Question about Craftsman Drills
I need to replace the chuck - Craftsman Drills
  • 91 Answers
There is a left hand screw in where the drill bits go & you need to remove this before chuck can be unscrewed
Posted on Oct 22, 2013
Aeg chuck 18 volt
yeah, you'll need to replace the chuck. to remove the chuck generally takes a special tool.that fits between the drive and the chuck, that keeps the drive from spinning when you unscrew the chuck, this tool varies by manufacturer,
Oct 21, 2013 | Drills
How can I replace the keyless chuck on my Dewalt DWD215G?
Open the chuck wide open. In the center is a retaining screw, they usually have left hand threads. Remove the screw. Take an allen wrench1/4" to 3/8" in size and fasten the short side tightly in the chuck. The chucks are usually right hand thread, so take a small hammer and strike the allen wrench to turn the chuck to the left to loosen it. Once you have the chuck off, verify the thread size of the drill motor shaft, then go to McMaster-Carr and choose the one you need.
Apr 16, 2011 | Dewalt DWD215G 12Inch 10AMP Heavy Duty Mid...
We need to replace the chuck on our Bosch corded drill 1005VSR. We need detailed instructions on how to remove the chuck . Also, how can we order a new chuck?
Open the chuck wide open. In the center is a retaining screw, they usually have left hand threads. Remove the screw. Take an allen wrench 1/4" to 3/8" in size and fasten the short side tightly in the chuck. The chucks are usually right hand thread, so take a small hammer and strike the allen wrench to turn the chuck to the left to loosen it. Once you have the chuck off, verify the thread size of the drill motor shaft, then go to McMaster-Carr and choose the one you need.
Apr 15, 2011 | Bosch Drills
How do I change the chuck on my milwaukee right angle 1/2" drill? It has snapped off behind the chuck
Take digital photos when taking the front metal gear box off the drill. Next carefully remove the two plastic halves of the drill if needed to gain access to the shaft that holds the chuck.
Replace the broken threaded metal part that the chuck screws onto.
Normally chuck replacement involves unscrewing the small screw deep inside the chuck on a metal shaft has a left hand thread. Next use a large allen wrench tightened in the chuck with a mallet to loosen the bad chuck. Reverse to install new chuck.
Feb 01, 2011 | Drills
The chuck on my drill is hard to open and close around a drill bit. Is there a way to losen the chuck up a little?
You can apply som light lubricant spray to the threads or to the inside of the chuck and see if that helps. If not it may be permanently damaged or corroded and you may need to replace it.
To replace get you replacement chuck first, then;
Open the chuck fully. Inside the center bottom of the chuck you will normally find a reverse threaded lock screw that you must first remove. If it is hard to loosen, you may need to heat it with a micro torch or a heat gun to make the thread lock compound slip. Then fasten the smaller end of an allen key firmly into the jaws of the chuck. Engage the low gear. Then hit the longer end rapidly with a hammer to unscrew the chuck by rotating it anti clockwise.
Jun 20, 2010 | Dewalt & 14.4V Heavy Duty Xrp Drill/Driver...
I have a model 1689 drill press with a 33 taper jacobs chuck I need to remove the chuck to put a larger chuck on is the smaller chuck threaded on and if it is, is it RH or LH thread and how do you hold the...
you dont hold it, the chuck is a taper fit and you would need wedges to remove it. the newer chuck would also have to have the same taper to work. if replacing the new chuck you would need to make sure the parts are clean, use a brake cleaner and a paper towel to clean them and then they would press together. Let me know if you still need more assistance.
Jan 13, 2010 | Speed Clausing 15" Variable Floor Model...
3/8 Drill Driver, chuck replacement.
hi friend,
Step 1. Determine what kind of replacement drill chuck you want - a keyed chuck or key less chuck. Over the years, key less chucks have been widely used for handheld power tool drills, due to their improving grip torque and convenience.
Step 2. If you prefer replacement key less chucks, then you have to know what type of key less chuck you will need - a single sleeve key less chuck or a double-sleeve chuck. You can simply determine it by checking your current chuck. If your current chuck is a keyed chuck or a double sleeve chuck, then you will need a replacement double-sleeve key less chuck. On the other hand, if your current chuck is a single sleeve chuck, then you should get a replacement single sleeve chuck.
Step 3. Confirm the threaded mount size (spindle size) on the chuck. 3/8"-24 threaded mount for 3/8" capacity drill chucks and 1/2"-20 threaded mount for 1/2" capacity drill chucks, but there are some exceptions where just the opposite may occur. To be safe, always check the threaded mount before you buy replacement drill chucks.
hope this helps u
please rate me.........................
thank u for using fixya
regards
sivaranjini
Nov 26, 2009 | Craftsman 19.2V C3 DRILL/DRIVER
Dewalt Drill DC728. Chuck came out of drill body
I would clamp chuck in vise and use a chuck key or a Channel Lock Pliers to loosen the chuck.
Jun 08, 2009 | Dewalt Drills
Chuck Replacement
Hello Mike-To remove the old chuck, you'
ll need to open the jaws all the way and l;ook inside the chuck for a screw that holds the chuck onto the motor shaft. That screw has a reverse thread which means that you'll need to hold the chuck tight while using a screwdriver to turn the screw in the forward direction. After the screw is removed, p[lace a large allen wrench into the chuck and tighten it. Then using a hammer handle, rap the allen wrench in the reverse direction for removal. Then call Alltrade Tools @ 1-800-423-3598, give them your model number so they can provide you with a replacement chuck.
Jul 31, 2008 | kawasaki 19.2V 4 Piece Cordless Tool Kit
Drill chuck swap
1. Turn the screw clockwise to take it out.
2. Then you needs 3/8 allen key & insert the short side of the allen key & tighten the chuck.
3. hold the drill at the edge of the table & wack the allen key
counter clockwise & do it again as needed.
4. dewalt keyless chuck will fit but you might add a washer to insure the chuck is not rubbing the clutch collar.
5. putting it back together the other way.
Jun 01, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Drills Logo
Top Craftsman Drills Experts
Tim Venetis
Tom Chichester
Are you a Craftsman Drill Expert? Answer questions, earn points and help others
