Question about Kenmore Elite Oasis 27052 Top Load Washer
I have a Kenmore front loader model # 796.4044 started a couple months ago washer leaked water everywhere. Cleaned out filter and was OK now sometimes I find water on floor and washer is done and filter is clean
SOURCE: Kenmore front load washer
Purchased a Kenmore HE 2T a few months ago. We discovered water on the washer during the rinse cycle of 1 large load of wash. A Sears repairman checked over the washer and told us we were using too much HE detergent and this caused water to leak out from the door. He said its a common problem with front loaders and recommended using 1/2 to 1/4 (if a water softener is installed) the amount recommended by the manufacturer.
We use the washer everyday and so far no more water leaks.
Posted on Jan 19, 2008
aborcass
  • 2651 Answers
SOURCE: leaks water onto floor in front of washer after spin cycle, help
open the door though, put your hand around the rubber boot assy, run *** all around looking for small tears, and or holes, if so replace it. only other thing to do is remove the lower access panel and watch it spin a load and youll be able to detect where te waters coming from
Posted on Mar 23, 2008
jsrock516
  • 5911 Answers
SOURCE: Front Loader Kenmore Mod # 110.44832202 is leaking.
The rubber seal is known as a bellow. If the bellow is torn, more than likely it IS the cause of your leak. Your only course of action is the replace it. Searspartsdirect.com carries replacements. Just type in your model (as you provided) and look under the "Door and Latch Parts" heading for item number 1 (part #8182119). It is not a cheap part, but it will cost you much more to have an appliance repair company install it for you. This is not a difficult repair, and you can accomplish this on your own if you follow these steps:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
Some additional parts that normally do not need replaced, but you may consider just in case are the front and back clamps that hold the bellow in place. They are listed under the same heading as items 6 and 14. They don't cost that much and may consider them just in case you need them. In particular, the front clamp, can break or the spring becomes stretched. Inspect these items just to be sure.
I hope you find this information helpful. If you require additional assistance, please let me know.
PS You may also try repairclinic.com for comparative pricing. They also carry the same parts (sometimes for less).
Posted on Sep 12, 2008
jumptrout51
  • 3361 Answers
SOURCE: Kenmore top load portable washer leaking, model 110.42722200
Replace the water pump. The seal is leaking.
Posted on Jul 16, 2009
  • 714 Answers
SOURCE: kenmore heavy duty 70 series model 110-8237012
probably your drain pump leaking it has a seal right where it attaches to motor,,,,mine is leaking there but haven't replaced it yet! lol
Posted on Feb 28, 2010
How do I replace the pump filter on a front loader Kenmore washing machine
check the rubber o-ring. i may have come away or have got caught and broken when you screwed it back in
May 24, 2014 | Washing Machines
Washer is Kenmore He2 model # 110.46462501
It sounds like you have something stuck in the pump.
To repair
Unplug machine.
Remove bottom front panel(remove 2-3 screws in the bottom) Pull bottom of panel out and down to remove.
Towards the center bottom you will see the pump. On the front is a round thing that resembles a filter. This is the pump filter screen...Get a shallow pan to put under screen. Turn lid counter clockwise to remove(turn slowly and allow water to drain. As you may need to dump pan several times before all water is drained out. Be carful or you could end up with water everywhere. Once the water is drained pull out screen and remove the debris and objects stuck in screen and filter housing you should also be able to see the impeller on the pump inspect for debris. Once everything is cleaned out reverse removal procedures put back together.
Mar 22, 2010 | Kenmore 43142 Front Load Washer
Washer leaks water in the back of the washer but i cannot see any signs of the leak. this is a front load washer . model 970 ca0042 00,
I have a Kenmore front loading washer HE2 Plus.
Started leaking only 6 months old from the back over the spin motor.
I found a bolt had come out of the motor bracket causing the motor to crack a small hole in the plastic outer drum. I've been down for about a month waiting on the part and service. This is under warranty and we cant get any help any sooner from sears, not even a loaner.
Will not purchase Kenmore products again, 2nd front loader from Kenmore, 2nd problems.
Oct 14, 2009 | Kenmore Washing Machines
Kenmore Elite Front Loader
Debris can be in the fill valve, jamming it open a little. You can't always take them apart. Turn the water off at the faucet to check. Get new hoses, the filters in the old ones must be bad, and old hoses can blow.
May 10, 2009 | Kenmore 44102 Front Load Washer
Kenmore 3.5 frnt loader always has inches of H20 in rubber gasket
does your model start with 417? if so then there is a new door gasket that will help with water left in the boot.
if you have 110, then there is no new gasket/ boot...
you need to clean the drain pump sump screen.
either unit will have a clean out screen that is a removable cover on the front of the pump and it allows you to unscrew the sump filter and clean it out.
Feb 23, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Moldy smell in front load kenmore washer
I had the same problem. Have you cleaned the filter under the front panel? Simply remove the three screws holding the panel below the door and remove the 2" white screwcap. Be sure to have a basin handy to catch the water. (possibly a couple of gallons if the stainer is really clogged) I suspect you'll find several moldy items that are causing the odor. Good luck.
Feb 28, 2008 | GE WSXH208A Front Load Washer
check teh rubber seal on teh front door. They sometimes leak down the front of the door.
Jan 14, 2008 | Kenmore 44832 Front Load Washer
Kenmore front loader washer HE3 kenmore Elite
ok " there is a filter on that line ,it has to be cleaned
to locate filter, follow hose back to filter
filter will come apart for cleaning
Jan 11, 2008 | Kenmore 44832 Front Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
110 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
