Question about Car Audio & Video
Kicker solobaric l5 12''
Proper wiring of sub for connection to a crunch 1 ohm stable 600 watt amp
  • 2 more comments
  • Anonymous Feb 19, 2008
    writing tips
  • PETEYWHEAT Feb 23, 2008
    speakers shut off when volume is raised
  • Purplemon769 May 13, 2009
    I have three l5 12's ran by a directed d2400 amp and want to bring it down to 1 ohm or less. Need a wiring diagram though. Anybody know how let me know by emailing me a diagram. My email is, the product numbers are 05s12L5. I have three like I said and want to bring the ohm load down to 1 or less. Let me know please.
  • Anonymous Mar 21, 2014
    i need to know how much it would cost to get the sub woofer recoiled
How to wire a kicker solo baric l5 12'' 4ohm down 2 and 1 ohm
Posted on Feb 03, 2008
I have a kicker L5 12" subwoofer witha kenwood kac 7252 bridged at 500RMS what should be the HPF and LPF?
Posted on Aug 09, 2008
  • 709 Answers
Hi Bobboo, Which Crunch Is it? Groundpounder, or Powerzone? best thing to do is give me the model number and I can figure the correct wiring. It is critical how you wire it, to get the best effect.
Posted on Sep 26, 2007
A kicker 600.1 wired to a jl w7 10" sub? Will that work?
The kicker 600.1 provides 600 watts at 2 ohms and 300 watts at 4 ohms the 10" JL W7 has 2 1.5 ohm voice coils so you will have to wire them in series. Take about 1.5 feet of 14 gauge wire and connect the positive of one voice coil to the negative of the other then the positive and negative that are left go to the amp. Your impedance should be 3 ohms and that amp should work just fine.
Jan 14, 2016 | Kicker Car Audio & Video
I have 2 12 inch kicker rt dual 2 ohm subs. On a kicker cx1200.1 i want to kno how to hook it up to 2ohm to the amp. And if i can add another 10 inch kicker rt 2ohm sub in the future.
Do to the impedance Of your sub u can't run it @2ohms its going to either be @1ohm or 4ohms and your amp isn't 1ohm stable and u will risk damaging your amp. So your only option is to run it @4ohms and on a good note your sub is 100-600 watts RMS and your amp will push 400-500 watts RMS @4ohms. Now if you want to run 2 sub's in the future That amp will work perfect because it pushes 1,200watts RMS @2ohms and to wire your 2 sub's @1ohm just follow the steps in the image below. Hope this helped.25345194-v0hbouy2nvquqteoroa5j5rq-3-0.png
Dec 30, 2014 | Car Audio & Video
Can I hook up 2 lanzar opti1532 subs 2 a kicker kx 1200.1 or do I need a bigger amp, its a 1ohm stable amp an birth sheet says 1390watts but they told me at 14+ volts it will do 1400rms
Based solely on spec sheet information the Lanzars can handle 1300 watts RMS and the KX1200 is rated at 300x1 @ 4 ohms, 600x1 @ 2 ohms, & 1200x1 @ 1 ohm. Even with a 1 ohm load you will still only be providing 600 watts to each sub. While the kicker will provide more power at 14+ volts, no car creates more than 12-13 volts via its alternator. A car battery only provides 12.6 volts. So you will be loking at 1200 watts from 1 channel as a best case scenario.
Additionally, with your 2 subs, they will need to both be Dual 4 ohm voice coils in order to net a 1 ohm final load. Each voice coil will need to be wired in parallel and then each speaker needs to be wired in parallel.
Dec 23, 2010 | Lanzar OPTI1532D Car Subwoofer
I want a reliable system.
if you bought that equipment today then your answer is yes your amp will power the subs but if i was you and you want more bass I would go with a two channel amp or even a mono block amp that will be 1 ohm stable and if you decide to do that you might want to get subs that are dual 4 ohm voice coils and run them in series that will get you 1 ohm of resistance
May 19, 2010 | Kicker ZX650.4 Multi-Channel Amp - 480W ZX...
