Since last few days i was trying to decrease the temperature but it's not possible with this remote. please give me a advice
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Office Equip... Master
  • 102,366 Answers
What make and model is "this remote"? What device is it attempting to control?
Posted on Oct 14, 2013
I have Royal Sovereign ARP-1000ES Portable Air Conditioner. Last a few days, it shut off When running with cool mode.(no problem with dehumidify or fan mode) I checked water tank, but it's empty. Please...
It is supposed to shut off when the room meets the temperature you set it for. Are you saying it shuts off before the room cools to the temp you set it for?
What do you mean "..last a few days...?" Is it new only a few days and then break?
Be clearer if you need help.
Oct 18, 2013 | Heating & Cooling
Sir, how to get max speed
The best possible internet speed is dependant on a few factors including but not limited to, your distance from the exchange, last mile ethernet standards in use, type of service you have subscribed to.
ADSL is over copper so, if your telco has maintained the copper wiring from your house to the exchange well and the copper installed in your house is new or less then 5 years old you should be getting the best possible speeds that can be achieved. Also you can check that any devices connected to your home network are not sharing files via a torrent client, software updates are not being installed or even anti-virus scans running at the time you are browsing the internet, it also means that minimal people are on the home LAN as possible as all these things will slow down the individuals experience. If you try to mitigate all or most of these points you should achieve the best possible speed available.
Cable along with the previous points, it should be noted that this is in-fact a shared medium so speed will increase and decrease as users decrease and increase throughout the day. So if you are surfing the web, typically between the hours of 12am-6am you will most likely be getting the maximum possible speed, and as more people get on during the day you will notice a decrease in speed.
Jun 01, 2013 | Computers & Internet
Pump cuts off then comes back on a few minutes later
More than likely, your unit is equipped with a protective device which automatically trips the unit should the internal motor temperature exceed a preset limit. Then, when the temperature decreases, also to a preset limit, the device turns the pump back on. The purpose of the device is to prevent burnout of the motor.
Have an electrician use a clamp-on ammeter to measure the current draw of the motor and compare that to the nameplate data. If the meter shows the motor near, at or over the normal Full Load Amps (FLA), investigate that condition. While there are numerous possibilities, the most likely causes are worn/defective motor or pump bearings. Try to determine if the motor is actually running hot. The nameplate lists a Temperature Rise which gives the normal motor operating temperature under expected full load conditions. Quick check:If you cannot place your hand on the motor surface for at least 10 seconds w/o undue discomfort, your motor is running hot.
If the motor is tripping but not drawing excessive current nor running hot, it's very possible that the protective device itself is defective and needs replacement.
Have the electrician check out whatever is used in the motor starter for overload device. Some overloads trip on overload and reset themselves on decrease in temperature. Others must be manually reset. If the starter overloads are not tripping but the motor is, then the problem is almost assuredly a defective trip installed in the motor itself.
Important: If you are not electrically trained yourself, it IS NOT recommended that you attempt any electrical troubleshooting. Hire a pro.
May 29, 2013 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
Bush lcd42f1080p100hz remote will not turn tv on
I had come home about a week ago and pushed the power button from my remote but my tv did not respond. So I just went to the front panel and pushed power but once the tv turned on, the volume was on full blast! I used the front panel volume decrease to get the volume down, but when I stopped pushing the button, the tv increased its volume to full blast again by itself! Naturally I just turned the tv off for a few moments. I tried the remote again, no response again, so I used the panel power button. The tv volume was still full blast when it turned on but after I decreased the volume it stayed this time. The picture is and has been perfectly fine and the tv was working fine. The next day the problem started all over and now once we turned it off from frustration of having to manually use the panel to change channels, it now will not turn on at all. I have changed batteries from my remote, reprogrammed my remote, pushed system reset several times, unplugged it for a while, bought a new surge charge, and even held the menu and device panel buttons for 10 sec and tried to turn the t.v. on again! What other options do I have or what may be the issue at hand and possible parts that may need to be replaced?? Thanks!!
Nov 02, 2012 | Televison & Video
What will happen to a reptile if proper heating is not maintained?
Reptiles who do not receive a proper range of temperature in their habitat can suffer from decreased appetite, digestion problems, stress and possible death.
I recommend ensuring that the proper heating levels are maintained for a few days before bringing your reptile home.
Sep 04, 2012 | Aqueon Reptile
I have a spice c-810 since last 2 yrs. from last few days it is not accessing memory card.it shows "Memory Card not inserted" as i try to access it. Please advice.
i have spice c-810 cdma when i put my phone on charging then display is white.when i remove the charging it was ok .please give solution
Sep 07, 2010 | Cell Phones
Coolant temperature and water leaks
Hi
You need to have the cooling system pressure tested, this should point out the leak.
If no joy, a Carbon Monoxide test on the cooling system, if the fluid changes color, you have possible head gasket problem.
I suspect it will be either a Water hose, or Water pump ?
Good Luck !
Please give me a FixYa rating....I want to be a Guru !
Feb 04, 2009 | 2003 BMW 330
We have lg air con, i think it is a split system. no buttons visiable. we lost the remote for it a while ago. it turned itself on an hour ago. cannot find remote want to know how to turn off?!
Find the circuit breaker of this aircon outlet or unplug the unit to outlet or wall socket to made it off. If your desire and want to shut it down.
Then final option, Find the Thermostat control (Temperature control) If its digital theres a small lcd show the number and figures that control the temperature set up to start and off the unit.
It can be done by remote only.
On the other manual way you must find also the knob and rotate it clockwise to increase the temp and run longer.If reverse counterclockwise it decrease the temp. and turn it off quickly as possible. In case if it compose of slide control. Upward to increase and downward to decrease
All aircon unit has its panel board or LCD Screen that control the power on & off.
You can test the result by trying to put a power again on the unit.
I hope you you find my solution successfull. Until you locate and found the remote.
r_ic7
Nov 27, 2008 | Coleman Mach III Air Conditioner
Need to open remote control possibly one of the kids spilt fluid on it!
Hi mickbell39
Check out this tip I have written about how to dismantle your remote, and clean the switch contacts. was the rubber and plastic parts in water, the remote pcb with meths.
I am more than happy to answer any other questions you may have about it, just give me a hoy :) If you are still unsure, or have problems, then before you give a rating for this advice, please get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Jun 16, 2008 | Panasonic Televison & Video
15 people viewed this question
k24674
