Question about Kenmore 63263 Microwave Oven
Quit working Kenmore Elite Model No 721.66469500
Not realy...Kenmore Elite microwave runs 3 seconds then stops. All other functions work ok. Model 790.80363310
Not familiar with That Kenmore elite model. But with the symptoms I would bet your unit may have an inverter, which is the power source for the part that puts out the microwave energy the Magnetron to run, If that is the case it could be a bad inverter AND a bad magnetron. If the unit isn't anything really special to you I would recommend replacing it as the repair will be quite expensive
Nov 01, 2017 | Microwave Ovens
How Many cubic feet in a elite?
This is a 2.0 cu ft model. link to user manual:
http://kitchen.manualsonline.com/manuals/mfg/kenmore/721_7920.html?p=1
Sep 09, 2014 | Kenmore Elite Microwave, Model...
Kenmore Elite Microwave oven 63792 doesn't heat - all lights, turntable, fan, etc. work just fine.
Most likely it would be a bad magnetron since the light, turntable, and vent fan are running.
Sep 10, 2013 | Kenmore Elite Microwave, Model...
Hi, i own a kenmore elite speedcook oven model 363.63692301, ever since my wife used the convection speedcook oven and had the heat setting set to the maximum temp of 450 degrees which the oven should...
I have had issues with my Kenmore Elite conv oven too. I have had several service calls and found out that the TCU (thermal cooling unit) sensor was not working. This allows the oven to cool down so it doesnt overheat the sensors in the display. I actually had to have the oven replaced after 4 months of use. I am currently waiting for a technician to review the replacement oven for the same issue. I spent $7k on all new Elite appliances and will never purchase Kenmore appliances again. Good luck
Nov 30, 2010 | Kenmore Microwave Ovens
Our Kenmore microwave started emitting odors and then quit
To figure out what is wrong with it, it will have to be removed from the wall, Then the top cover will have to be removed, then you can look for any swelled capacitors, burn marks on the circuit board or any shorted wires.
The power supply is most likely faulty . You can test the power with a voltmeter from power supply to main circuit board.
Oct 28, 2009 | Microwave Ovens
My Kenmore Elite Microwave Model No. 721.64683300 does not seem to be heating well and will shut off and flash an F9 code. What does the F9 code mean
Oct 07, 2009 | Kenmore Microwave Ovens
Kenmore Elite microwave Combi funtion not working
Unplug the unit for 1 minute to clear the ECU.
re-plug, and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 29, 2009 | Kenmore 62622 Microwave Oven
Kenmore elite microwave oven displays "Locked" and will not respond
My Kenmore Elite microwave (don't have the model number in front of me) also mysteriously locked its own keypad (we were sitting in an adjacent room, heard a strange beep, and got up to find the LED reading "Locked."). I pressed and held down the Stop/Clear button for ~10 seconds and it returned to normal.
Mar 01, 2008 | Kenmore 62622 Microwave Oven
Kenmore 63263 Microwave Oven Logo
79 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
