Question about Sewing Machines
I have a Husqvarna Opal 650 machine that was just purchase in July. I am hired to sew headbands, and we use Coats Transparent polyester thread. It's worked perfectly, until last Saturday it suddenly decided to break the top thread every time I backstitch (which occurs 4-6 times in the making of one headband.) It sews fine down the end, and as soon as I hit backstitch, it takes one stitch and snaps. If I come down, stop, go backwards, stop, and go forward again, it works. But I can't do it continuously. I cleaned the bobbin case, took the spool and bobbin out and re-threaded the top and bottom threads with the manual and changed the needle twice. (Actually, I had just changed the needle, and then it started happening) I made sure the needle was properly inserted, and the tension is the same as it's always been. Any suggestions? Thanks!
  • Sewing Machines Master
  • 7,365 Answers
Change the needle again, the needle could have a burr
check for burrs in the needle plate area and in the bobbin area
is the needle the right one for the fabric being sewed? was the needle inserted correctly into the needle holder?
is the tension correct for the fabric being sewed?
Posted on Oct 31, 2013
Testimonial: "I don't know how to tell if the needle is correct for the fabric or how to tell if there are burrs. The needle was correctly inserted, that much I do know. :) I actually took it in to be repaired, and now that it came back it skips stitches like crazy, so now I have another problem to fix. :P"
My Husqvarna Opal thread cutter is not cutting the thread from the bobbin.
Huskies are excellent machines. Guessing this is a serger? Doesn't matter. Very likely you could ask Husqvarna.com. Likely, something is a bit out of sync. Or - all sewing machines are 'picky' about being threaded correctly. You might check that.
Jan 23, 2018 | Husqvarna Sewing Machines
I have a B350, i want to sew with just straight ordinary stitch, but the top stitch is too lose, the bottom stitch looks great. IN other words, i can pull the top thread out without any problem.
You need to tighten the upper tension--higher the number, the tighter the tension. Be sure you are using the appropriate needle and thread for the fabric being sewn.
If using 100% polyester thread, be sure it is a good brand--not Coats & Clark, bargain bin threads, or old thread.
Oct 08, 2017 | Sewing Machines
Singer 99 not feeding heavy thread.
Unfortunately, your domestic machine was not made to sew leather. It can probably sew lighter weight leather with a lighter weight thread. Your thread is most likely too heavy for the machine you are using so it is not able to pick it up properly.
Apr 19, 2017 | Singer Sewing Machines
Needle stitch fine. Bobbin stitch loops.
First, try a brand new needle.
Second, consider using a better quality thread. By all means, AVOID old or bargain bin threads. Coats & Clark used to be a standard, but thread quality has improved over the past few years, so you may want to check out other brands like Aurafil, Superior, Isacord, etc. Also, cotton wrapped polyester thread releases thread lint that contributes to build-up of gunk in the machine. Some sewists have noted that they experience more sewing issues when using C&C threads. However, some machines will do better with certain thread brands than others, so some experimentation may be beneficial.
Third, check the stitch on your sample again. Generally, when thread loops appear on the underside of the fabric, it is the upper thread that is the problem. If loopy threads appear on the top of the fabric, it is the bobbin thread that is the issue. You can even use a different color in the top to help distinguish which thread is the problem.
Fourth, when threading the upper thread, Always Raise the Presser Foot during the threading process so the tension disk is released and the thread can seat properly. "Bird nesting" occurs when the thread is not seated in the tension disk.
Sewing Machine Thread Bunching Up Here Why
Birds nest under the fabric big loops of thread top side looks good...
Fifth, when the upper thread appears on the underside of the fabric, the upper thread tension is too loose. If the bobbin thread appears on the top of the fabric, the tension thread is too tight (or the bobbin thread is loose). Start out with the upper tension set at the midway point and tweak it from that point. The tension is ideal when both upper and bobbin threads meet in the middle of the fabric.
Also, remember that tension is not static--a tension setting for chiffon will most likely not work on cotton or denim. Get comfortable adjusting the tension to suit the project you are sewing.
May 24, 2016 | Sewing Machines
Says check upper thread, but thread not broken. then stitches about 20 stitches and stops again
if it's losing power, you have a short in the machine.....if the stitches are jamming, you need to switch thread type. Many standard machines cannot function with the lightweight polyester threads ( especially the large spools made for sergers) so I recommend using coats and clark dual duty. ....make sure you have the same size thread on the top as you do on your bobbin....hope this helps
Feb 20, 2011 | Baby Lock Ellure
I just had my Designer 1 serviced. Now it has problems with sewing polyester thread, which I used a lot before the servicing. It sews perfectly with rayon thread so I'm thinking the tension is too tight...
Your dealer should keep a record of what was done to your machine. Actually, they should give you a record of what was done to your machine.
Calmly let them know that it used to do this and now it won't. Maybe they can take care of the problem for you.
If they are not willing to help, take all of the repair documentation that you have on what was done and contact another Husqvarna Viking dealer to see if they can help.
Dec 13, 2010 | Husqvarna Designer I
I am experiencing difficulty in stitching shade cloth. I have thread provided by the shade cloth manufacturer, and am using denim needle, as recommended by the shade cloth people.The machine is locking...
Probably just too heavy for the machine to handle and the thread may also be too thick for the bobbin to tension correctly.
Thread above 50 gauge is not suitable for domestic sewing machines and it is likely that that is what the shade cloth manufacturer use through an industrial machine.
You could try again with regular good quality polyester thread, a roller foot and very careful slow stitching with you helping on the fly wheel and see if it works?
Oct 24, 2010 | Husqvarna Viking 1
Thread keeps breaking
Check first that you are using premium thread (not the cheaper type that you'd use in an overlocker/serger). Breaking thread could be because of one of the following reasons -
the upper tension is too tight, the machine isn't threaded correctly, the thread doesn't suit the fabric (I had the problem when sewing an item the other day and changed from cotton thread to polyester and it stopped breaking). In your instruction manual check at the back for a troubleshooting section where it should be listed with some solutions.
Jul 08, 2009 | Husqvarna Husky 165
Thread jamming, wont feed material, sewing in one place
Try moving the stitch length dial to 4 or 5 - check the manual. You may have it in the position for very close together sewing. I had to do a lot of trying with my 4795 to get it to work right. I found that very thin thread, polyester kind, broke at the needle after a couple of stitches. I switched to coats & clarks thread and a Singer ball point needle and it works fine. Be sure your needle is inserted with the flat top toward the back of the machine. Good luck!
Nov 04, 2007 | Necchi 4595 Mechanical Sewing Machine
Sewing Machines Logo
144 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
