Question about Whirlpool GEW9250 Electric Dryer
Door pops open
Ever since this dryer was brand new (5 1/2 years), the door has popped open. I had a warranty call on it and the service man told me that I just had to push in on the top and bottom, where the connectors are, to keep it closed. That worked for a while, now as the dryer is aging, there is nothing that keeps the door from popping open. I figure I need to replace some of the latch parts, but which ones?
  • 119 Answers
The one on the panel, but sometimes they sell you the whole kit. mind as well replace both
Posted on Oct 16, 2013
  • 1028 Answers
SOURCE: Dryer door pops open after
door strike is bad also door may be warped make sure door is not warped if it is just twist in opposite direction if strike needed part #279570
Posted on Jun 14, 2008
vitg55
  • 78 Answers
SOURCE: Hello, my dryer door keeps
It needs to replace door latch kit part# 279570
Posted on Nov 29, 2008
  • 401 Answers
SOURCE: Latch on dryer door loose and will not close.
Pry carefully. They just snap into the hole.
Posted on Apr 01, 2010
sonicboomele
  • 1557 Answers
SOURCE: I have a whirlpool gold dryer. I can't keep the
the problem is the door latch have a look and see if the door pin (plastic) still has both prongs they should look the same from side to side if they are then the tension wires in the doors clamp have come apart. if one side of the door pin has snapped off (most common problem from slamming door closed) replace the door pin
hope this helps
please take the time to rate this repair
Posted on Aug 03, 2010
SOURCE: Whirlpool Front Loader Dryer Door will NOT stay closed
I have the same issue with the door popping open. If you push hard on the bottom of the door then it snaps in. I think the bottom latch is broken or misalligned.
Posted on Jul 10, 2011
Whirlpool duet dryer model #wed9400swo Dryer door pops open, stopping the cycle. Dryer is about 2 years old. Can I fix this myself?
The most probable thing causing the door to pop open isa weak/broken door catch, its very easy to replace. To find it look on the mid center door rim opposite the hinged side,you will see a rectangular shaped plastic piece,thats the door catch.To remove it use a screwdriver and pop it out by placing the screwdriver on the inside rim of it and prying it out. To install the new one line it up and pop it in by pressing on it with your thumb,when you get the part it will come with the rectangle peice and the peice that fits in door,the part that fits in door is probably going to be good and no reason to replace. The part # is 279570 it could be found on line by simply entering that part# in a google search
Good luck,i hope this helps and if it does please give me a 4 thumbs up rating
Gene
Jul 29, 2011 | Dryers
My duet dryer's door will pop while drying and then the door is not shut tightly. The door never completely opens just not shut tight and the light comes on in it. When this happens the dryer quits, and...
We had the same problem and surprised how rampant the issue was after referring to the internet reviews / troubleshooting, etc. The problem started after about 6 months and the solution came to me after much "headaching" over the problem. There were no 'codes' coming up just the door popping open during the cycle. I purchased a (2) twenty pack of 1/2" diamerter x 1/16" thick N42 Neo Earth Magnets and placed them along the top edge and bottom edge of the dryer opening. Instant fix in less than a minute. The thickness does not interfere with the door opening and the strength of the magnets is obvious. Hope this helps. Fix was less than $10 bucks and no service man, etc.
May 19, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Oct 17, 2009 | Whirlpool GEW9250 Electric Dryer
GE profile freezer door pops open
If you close any refrig door " fast " , the other will pop open . These magnetic door gaskets , are designed for lighter holding power now , than they used to be , due to children getting caught inside . I would suggest lowering the front legs slightly , so that when you let go of the door , it will close slowly on its own .
Sep 29, 2009 | GE Profile PFS22 33" Artica French Door...
Kenmore Electric dryer Model 110.8708 - brand new, worked fine for 2 days. Now suddenly the dryer door pops open on its own and shuts down the dryer. Is this an adjustment ?
Sounds like the door catch is weak. You can try to spead the prongs on the dryer catch (the metal protusion on the dryer, not the door), but be careful. Unless it's very easy to do, call the wrranty dealer for the the machine since it should still be under warranty and the catch should be replaced at no cost to you.
Apr 12, 2009 | Kenmore Dryers
Dryer door pops open. leaves burn marks on clothes.
check to see if you have bent door hinges first, do this by opening the door all the way down and see if it is level with the floor. if it goes past level then the hinges are bent.
guess someone may have fell on the door or used it as a step.
if so, then you can take a hand towel and roll it up, then put it at the bottom of the door and close the door gently to "bend" the hinges back into place. this will aloow the door to stay closed and should also take care of the "burn" marks on your clothes.
i would guess the unit was overheating from the door not closing right allowing air to enter around the door. that will cause the unit to overheat and leave marks on your clothes.
Dec 28, 2008 | Kenmore 63942 Dryer
Dryer door pops open after running 5 minutes,close door hit start button door opens.let set 10 minutes ,run 5 minutes door pops open .dryer not overloaded. Serial #GEQ8811KTO
Jun 14, 2008 | Whirlpool Dryers
Duet dryer dead
A tell tale sign of a failed control panel. Irregardless of brand, Dryer usually has a 1-year part and 1-year labor warranty. Pull out your proof of purchase (POP) and go to the manufacturer's website to find a servicer near your area (usually search by zip code or miles radius). Call the recommended servicer in your area and provided them with POP when asked. Repair turn-around time is usually 4-6 business days. A trip to the laundromat or installing a clothesline... take your pick :-)
Best Regards.
Jan 16, 2008 | Whirlpool GEW9250P Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
109 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
