Question about Husqvarna Viking 1
Every time I go to sew, the machine closes down & all the function buttons light up. It then comes back on but repeats everytime I either press the foot pedal or tap the start button. It's a Husqvarna Ruby.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 83 Answers
I would go directly to the mfg and see if they have a troubleshooting page or a teck that can help
Posted on Oct 20, 2013
4 Suggested Answers
SOURCE: Needle doesn't move the problem isn't the foot pedal
Same problem with my 400. I took it in to dealer and they said main computer board on my machine would have to be replaced. Fortunately, they agreed to get it fixed for me. My machine is 2 years old. How old is yours? I wonder if this could be a manufacturer defect on the machine? Maybe this needs to be addressed with Viking Husqvarna Corporate.
Posted on Jul 24, 2008
  • 96 Answers
SOURCE: Husqvarna 2000 sewing machine foot pedal stuck on but not pressed
you may need to take foot pedal apart and clean it the contacts inside may be dirty and causing it to stick
Posted on Dec 13, 2009
aeroseek
  • 55 Answers
SOURCE: foot pedal dead, machine keeps sewing!
Sounds like your foot control is faulty.
I can supply foot controls for 99% of sewing machines.
Mike
sewingmachines2004@yahoo.co.uk
http://www.sewingmachineswales.com
Posted on Oct 10, 2012
I followed the direction, the pressed the peddle. My stitches are straight instead of zigzag.
For the buttonhole function, there is generally also a lever you must pull down to engage the function. If you DID pull it down, you may not have pulled it down enough, so that it wasn't engaged.
Dec 27, 2013 | Singer Confidence 7469 Mechanical Sewing...
Elna 745 serger won't sew
the motor could have gone out or the machine could have jumped time, you may want to have the machine checked at a sewing machine shop
May 14, 2012 | Elna Sewing Machines
How to wind the bobbin on the singer creative touch 1030
on touch and sew models thread the machine up as normal, select straight stitch, presser foot up, take the thread from the needle and wind it round the presser foot screw a few times, open the slide plate, push the little button over, press gently on the foot control to wind the bobbin, when finished close the slide plate to drop the winder down and pull the threads to the back and start sewing
Sep 04, 2011 | Singer Sewing Machines
We have a Touch & Sew 640 that we ARE trying to get running, and we need a manual, and specifically how do w thread the bobbin.
To wind the bobbin, select straight stitch, thread the machine up as normal making sure the presser foot is up, open the slide plate, push the little button over to raise the winder, take the thread and wind it round the presser foot screw a few times, press on the foot control slowly and the bobbin will wind, when you have enough, stop, close the slide plate to drop the winder down, pull the threads to the back and start sewing. for manuals try www.tandtrepair.com
Jun 24, 2010 | Singer Touch Sew 7462 Mechanical Sewing...
I have a Juki MO-655. I just threaded the machine, plugged it in and when I turn it on the light comes on but the motor doesn't start when I press the foot control. I have all the doors on the machine...
I also have the Juki M)-655. Look at the power button; it should have 3 positions. First position turns the power switch Off, second position turns the power switch on and it will sew, third position turns on both the power switch and the sewing light. Several times I have thought I turned on the power switch to sew only to realize it was not in the second position. Hope this helps.
Jun 14, 2010 | Juki MO-655 Mechanical Sewing Machine
Pfaff grand quilter 18.8 with Q-Bot, and having problems with the stitch regulator. Anyone else have this problem? Any solutions?
the up and down buttons are not working properly. When pressing the needle down button, the needle does go down and then comes right back up. pressing the needle up button makes the needle shoot up and down 2 times very fast. HELP
Oct 07, 2009 | PfaFF Sewing Machines
How do I program my Viking 980 sewing machine? I can't find my manual & I think this machine can be programmed to stitch a word/phrase at one time, but I can't figure it out.
First touch the "P" button, the #1 will appear in the left digital window. Choose the first letter you want to sew and then push the reverse button, ( the button furthest to the left with the upside down arrow on it) that puts your first letter into memory. Then select your next letter and push the reverse button again. Repeat the process until your word is programmed into the machine.You can start sewing immediately by pressing on the foot control. Pressing the finishing button (Bullseye) before you start to sew, will make the machine tie off each letter so you can cut the joining stitches. Husqvarna may be able to make you a copy of the manual. They can be reached at: 1-800-474-6437 Good Luck
Oct 03, 2009 | Husqvarna Sewing Machines
Red light comes on when pressure foot is down
Is your bobin winder thing on top pushed to the left? If it is pushed to the right - the machine will not allow you to start sewing.
Jan 04, 2009 | Singer 5050 Mechanical Sewing Machine
Electrical problem?
Neither the needle up/down or the LED for the stitch selector will work if the bobbin winding pin/holder is pushed to the right (meaning pushed into the winding position). If you accidentally left the winding pin/holder pushed over, you will lose the functions of both the LEAD and the needle up/down button! (Neither of these functions can work while in bobbin winding mode!)
Nov 04, 2008 | Janome 4623 Mechanical Sewing Machine
Buttonholes
Put on the C foot. Select the buttonhole stitch. The machine will start sewing in the bottom left corner of the the buttonhole. Sew the length that you need, press and release the reverse button and sew the right side of the buttonhole. When you get back to the bottom, press and release the reverse button again and the buttonhole will be finished and the thread will tie off and the machine will stop. If the buttonhole is what you want, press and release the Stop button and the machine will repeat this buttonhole as many times as you need until the machine is turned off or the Stop is pressed again. When repeating, you need not press the reverse. Just press down on the foot control and continue until the machine stops by itself.
If you don't like the first one, just sew another one using the reverse button to set the ends.
Jun 28, 2008 | Husqvarna Viking 1
Sewing Machines Logo
105 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