XM-2002GTW Car Amp: i have 2 dual 2-ohms solobaric speakers and im try...
I researched your amp and it looks like its not even 2 ohm stable :( the problem with these companies is they lable there amps 1200 watts MAX, that means they tested the amp in a perfect enviroment and the amp fried somewhere in the ball park of 1200 watts, your best bet is to save your money and buy a nicer amp that is two or one ohm stable... that being said the best way to wire your subs is in series
May 17, 2010 | Sony XM-2002GTW Car Amp
2 12" dvc subs 2 ohm stable amp
+ on amp output to + on speaker #1 to + on speaker #2. - on amp output to - on speaker #1 to - on speaker #2. This is a parallel circuit....4 ohms in parallel with 4 ohms = 2 ohms. IF it were wired in series....would represent 8 ohm load.
Nov 12, 2009 | Kicker KX2500.1 Car Audio Amplifier
Why does the kenwood kac-9103d has two sets of terminals if its a one channel amp so how do i hook up a dual 12 phoniex gold 1200 watt sub to it
Hello damasogrizzl,
The 2 sets of terminals are connected internally. Having 2 sets just makes it more convenient when wiring multiple subs. The amp is rated for 900 watts RMS into a 2 ohm load. The specs claim that it is stable at 1 ohm but does not give a power rating.
The Radial SD competition series from Phoenix Gold are rated to handle up to 600 watts RMS. If you have the model RSdC124 with dual 4 ohm voice coils, it would be best to wire the voice coils in parallel for a 2 ohm load and connect the sub to one set of terminals on the amp. If your sub is the model RSdC122 with dual 2 ohm voice coils, you should wire the voice coils is series for a 4 ohm load and connect the sug to one set of terminals on the amp. Wiring the voice coils in parallel will result in a 1 ohm load. And, while the amp may be stable at 1 ohm, the sub will be seriously overpowered.
Hope this helps.
Sep 23, 2009 | Kenwood KAC-9103D Car Audio Amplifier
Does two 1ohm woofer = 2 ohm
if you buy the 4 ohm subs you can drop each of them to 2 ohm and then down to 1 ohm between the two of them. going with the 2 ohm no matter how you wire them you will either get 2 ohms 4 ohms or 8 ohms. hope this helps by the way the 4 ohm solobaric and the 2 ohm are both the same price.
May 21, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
AMP shuts off
your problem could be in the fact that you are trying to overdrive the amp. sony will not carry a 1 ohm stable load and if your speaker are 4 ohm speakers wired in series then you cant drive the bass your looking for. try using soundstream tarantula amp or new hifonics block mono class d amp with about 1000 watts rms. what kicker subs do you have? that will also make the difference in amp choice. im running tarantula on 4 polk momo 4 ohm 12's and has broke my back glass in my jeep twice one time was for a show. oh well let me know. happy boom boom. i'll be glad to help
Feb 28, 2009 | Sony Car Audio & Video
I have 2 kicker 07CVR124 12" dual voice coil with a 800 watt mono pioneer amp. How do I wire it correctly
I'm not sure what pinoeer amp you have. If I remember correctly some are 1 ohm stable. In this case you would be able to wire everything in parallel. Meaning, with the voice coil, wire the positive to positive, and the negative to negative. Then wire the subs together positive to positive, and negative to negative. This will give you the total impedence of 1 ohm. If it isn't 1 ohm stable the best you could do is 4 ohms. To do this you would need to wire the voice coils in series and the subs in parallel. Meaning, wire the negative to positive and the positive to negative. Then take the subs and connect the positive to positive and the negative to negative. I hope this isn't too confusing. If you need further assistance let me know. Good luck
-Andrew Hawkins
Aug 26, 2008 | Kicker Car Audio & Video
Car Audio & Video Logo
559 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
