Question about Halex 64339 Match Play Electronic Dartboard
Halex bowling machine continues to give error code E 33 game will not work
Frigidare ATF8000FSO error code 33
Hello edward, thanks for your post!
I see your Frigidaire washer is displaying an error code "33". However, it appears "33" is an invalid error code. Let's attempt resetting your range. You can do this by unplugging it or flipping the household circuit breaker to the off position for roughly ten minutes. This usually clears false error codes.
If resetting the power does not correct the issue, could you please inform me of the new error code or if your washer continues to display "33". I look forward to assisting you. -Matt
Oct 01, 2014 | Frigidaire Washing Machines
Getting oL code even after diagnostic check
OL, usually means Over Loaded. It is an error code thrown up by the on board computericon1.png.. generally when TOO much wet weight is in the bowl.
This condition is could be caused by faulty solenoid or solenoids at the water inlet valve. Unplug the machine, turn off the water, and remove the supply hoses. Check the solenoids at the water inlet valve. They can be tested using a multimeter or ohmmeter and checking for continuity. A lack of continuity will indicate a faulty solenoid and the inlet valve assy will need to be replaced.
Try unplugging for 12 hrs before reconnecting
If the problem continues then the controller board is damaged and will need to be replaced.
Jan 13, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
I need an instruction manual on the Halex outdoor football challenge game. We received the game for Christmas but we need the manual to see how to put it together!! Can I get the instructions online?
I am not sure if you can get them on line but you can contact there here:
Customer care at 1-800-645-5190 (or) custsvc@regent-halex.com
I am sure they can find a source for your missing instructions.
Kelly
Dec 27, 2010 | Halex 64339 Match Play Electronic...
Where can i find a games list for the Halex 64312 .
You can get the manual on the link below. It also list the games on the board.
http://www.regent-halex.com/manuals/64421.pdf
Good Luck
Dec 19, 2010 | Halex 64339 Match Play Electronic...
Im trying to figure out what games is what on my Halex Elight 2.0 6 darts ! I need a list that can show me starting at game 1 what each game is .
Some genius over at Yahoo Answers wrote all the game numbers: http://answers.yahoo.com/question/index?qid=20101215222956AAWwwlj
Nov 19, 2010 | Halex Toys
How do i score bowling in a dartboard game
how to play and keep score BOWLING
This dartboard adaptation of bowling
is a real challenge! It is a difficult game
in that you must be very accurate to rack
up a decent score. Player one starts the
game. You must select your “alley” by
either throwing dart or manually pressing
segment of choice. Once alley is selected,
you have 2 remaining darts to throw in
which to score points or “pins.” Each
specific segment in your “alley” is worth a
given pin total:
Segment Score
Double 9 pins
Outer Single 3 pins
Triple 10 pins
Inner Single 7 pins
There are several rules for this game as follows:
1. A perfect game score would be 200 in this version of bowling
2. You cannot hit the same singles segment twice within the same “frame” (round). The
second hit will count as zero points. Hint: Try to hit each single to reach 10 points in
the frame.
3. You can score 20 points per “frame” by hitting the triple segment twice.
4. Hitting the double segment with your second dart will only count as 10 points if you
scored a double on your first throw. Otherwise you will score a total of 9 points by
throwing a double with your second dart.
Mar 03, 2010 | Halex 64339 Match Play Electronic...
My dartboard didnt come with a game manual
if you have the crossfire from walmart with 90 game variations it's on the front of the battery cover, small text we couldn't find it either at first
Apr 12, 2009 | Halex 64339 Match Play Electronic...
I need the manual for the Halex 64670 electronic dartboard
I don't think this is the EXACT manual for this game, however, it helped us.....
http://www.regent-halex.com/images/PDFS/64515.pdf
Feb 21, 2009 | Halex Toys
Halex 64339 Match Play Electronic Dartboard Logo
53 people viewed this question
Top Halex Toys Experts
Stitch85
Level 1 Expert
ray gallant
Are you a Halex Toy Expert? Answer questions, earn points and help others
