not your control board. On these units, the heat pump compressor will not kick in unless the temperature you set on the control panel is within 2-1/4 degrees (or 4 degrees depending on your unit model. Otherwise, the unit locks out the compressor until the electric heat coil bring the indoor temperature up to that level - and then will switch the compressor back on for heat pump operation. So the problem is not the control panel or the compressor, it the electric heat coil. The coil has two manual limit switches on it that may be tripped and should be checked. The coil can be easily accessed by shutting down the power, removing 4 screws around the air outlet, pushing the screen up and sliding the panel out the top. The power wires can remain in place while the limit switches are reset. Hope it works.
Posted on Nov 06, 2011
Amana Wall unit blows cold air before heating
the unit works by chilling air and the byproduct is heat in the compressor, this is used for heating in the winter and then reversed in summer to blow cold air. It has to blow cold and warm up before it can blow heat.
Mar 17, 2017 | Amana Heating & Cooling
PTAC is not blowing cold air.
bad switch, bad motor capacitor, bad motor.
Jul 27, 2015 | Amana PTH093E35AXXX
Briggs stratton repair manuals
Could have something to do with the oil dispensor. I have to prime mine about 5-6 times before mine will start.
Aug 09, 2014 | Garden
Ihave 50 ge ptac units that only the middle of evap.is getting cold
short of gas. Check for leak and arrest it. Then vacum and do gas charging.
Aug 18, 2012 | GE Zoneline In Wall Ptac Unit Air...
I have a 5 year old heat pump (electric) Home is 5 years old and is very energy efficient with 6 inch outside walls. Do I have a problem as the air will run for 5 minutes and shut off for 5 minutes and...
One thing you might check is to make sure there is not cold air blowing across the thermostat from one of the vents. I've seen this many times make the thermostat short cycle.
Some less expensive thermostats may be programmed to short cycle. If you have instructions available for the thermostat, try to find information or the "heat anticipator". It may have an adjustable setting.
Jun 30, 2011 | Heating & Cooling
Amana ptac
you have the white wire on the wrong terminal put it on the same terminal as the red wire on the capacitor and you should be fine,
Dec 27, 2008 | Amana PTH123B25AJ Heat Pump Air...
Amana PTH123B25AJ Heat Pump Air Conditioner Logo
52 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
