Question about Health & Beauty
Philips PT920 fault: when fully charged, the shaver turns on as normal buy pressing and holding the on button, but it cuts out very quickly (after a second or so) with the on button still down. Release the on button, then press and hold it again and the fault recurs. Any idea what is wrong?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 32 Answers
Even though it is fully charged you may need another battery?
Posted on Oct 14, 2013
  • 3 Answers
SOURCE: charging stand
I just had the same problem, where the top of the charger would not stay down. I tried a spring clamp to keep it in place, and that works like a charm! Try it!
Posted on Sep 14, 2008
EwingElect
  • 276 Answers
SOURCE: norelco shaver, 7310XL will not run with the
Make sure that the comb and cutters have been dismantled and cleaned thoroughly. If they are jammed up with hair they won't work. Also check the surface of the comb and make sure there are no bumps or dents that will stop the head rotating.
Posted on Mar 25, 2009
  • 14 Answers
SOURCE: shaver cutting out
Sounds like the switch to me ... all stops when it stops ... no charging and no running ... take a look at this video ...
http://www.youtube.com/watch?v=9b7lf5hqjag
Posted on Apr 28, 2009
brector3
  • 1602 Answers
SOURCE: HQ7830 Philips Shaver. Does not turn on, bu light shows when char
your battery is probably bad or you may have a loose connection inside. you will find batteries at shaveroutlet.com
Posted on Jan 16, 2010
brector3
  • 1602 Answers
SOURCE: Braun 790cc Shaver battery not holding charge
the item has a 2 year warranty. if you have proof of purchase date, you should call Braun for warranty service. Phone number is in your owner manual
Philips pt920 makes clicking noise but doesn't 'spin'. When turned on there is a clicking noise. The 3 rod like things which normally spins no longer spins. The head should be working as its removed.
If you flip the head up and the shaver will run without the blades engaged, there is a problem with your blades. The may be installed incorrectly or damaged. Check that they are installed correctly using the video below
https://www.youtube.com/watch?v=Al2GIfK5bZM
When removed, each cutter should turn freely inside its corresponding comb. If one or more do not turn, there is damage and will need replaced. Replacements for model PT920 can be found at shaveroutlet.com at the link below
http://shaveroutlet.com/norelco-philips-hq8-spectra-sensotec-replacement-heads-p-251.html
Sep 11, 2016 | Philips Health & Beauty
Battery replacement braun
Have a Philips pt920 cannot find it to register for extra twelve month Can you help please
Dec 24, 2013 | Braun Syncro 7526 Electric Shaver
When the "Philips Senso Touch 2D" electric shaver is fully charged should the charger be turned off
It is not advised that you leave the shaver charging after it has fully charged.
Apr 17, 2013 | Health & Beauty
I HAD PURCHASED A HQ8140 SHAVER 1 YEAR 9 MONTHS
This problem can be caused by a malfunctioning printed circuit board inside the shaver. This usually can be fixed by fully discharging the battery then fully charging it or disconnecting the battery then reconnecting it (if possible, most shavers has their batteries soldered-in).
Jan 09, 2010 | Philips Health & Beauty
The power button dosent come on when I push it.
Quick solution-find a small needle and press the reset button-it's under the "hold" button on the left side of the player. it will NOT erase the songs. It turned it on and then i was able to charge it and havent had the problem since!
~Betsy~
May 29, 2009 | Philips GoGear SA3020/37 MP3 Player
Doesn't hold a charge or cut very well anymore
Heads for your model are no longer available. Shaver will not hold a charge because batteries need replaced. Batteries can be replaced but soldering is required. If you have cleaned it well and it does not cut, I suggest getting a new shaver.
A full line of Philips Norelco shaver can be found at shaveroutlet.com
ShaverOutlet com ShaverOutlet com Rotary Shavers Men Shavers Manufacturer...
May 22, 2017 | Norelco Advantage 5615 X Electric Shaver
Smarttouch xl lock
Keep the on/off button pressed for approx 30sec (or more) until the razor starts
Dec 05, 2007 | Philips SmartTouch-XL HQ9190 CC Electric...
Brand new razor.. one clean and then...
Had the same problem. The cleaning light was flashing faster than the charge light. I pressed the on/off button twice in quick succession and the cleaning cycle started normally and the lights began flashing together. Don't know why I had to press the button again, but it did the trick.
Aug 12, 2007 | Norelco 8170XLCC Electric Shaver
Health & Beauty Logo
95 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
