Question about HP Tablets & eReaders
Display off center
Pc blinks 6 times and goes off without displaying
My daughter has a problem with her tablet, I have performed a "hard reset" as suggested however I cant get past the icecream sandwich with the water marks.
Any suggestions would be greatly appreciated.
Thanks.
Posted on Oct 18, 2013
My touchscreen goes so dim I cannot see the display
may be problem with your display backlight hardware problem
Jun 29, 2014 | Panasonic TOUGHBOOK CF-18 Tablet PC
Is there a way to recover the Panasonic Tablet PC back to factory default settings, without the CD? I don't have the CD so can you please tell me how to recover the PC?
Yes : boot from the recovery partition (you'll need to give the boot process some more time to keep the choice of the bboting partition displayed :
Windows+Pause, Advanced, 3rd "Parameters" button, change to 10 seconds.)
Jul 03, 2011 | Panasonic TOUGHBOOK CF-18 Tablet PC
Why cant i use my kindle when pluged into my computer, am i thick
When you connect your Kindle to a PC, it automatically goes to USB mode, allowing access to its internal memory from the PC. The Kindle cannot display a book for reading at the same time. It would require quite complicated handling, for example, to display a book while the book is deleted by the PC concurrently. Allowing only one machine access to the internal memory at a time avoids any concurrency issues.
If you want to read books while continue charging, on the PC:
  • Windows XP, Windows Vista: find the "Safely Remove Hardware" button in the status bar (right side of the task bar), and select "Eject" for the Kindle device.
  • Windows 7: Open "My Computer", press the right mouse button on the drive icon representing your Kindle's internal memory and select "Eject".
Jan 02, 2011 | Amazon Kindle Wireless Reading Device
1250S Display problem
It sounds like the system is trying to reduce power consumption to save battery life. Check your power settings in the control panel and set them to Max Performance to see if it stops doing it. If it does, you know that was the reason. If it doesn't let us know.
Mike Vail
Oct 05, 2009 | ViewSonic TPCV1250S (TPCV1250S0103) Tablet...
My toshiba portege M400 laptop will not start up, when I turn power on the power light starts blinking yellow and does nothing
This happened to me. The computer will not work with the battery in it.
Solution: Take battery out and plug in without battery... It should work,
You will need to get a new battery
Sep 19, 2009 | Toshiba Portege M400 PPM40U01000E Tablet...
Screen goes blank (white), sometimes screen display will get big
You can update graphics driver, if that does not fix the issue check the display on external monitor. If the external monitor works fine you can isolate checking the display in BIOS Setup scree (Restart your computer and keep tapping F10 to getinto BIOS). If the same issue in BIOS, you may have to change display of the unit.
Jun 26, 2009 | HP Pavilion TX1320US Tablet PC
Toshiba Portege R100 CMOS/BIOS PROBLEM at startup.
I'd look at trying to replace the BIOS battery...
Check out this guide for dis assembly instructions :
http://www.irisvista.com/tech/laptops/Toshiba_Portege_R100/remove_system_board_1.htm
Feb 22, 2009 | Toshiba Portege R100 Tablet PC
On boot up it displays and asks for a password on Laptop
1. At the BIOS password prompt ("PASSWORD = "), press and release the following keys, one after another:
Ctrl, Tab, Ctrl, Enter
The computer's response should be:
PC Serial No.= XXXXXXXXX
Challenge Code= XXXXX XXXXX XXXXX XXXXX XXXXX
Response Code=
2. Get response code from your local toshiba support center
Then follow the instructions the support guy will give you to unlock the laptop
Jan 15, 2009 | Toshiba Satellite R25-S3503 Tablet PC
Cant duplacate on extended monitor or on projector
Use your Q menu to select the "Internal and External" display. If this choice is not enabled on your Q menu, go to tablet settings and enable it there.
Feb 27, 2008 | Compaq tc1100 Tablet PC
Tablets & eReaders Logo
26 people viewed this question
Top HP Tablets & eReaders Experts
Anthony Pattay
Level 1 Expert
Lawrence Oravetz
Are you a HP Tablet and eReader Expert? Answer questions, earn points and help others
