Question about Monte Carlo (5CMR56OP) Carmel Old World Pewter Fan
I have a Monte Carlo 60" Arch Fan. Both the lights and the fan stopped working. There is power getting to the unit, and the remote has a good battery. I may have had some water drip onto the fan at some time, the roofer didn't do a very good job at replacing the shingles. What parts should I be looking at troubleshooting?
    Genius:
  • Monte Carlo Master
  • 1,617 Answers
You need a new receiver for the remote.
Posted on Oct 14, 2013
3 Suggested Answers
  • 579 Answers
SOURCE: Light on fan.
Most likely, the dimmer control has failed and needs replacing. Would be good to check its output voltage first.
Posted on Dec 31, 2007
  • 569 Answers
SOURCE: remote control wall unit does not turn on Monte
Are the manual switches on the fan in the 'on' position?
Select the maximum fan speed on the remote and then operate the manual switch on the fan. Set that to the highest speed then control it with the remote.
Same theory applies to the light.
If this is not the problem then the remote receiver on the fan is probably faulty.
Posted on Feb 28, 2010
Remote won't operate lights or fan.
Sorry, but this isn't a solution. I am a caretaker at a house that has 13 fans with these controls. In a nutshell,30% of them stop working and do exactly what you are describing. I have never been given a satisfactory answer from monte carlo. The only thing that has helped is I now carry and extra remote with me that I know works since some of my fans are over 15 feet up and I have no ladder that high. I then change change the code to match the one of the fan that I need used. I'm sorry, but this is what I have been dealing with for 4 years. If you have only 1 fan this probably won't help at all.
Jun 27, 2014 | Monte Carlo 5DI52BSD Discus Brushed Steel...
Blown bulb
Ideas? Yep. Shut down fan power at the source (fuse, breaker, etc.). Turn on fan power again. You should be back in operation
Jun 14, 2013 | Monte Carlo Manhattan Ceiling Fan
Monte Carlo ceiling fan and light not working
Even a brief power outage can cause amnesia in the receiver. You can try disconnecting power at the source and spending a few minutes removing the battery from the wall-mounted remote and pressing all buttons to eliminate the 'stuck button' problem. Reinstall the remote battery and reconnect main power to the unit. Test operation.
Lastly, there always is the possibility that some gremlin changed your original control setup.
Jun 23, 2017 | Dryers
Remote control wall unit does not turn on Monte Carlo fan or light although red light comes on when buttons are pushed (fan and light worked for about 2 years although it was hardly ever used).Frank
Feb 28, 2010 | Monte Carlo (5LCR52MW) Fan
2001 monte carlo blower motor stops working with heat or ac
Check all fuses using a test light. If good, turn on fan and check for power at the blower motor connector. There all the wires there as each one is for different speed. If good, blower might be bad. If no power, check switch itself for continuity. Keep me informed.
Jun 13, 2009 | 2001 Chevrolet Monte Carlo
FAN STOP TURNING
Hi! try old fashioned way, take a stick and try to run the fan with it and when it catches up some speed then turn it on. Or else tap on the face plate of your fan and else check for any loose connections or any oil leak from fan's capacitor.
Jan 07, 2009 | Monte Carlo 5AHR60OCD Arch Old Chicago...
Light on fan.
Dec 31, 2007 | Monte Carlo (5LCR52MW) Fan
Monte Carlo (5CMR56OP) Carmel Old World Pewter Fan Logo
85 people viewed this question
Top Monte Carlo Dryers Experts
ka4iup
ka4iup
Tom Chichester
Are you a Monte Carlo Dryer Expert? Answer questions, earn points and help others
