Question about 2006 Focus Tailgate/Trunk Lid uk73594m Hatchback 5 door, heated glass, Without spoiler; Coupe 3 door, heated glass, Without spoiler Orlando, Florida
Have changed the bulb on the left hand indicator but still not working ( ford focus)
  • Ford Master
  • 655 Answers
1. Remove the bulb and check to make sure the brass contacts are not corroded (green color/white).
2. You MAY have got a bad replacement bulb. Happened to me at AutoZone...
3. Your next step would be to get a circuit tester (or borrow one from the parts store) and see if you have current at the bulb receptacle.
Beyond that, it is probably a broken wire or connection somewhere in the vehicle. To trace it takes some skill and special equipment. It should be an easy fix but sometimes life deals you a lemon...
Posted on Oct 14, 2013
Hi got ford focus 2001 1.6 now for the problem the left hand rear back light wont come on at all stop light on it works fine any ideas pls could it be the bulb holder tried changing bulb but still no
Are you certain that the correct bulb was installed? You need to look the bulb number up on a chart for the vehicle. Your bulb should have 2 nubs on the base if it's a dual function bulb.
And how exactly did you check the wiring? If you did a visual inspection only and not test it with a voltmeter, then have a mechanic have a look at it. That won't cost much at all.
Feb 08, 2015 | Ford Cars & Trucks
Front left indicator not working.
changing front indicator bulb ford focus 02
Feb 11, 2013 | 2004 Ford Focus
My son has a 2003 Focus 1.8 tdci left hand drive because he lives in France. The right hand rear light is not working; but the bulb is OK. Any ideas I could help him with?
Not many electrical problems with the Focus...:) Depending on the climate He lives in...many times the bulb socket will become contaminated with corrosion...best try would be to clean out the socket and wipe dry...then use bulb lubricant when putting bulb back in socket...try wiggling bulb in the socket...this will confirm the problem...most sockets are cleanable...but can be replaced...:)
Dec 15, 2010 | Ford Focus Cars & Trucks
FUSE BOX LAYOUT ON A 2007 FORD FOCUS
My headlights keeping blowing in my 2007 ford focus sport, i am using a 12v 55w bulb, the right hand side light went out first then then left hand side went out a week later, can anyone help me?
Sep 22, 2009 | 2007 Ford Focus (3 Door) Hatchback
Driver's side headlights don't work, although indicators do!
The most common fault is ground use a test light at the plug it should show you what is missing. Most garages should be able to hande it in about an hour.
Aug 02, 2009 | 2000 Ford Focus
Towbar wiring
i wiried up my focus estate with the following no relays needed as the wiring is protected by the car fuses
pin 1.yellow/left hand indicator
pin 2.blue fog light
pin 3.white/earth
pin 4.right hand indicator
pin 5.brown/right hand tail light
pin 6.red/ brake lights
pin 7. black left hand tail light
connect these to the car wiring with scotch locks as follows/red/blue.right hand indicator/blue.left hand indicator,green/black,left hand indicator,red/green,right hand indicator,orange right hand light,orange and white,left hand lights, finally green/yellow fog light
hope this is of use to you all my lights are working and correct
May 09, 2009 | 2000 Ford Focus
My left indicator on all the near side are out on ford focus
It may be that the actual indicator switch is faulty
Apr 11, 2009 | 2000 Ford Focus
Please help me find out how the change a blinker bulb
hi this will be easy if you have slender hands ? open the hood then put your hand down towards the rear of headlamp assy then to the location of indicator area you will feel/see a socket with wires attached this is the bulb holder for f/bulb now hold the holder and twist to left this unlocks holder and you can pull out holder and attached bulb renew bulb this is unplugged in the same way ? and pushed/locked in also then refit bulb holder into lamp assy and check it works? hope this is clear to follow?
Mar 25, 2009 | 2006 Ford Focus
Ford focus
only one light not working indicates a bad circuit at the plug on the back of the light housing or in the wiring between the light and the dash swith
Sep 18, 2008 | 2001 Ford Focus
2006 Focus Tailgate/Trunk Lid uk73594m Hatchback 5 door, heated glass, Without spoiler; Coupe 3 door, heated glass, Without spoiler Orlando, Florida Logo
109 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
