Question about Amana Kitchen Ranges
Still with my amana range yacr4330bcwo.. where would I look for the fuses?
    Top Expert:
  • Amana Master
  • 9,472 Answers
What problem are you having?
Posted on Oct 22, 2013
My amana stove glass top is showing f9eo on board what do i do?
  1. You can power off your range by turning off the circuit breaker(s) or fuse(s) for 1 minute. Then power up your range by turning on the circuit breaker(s) or fuse(s) on.
  2. Monitor your range for at least 1 more minute to make sure the error code does not return.
Taken straight from the Amana website. Issue My range console has an error message Amana Owner Center
Oct 07, 2016 | Amana Kitchen Ranges
Amana Stove just stopped working
Could be the fuse in the back turn off the power and trace the wiring with a multimeter, when you stop getting continuity there is the fuse.
Good luck Ray
Apr 15, 2014 | Amana 30" Self Cleaning Electric Range...
I have an Amana Self-Cleaning Range ARG7600. It is plugged into an outlet that is working but no lights come on. Does this model have an internal fuse that might be blown?
No fuses. All power is routed through the electronic control on the front of the range. The electronic control (ERC) will need replacing.
Jun 20, 2011 | Amana ARGS7650SS Gas Kitchen Range
1.Our gaz range (with electronic range control) Amana ACS3350AS oven bake works normally at 350 F for 40 minutes, then stops. While the broil can still work at this point, it's likely the Oven - High...
Works normally for 40 minutes? Then after she cool down will work again? Let me look un momento mon ami. Aha Your temp sensor might be faulty,
Another thang it could be is a weak ignitor,
An oven limit would shut down and NEVER come back to life. It ain't gonna be no limit er fuse.
Basic American oven fault codes and more HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 11, 2011 | Amana ACS3350 Gas Kitchen Range
All four burners of my Amana ACS3350AS range stopped lighting today. The covers are in the correct position and no debris is blocking the electrodes, they simply stopped lighting. The power is on, gas...
hello,
what this indicate from your statement could be view from two ways ,that is the problem can check and solve from two way .
1 from the fuse or,
2.from the wire connections
what you are to do to solve this problem first of all put off all form of power supply connected to the range ,then carefully unscrew the screw use as key on the range with technician tools either screw driver or allenkey depending on the nature of screw use on the range then trace the wire down to the fuse at the back of the range
Locate the fuse. It should be near where the electrical cord comes into the range. The fuse is a small white bar with metal caps on either end. Carefully remove the fuse. Avoid touching the transformer or other parts inside the range.
Purchase a new fuse. Most range ovens use an 18 amp ceramic fuse. Consult your owner's manual to find out what kind of fuse is used, or take the old fuse into the store to find the exact match.
Replace the fuse. Put the cover back on and see if your range works. If it does, replace the screws. If it does not, try a different fuse. If the microwave still does not turn on, you may have to have it replaced of professionally repaired.
but for the wire connection carefully trace the wire down to the element it is silver in colour see if there is any form of loose wire connected to the element carefully replace the wire on the element then couple it back to is position with this the problem of the range will be solve .
thank you.
Aug 19, 2010 | Amana ACS3350AS Gas Kitchen Range
The oven doesn't work on my amana range! the top works but the oven does'nt heat up
look to see if there is an inline fuse....you will probably have to take a panel off the back of the stove so you can see the wiring.. if it is a glass buss fuse they can be purchased at any auto parts store in the correct amperage for very little cash.....
Jan 03, 2010 | Amana ACF4215 Electric Kitchen Range
AMANA ELCTRIC RANGE ARR6202 ALL THE TOP BURNERS
i believe they are fused. so i would say follow one of the wires and see if there is a fuse somewhere
Jun 07, 2009 | Kitchen Ranges
Vent and lights do not work on over the range microwave
Check for another fuse. Check all electrical connections for burns. Did you check fuse with a meter or just look at it? Don't trust what it looks like.
Mar 27, 2009 | Amana MVH210W Microwave Oven
Oven bake does not work properly
check the selector swich and thermostat.
Dec 07, 2008 | Amana AER5515QA Electric Kitchen Range
Kitchen Ranges Logo
52 people viewed this question
Top Amana Kitchen Ranges Experts
Sal De
Ismael Rodriguez...
Oloyede Monsuru
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
