Question about Garden
The points keep grounding out and its not firing
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Bad condenser ???
Posted on Oct 20, 2013
I have a 2003 s10 blazer 4.3v6 vortec. ok i keep getting hydrolock my #6 keeps feeling up with gas. i changed the sensors bought one new injector and new regulator and still the same.New pcm?
# 6 injector ground side is shorted to ground causing injector to fire constantly . It's probably not the PCM , If injector driver inside the PCM was bad the injector wouldn't fire at all . On the injector there are two wires , one is B+ voltage , the other goes to the PCM . PCM supply's a ground when triggered . How to test fuel injector circuit with basic tools open control wire
Jan 26, 2017 | 2003 Chevrolet Blazer
Could a fuel filter in vw 1600 beetle cause backfire
very unlikely
back firing is from partially open inlet valves , incorrect firing order , shorting across the points , faulty condenser , loose coil wires or faulty pigtail wire from the points plate to the ground ( distributor body)
seeing as to you have put in new points , I suspect that the condenser lead is shorting across to the points plate where it attaches to the moving point spring
also if the firing order is wrong after replacing the distributor cap that will also cause the problem
Nov 06, 2016 | Cars & Trucks
I had an elect ground fabricated &installed on RV Trans to correct a shifting problem. Now my 5500 Marquis won't start. No fire. Could the grounding kit be the culprit?
If the new ground wire is truly tied to a ground circuit it will not effect anything, unless the ground circuit tied into is a pulsing ground circuit. Example: the pulsed ground wire coming from a set of ignition points going to the coil or some other control unit that opens and closes a ground circuit when triggered.
Oct 13, 2016 | Cars & Trucks
How do i fix a no fire on a honda cb 100?
Take a close look at the shaft where the lobe is, is there play in the shaft? High mile bikes the bushing or shaft can wear down and not open the points correctly. You did a good job troubleshooting so far.
Jul 04, 2015 | 1971 Honda CB 100
I have a early 1970 1600 dual port volkswagen not getting fire to plugs what could be the problem
IF NOT MODIFIED THIS CAR HAS CONTACT BREAKERS (POINTS) Check for ignition at coil (terminal 15). If OK check if coil is grounding by sorting the negative (1). Also sheck for spark at this point by removing HT lead from distributor and holding en close to ground point (engine or body) but not touching. If coil is ok you should get a spark. Then go to the points themselves, Turn engine to point-closed position then open and release the points with a screw driver. You should see a spark there. If not replace points and also check connection wire fron coil.
Apr 26, 2015 | Volkswagen Cars & Trucks
I have a lt1000 with a 17.5 horse briggs was running great died one afternoon and has no fire to the plug. keeps fouling the plug. what could be the problem.. How do u test the magnito and where does it...
you can use a neon bulb voltage tester to check for spark
a magneto gets its spark from the collapse of the magnetic field that occurs when the points close
the magneto is comprised of two coils.
a primary and a secondary.
when the points are open the primary and secondary are one continuous circuit and generates a considerable magnetic field when the magnet passes the magneto.
when the points close the primary coil is shorted to ground.
this causes a very rapid collapse of the magnetic field in the magneto.
this field collapse can generate a very high voltage surge (the power for the spark)
this surge can exceed 12,000 volts or more and yes it is a bit painful
Sep 08, 2013 | Garden
How to strip a electronic distributer to check points
The points just close & ground out the ignition coil
& then the secondary field collapses to the spark plugs
You can see what the points are doing, turning over the
motor
No points in an electronic distributor
Mar 19, 2013 | Cars & Trucks
No fire at plugs on golden jubilee ford tractor . I have power to the coil and power out of the coil but can't get any fire.
check and see if the points are gapped, no gap or too wide(not closing) make sure the point set is grounded properly and the connector tab from the points to the terminal is insulated. if you dont find it here then you have a bad condensor. look closely where the terminal comes out of the distributor and make sure the insulator is intact. i have seen people putiing in points loose them and also cracks from the years have led them to rot and when the terminal is turned they just turn to dust. i found one from just 8n's for mine and put it in he has naa parts as well. the trick is the points have to open and close and not be gronded to the hull of the dist. the only ground on the points should be where the screws hold them in the other side (breaking side should not ground) . good luck and hope this helps
Aug 02, 2009 | Ford Tractor Naa Golden Jubilee Emblem
No fire untill you let off starter button
Check the ground to your coil. Same problem happened with my buddies bike I was working on.. I was baffled by it... then realized the ground had a bad connection.. If not your coil, check other grounds that have to do with your ignition system.. even try checking the battery terminals to see how tight they are.. are you getting gas? have you checked for spark? Check all these points and I can almost guarantee its somewhere in there..
Mar 14, 2009 | 1980 Yamaha XS 650 G
Garden Logo
12 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
