Have changed the bulb on the rear indicator but it's still not working
  • 4 Answers
This could be a few diffrent things.
could have a bad socket or corossion
also could be a bad switch up under the brake pedal
or some how got a break in the line to it
also could be as simple as a fuse
Posted on Oct 15, 2013
Reset reverse light indicator camry
Make sure the tail lights and brake lights are working including the one in the rear window, if any of these are out the dash warning light will stay on, any bulbs that look discolored should be replaced
Mar 16, 2014 | Toyota Camry Cars & Trucks
Left indicator light flicker too fast
If the right side works properly, switch all indicator bulbs one at a time. test with each bulb change. Untill you find the one that makes it flash at the rite timing. I had a bad rear bulb. The brake filiment was laying on the tail light filiment. This made the blinker timing bad.
Jan 26, 2014 | Hyundai Tucson Cars & Trucks
I have a 2009 Kia Spectra. The drivers side rear turn signal and flasher will not work and cannot find help from local mechanics
if no power to rear indicator on one side and all the rest work ok then if bulb is ok then wireing feed to that bulb cant think of any other souce take a long piece of wire from front indicator adt touch on conector at the rear bulb if works then is wireing if not its a bad earth
Aug 14, 2012 | 2009 Kia Spectra
I have a 99 buick century my drivers front blinker bulb doesnt work, the rear works fine my dash indicator doesnt work either ive tried the wiring diagram but didnt get anywhere any ideas?
change bulb in front if indicator doesnt blink or blinks fast if new bulb check socket connectors may have corrosion or damaged wiring
Oct 30, 2009 | 1999 Buick Century
Ford festiva indicator light replacement
take cover off at lights inside the boot,there are two clips on the taillight squeeze them and the bulb unit should come off
Jul 16, 2009 | 1993 Ford Festiva
How do i change my rear indicator bulb in my 04 beetle?
open rear hatch and look strait down on inside boot well. the plastic trim has access holes that pop out on either side just behind the lights. pop out the access cover on the side with burnt bulb, then reach inside that hole and you will fins a large plastic "wingnut", unscrew it<careful not to drop it or you'll have to take the whole boot apart to retrieve it> after removing wingnut carefully pop out lens from outside , replace bulb and reinstall after testing
Mar 19, 2009 | 2000 Volkswagen Beetle
REAR TURN INDICATOR WILL QUIT WORKING
if you have done all of this check out the socket with a 12- volt tested and the wire behind the socket to see if you have power coming to it or a loose wire or a broken wire.
Feb 14, 2009 | 2001 Ford Expedition
Computers & Internet Logo
David Payne
David Payne
