Question about Schlage Lock Co - BRZ SGL Cyl Deadbolt B60N716
Thumbsturn wont work unless key is in the lock so can't lock the door from the inside
    Master:
  • 492 Answers
Try using powdered graphite in the lock. Available at any key copy place or automotive parts store.
Posted on Oct 18, 2013
The key wont turn in the door lock of my 2004 Ford Escape and the electronic locking mechanism doesn't work unless the key is in the ignitionl. How can I get into my car?
It's not going to seem very helpful, but the only way that you'll be able to take care of this is to manipulate the lock from the inside. This is, of course, assuming your keys are stuck inside your car. If not, attempt unlocking the door by physically using your keys.
If your keys are locked in your vehicle, use the AAA wedge on the door and attempt to retrieve the keys -- they physically will be able to manipulate the lock. If the keys are gone, you could attempt wedging the door open and using a metal or plastic bar or plate to bypass the lock on the door itself (passing it between the door closing mechanism and the frame of the vehicle). If you're desperate, and don't have the keys anyways, it may just be time to break a window and do things the old fashioned way.
Aug 05, 2015 | 2004 Ford Escape
How do I fix a Schlage deadbolt. B60 series will not unlock from the inside unless the key is inserted from the outside
With the door open, remove the interior trim (thumb turn) from the door, and using the key, turn the deadbolt to the locked position. Now re-install the thumb turn, in the locked position, and with the key removed see if you are able to unlock the deadbolt. I suspect that the tailpiece (part that sticks out of the lock cylinder and into the thumb turn) is not in the correct position.
May 02, 2014 | Schlage B60 Series Double SecureKey 5-pin...
98 accord door handle broke door will not open
A non electric door, (which?) wont open,lock works ok, handle wont open the door.
What can I do to fix it.
well telling the door to us would help, and options.
so no electric locks,
there are 2 levers. one inside and one outside.
so you pull the door card (inside door covering)
and look at both locks , the inside pull, its it working?
then look at the key lock cylinder. is it connected still
and last are both connected to the latch mechanism.
one can cycle this latch lever inside the door shell.
if that fails the latch is busted.
all this is covered in the FSM ,why not read it.? (under body)
free , too.
http://hondatech.info/downloads/Auto/Manuals/Accord/
Nov 25, 2013 | Honda Accord Cars & Trucks
Escort 55 van rear door lock wont unlock with key
I assume you are referring to the tailgate door, so what likely happened is that either the door lock has something in it like a broken key, or dirt, or rust, etc. or perhaps the mechanism has failed.
Understand these parts are made as cheaply as possible, and are easy to break.
You may need to remove the riveted cover to look inside, and you may find a plastic clip broken, or the lock mechanism spoiled, or something else.
You do not need to re-rivet the cover, unless you have a pop-rivet tool.
You can also find some small screws that will reattach the cover. God bless your efforts.
Jan 31, 2012 | Cars & Trucks
Ford futura ba 2003 lock door with remote and key but the drivers side door wont lock when you open it unlocks all doors
it is a defective door lock actuator in the door you will have to take it in and have it replaced unless you are able to. the it is inside of the door, and the panel will have to be removed
Mar 11, 2011 | Ford Futura Cars & Trucks
Door locked can not unlock or open door pass door
This is very common. what happens is the power door lock actuator freezes up and doesnt allow the linkage to move, you may have to use pliers to pull on the lever or remove the door panel to get inside the door and dissconnect the linkage from the actuator, then you will be able to unlock or lock with the key or lever its just the power lock wont work unless you replace the actuator, heres a picture of it and it located next to the latch on the door,e72fa1d.jpg
Oct 29, 2010 | 1990 Ford F150
I have a weiser lock powerbolt 1000 and i just installed it and progammed it except the bolt wont lock unless the keys are in the door, if i type in the code with the keys in it works fine but when i...
The deadbolt may very free inside the deadbolt hole... This system is low torque and a over torque clutch may slip if the dead bolt it's not completely free inside the deadbolt hole... Also, if you try to open the door before to unlock it, you may block the deadbolt... take care to unlock the door before open it. to be sure that the dead lock is ok, you can turn the manual knob and be sure is turning very very easily.
Also are you no that POWERBOLT is a 3 codes memory? go to that link to see more info about that : http://www.fixya.com/support/t8006865-not_overwrite_old_codes_just_keeps
Have a good lock
Have a good unlock
Sep 11, 2010 | Weiser Lock Powerbolt 1000 Lock
Passenger door wont unlock, key turns in the lock but door wont unlock. Electric locks dont work. Driver door works fine 1991 Nissan pathfinder XE 4door
2006 Nissan Pathfinder rear passanger doors don't open unless opened from insinde handle first. Then will open all the time until central locking is used then same problem occurs
Apr 03, 2010 | 2001 Nissan Pathfinder
Key wont unlock door from outside
Take nozzle of WD-40, or similar penetrating spray & stick in key slot as deep as you can & spray inside, see if that helps.
Mar 06, 2009 | 1999 Dodge Intrepid
2004 Civic Drivers door lock
The driver's side door lock button is designed not to lock from the inside unless the handle is pulled, or the power switch is used. This serves as a reminder to not lock your keys inside.
If you are inside, and push down on the button (not the switch) hard enough to lock it, you've probably damaged it.
Jun 09, 2008 | 2004 Honda Civic
Schlage Lock Co - BRZ SGL Cyl Deadbolt B60N716 Logo
80 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
ken skalski
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
