Question about Senco & Frame Pro 601 Framing Nailer
Fires 2 nails back to back - Senco & Frame Pro 601 Framing Nailer
    Scholar:
  • 70 Answers
Hi Ray,
2 Quick questions.
1. When you say that the nails are firing in pairs, are you "Bump Firing" the tool? (That's to say you hold the trigger down and then bump the tool onto the timber)
2. Is this a method that you're well used to doing?
Posted on Oct 15, 2013
Hitachi nail gun
If gun firing but nails not being driven could be one of two basic problems:
1. Nail jammed in magazine not allowing nails to move up.
Empty magazine, does follower move to top of magazine. Push gun against work piece, does fan motor start? Yes - jam in magazine or lock out bar not operating. (this would allow nail un to fire when out of nails)
2. Piston/driver not returning fully after firing, hence driver blade on top of next nail instead of behind it. This could again be caused by a jammed nail or just a nail head. Another case of not returning is the combustion chamber not making a good seal, check O rings on framer (they are steel rings on bradders) it may just need a good clean it is surprising how dirty they can get and if not cleaned a build up of dirt could break a seal. If not been cleaned for a long time worth checking piston rings, worst case scenario dirt builds up around the rings and stick fully in requiring new piston if the rings will not come out.
Nail guns work on the principle that an explosion pushes the piston driver forcing a nail into the work piece, after the explosion a vacuum is created and it is this that 'sucks' the piston/driver back up the cylinder.
Mar 27, 2014 | Tools & Hardware - Others
Arrow fastener 2 in. brad nail gun has stopped shooting nails
make sure nails are loaded into the gun straight and correctly
Mar 26, 2013 | Arrow Fastener 2" Red Electric Brad Nail...
My bostitch bt1855 nail gun worked fine, until it started to dry fire 2inch nails. No problem with firing quarter inch nails. Any ideas?
Have you serviced it recently? and is the gas in date? The pistons do dry out and have to be oiled with special oil.
Dec 24, 2012 | Stanley Bostitch Nail Gun
The nail gun TNT tools and tasks model 15205 seems to be jammed but we can't figure out how to get the tip open to take the nail out. Please help.
I HAVE A TNT BRAID NAILER AND IT GOT JAMMED BUT I REMOVED THE JAMMED NAILS AND AFTER PUTTING IT BACK TOGETHER IT FIRED THE FIRST NAIL AND STOPPED FIRING IT FIRES BUT NOTHING **** OUT I DONT THINK THE DRIVER ISN'T PULLING BACK FAR ENOUGH TO LOAD THE NEXT NAIL.
Jul 24, 2011 | Sears TNT 3 gal Air Compressor with 2 in...
Gun fires mor than one nail at a time porter cable model da 250a 15 ga. finish nailer
There are two issues that people have with nailers that sound the same however are totally different. Firing more that one nail at a time can be taken as; two nails being driven with one fire or the nailer vary rapidly firing a second time almost instantly after firing the first nail and each time only drive one nail. Problem of double fire (either type) is very common with nailers (the gun very quickly fires twice), however two nails at once can only happen if the wrong gauge nails are used in the gun. A 15 g nailer can very easily pass two 18 g nails or, with more difficulty, pass two 16g nails. To help prevent the driver blade from hitting two nail heads at once, most drivers are slightly tapered at the tip so that the driver will hit the first nail and the tapered part will push the other nails back into the rails slightly. Remove the head of the nailer and pull out the driver. Measure or compare the thickness of the driver to the thickness of the nail head. If you are sure that you are using 15 gauge nails, check the driver for taper. The tapered part should face the rails. If not tapered, try carefully grinding a taper keeping the tip cool so that you do not effect the hardness. You could also check for other brands of 15 g nails with slightly more spacing between the nails. There is a big difference in quality among brands of nails. Good luck with your repair
Jun 01, 2011 | Porter Cable FactoryReconditioned DA250BR...
My hitachi nr 90 gc nailer was always slow to fire a nail with about a second delay between pulling the trigger and firing the nail. now however the gun will only fire a nail once in about 20 attempts, and...
Trigger may be dirty, as an electrical switch the contacts can be intermittent. Also check to see if the safety plunger is set to correct depth and moving freely. Dirt can build up here......
Feb 14, 2010 | Hitachi NR90GC 3 1/2" Gas Powered Clipped...
Cambell-hausfeld framer
its double firing, after firing gun pull back, what is happening is when you fire a nail your pushing the gun back onto the wood and its putting another nail in
May 08, 2009 | Campbell Hausfeld 2" 18GA Brad Nailer
Paslode im350
Stuart - this sounds like an air problem - you should perform the following test. With the air nailer close to the compressor you must monitor the airpressure after the gun fires. it sounds like the air is not gettting through diapram fast enough or there is a blockage in line. Blockage in line is not suspected for the following reason . It sounds like the air hose is holding enough air to fire 2-4 nails and then you must wait for the line to fill up again and then it fires ok. The pressure regulator out to the line controls this and they do fail. try this test and report back to me - I know I can solve this for you as I have extensive background in compressor and the like.
Oct 22, 2008 | Itw Devilbiss Itw Paslode Cnp 65Y Coil...
Senco &  Frame Pro 601 Framing Nailer  Logo
157 people viewed this question
Top Senco Tools & Hardware - Others Experts
John Trevino
yoopertech
John Bowen
Are you a Senco Tool and Hardware - Other Expert? Answer questions, earn points and help others
