Question about Ovens
Lamona induction hob displays F5 error code all the time
5 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Is this oven suitable to have a Induction Hob
Provided there is a space between the top of the oven and the hob, it should present no problem.
You will of course need a seperate plug outlet for hob
Posted on May 21, 2010
  • 417 Answers
SOURCE: hello. I have a new hotpoint CIO644 induction hob
Hi
I'm not sure that you really have a problem as with induction hobs you need to put your pan (metal only) with the ingredients in it on the hob before switching the heater on.
it is the pan which will get hot, the ticking may or may not be the pan heating up.
Try it with water only in the pan and see if it works.
Posted on Dec 20, 2010
Testimonial: "Thanks Ashburton, its nice to have someone knowledgable to do a quick sanity check for me"
SOURCE: I have a Belling PBi60
Hi
I have this problem as well. Did you get a solution?
Posted on Mar 25, 2011
rickead1
  • 1998 Answers
SOURCE: f5 error code
F5 = EOC electronic control failure replace electronic control is stated in the service manual. If you have any further questions message me them back. Thank you
Rick
Posted on Nov 29, 2011
What size cable and fuse do I need to run a Neff oven 3.68kw. and induction hob 7.2kw together ?
Divide the total load by the volts available ie. 11kw by 240v or 110v, the result is current in amps. You need a cable of a suitable cross section to transmit that amperage. There is also a distance calculation to be considered as this affects the available load. Get a sparkie to guide you as to correct sizing.
Nov 04, 2014 | Neff Ovens
F5 error code
Rick
Nov 28, 2011 | Thermador SC302T Electric Double Oven
Ge oven jkp27 code f5
Hello Donald,
The F5 error code means that the control board has detecteda error within it self and theirfore the control(also called clock or EOC) needs to be replaced. The F5 error code can be cleared by pushing the cancel/off button and if it returns a short time later their is defiently a malfunction inside of the clock and it would need to be replaced.
GENE
Sep 28, 2011 | GE JKP27 Electric Double Oven
De dietrich induction hob fault code d5 6f 20 a3
I have a De Dietrich DTI749X induction cooktop and i have the FO error code flashing on two of the hobs.
How do I fix this?
Sep 01, 2011 | De Dietrich Ovens
Has anyone had a problem with the inner glass on the Lamona oven door exploding. Mine just has! It's only 18 months old and hardly used. I wonder if it's the difference in temperature betweeen the hot oven...
We bought our kitchen from Howden's as well about 15 months ago. They installed a Lamona double oven and hob. Last night when opening the door to the bottom oven our glass on the inner door exploded as well. Maybe there was a batch of defective ovens as ours sounds as though they mat have been bought/manufactured at the same time.
Mar 07, 2011 | Ovens
Hello. I have a new hotpoint CIO644 induction hob but when I turn a hob on, and put a pan of any size on the hob, it start ticking. The ticking stops when I take the pan off. The display shows the setting...
Hi
Dec 20, 2010 | Hotpoint Ovens
May 21, 2010 | Neff B1421 Electric Single Oven
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F4 Shorted wire or Sensor locate short and correct it
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F2 Oven over heat Replace defective Sensor
F7 Shorted Touch Panel Replace Glass Panel
F9 Door Latch Error Check latch
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F1 Defective ERC Replace ERC
F3 Oven Sensor Open Check/Replace Sensor
F5 Defective ERC Replace ERC
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
F8 Defective ERC Replace ERC
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Ovens with 2 Digit Displays
F0 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F9 Door Latch Error Check latch and latch circuit
Dec 18, 2009 | Ovens
Whirlpool Gold Electric Oven F5 E1 code on bar code
For some reason I get the same error code every time we have a power outage. If you push and hold the "lower off" button for about ten or 15 seconds it will unlock and reset. Hope this helps.
Jan 26, 2009 | Whirlpool GBD307PDS Electric Double Oven
Ovens Logo
365 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
